RE: E-Flite Brushless Conversion (I did it!)
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> RE: E-Flite Brushless Conversion (I did it!)
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: E-Flite Brushless Conversion (I did it!) - 10/7/2005 4:04:28 AM
arpitman
Status: offline
bdavison: I have looked around and can't find the 9CSuper with the synth module for less than $450. Where can you get it for $349?
(in reply to blw)
       Post #: 26
RE: E-Flite Brushless Conversion (I did it!) - 10/7/2005 4:14:54 AM
arpitman
Status: offline
I was also wondering if someone could advise me on what type of radio to get. Some are FM, some are PCM, etc. What mode do I want? I currently have the Blade. I can also get a Futaba compatible receiver at the LHS, but am not sure what it is (FM, PCM, etc). I appears that the 9C Super has several different types. What is the method of choosing?
(in reply to arpitman)
       Post #: 27
RE: E-Flite Brushless Conversion (I did it!) - 10/7/2005 4:28:04 AM
arpitman
Status: offline
As I look I am coming up with more questions than answers. I am in Utah if that helps. I don't go to any clubs or anything. I just fly with my friends at work. They have all different radios.
I am thinking the Futaba 9C Super is going to be the way to go. Spend a little more and have a radio for life....I am trying to figure out which one, however, because there are a TON of different models. I want the least expensive that will give me enough functionality to hook it to my Blade CP and my Planes and use a Synth module. That is all I need. I like the idea of the CAMP module, but won't pay a ton extra for it.
Suggestions please??? Include where the least expensive prices are going to be.
       Post #: 28
RE: E-Flite Brushless Conversion (I did it!) - 10/7/2005 3:42:08 PM
bdavison
Status: offline
Call Tony Stillman at Radio South.
www.radiosouthrc.com
Radio South is a authorized Futaba repair facility, and Tony knows everything there is to know about a Futaba radios.
He can hook you up with a good deal on it. Tell him I sent you.
I got mine new in the box 9CSuper tx, Synth Module, Tx battery and Tx Charger for $349.99...$379 after tax. I think thats his regular price on them.
Awesome deal if you ask me, considering its MSRP is like $579 bucks.
_____________________________
teamflyingcircus.com
       Post #: 29
RE: E-Flite Brushless Conversion (I did it!) - 10/7/2005 3:59:42 PM
bdavison
Status: offline
The Blade is a PPM(FM) reciever
The 9CSuper will fly PPM, and PCM1024 recievers. You can select which right off the main menu.
It wont fly the old PCM512 recievers, but you will rarely see these. The only Futaba radio I know of that came with one was the old single stick one.
Im working on getting the set-up for the Blade programmed in mine. Once I figure it all out, Ill post it up here so everyone can use it, I dont want you guys to have to figure it out. Its complicated if your starting from scratch.
Also you get a CAMpac module with it that will hold about 6 airplanes, and the radio itself has a 12 plane internal memory. You can get more CAMPac's later that will enable you to store up to 1000 different airplanes.
       Post #: 30
RE: E-Flite Brushless Conversion (I did it!) - 10/7/2005 4:02:33 PM
bdavison
Status: offline
I think I might have to post a review of it up here with some pics.
(in reply to bdavison)
       Post #: 31
RE: E-Flite Brushless Conversion (I did it!) - 10/7/2005 4:44:28 PM
arpitman
Status: offline
bdavison: thanks for all the great info. When I get the 9C Super do I have to get one of the CAMPac modules in order to share the configuration stuff or do I just have to get the file from you and download it? If download it, is there a cable I need? Are you setting up your 9C to work with the 4 in 1 that comes with the Blade or your own descreet components? If not the 4 in 1, do you think it would work? I can't afford a Gyro and receiver and everything else and would like to salvage the 4 in 1 even with a new TX. Any ideas are appreciated.
       Post #: 32
RE: E-Flite Brushless Conversion (I did it!) - 10/7/2005 6:51:20 PM
bdavison
Status: offline
You wont need a CAMPac for it.....The CAMpac is just for saving your setups once you enter them into the radio. If two people have 9CSupers, you can swap airplane setups by putting there campac in your radio, and copying the "plane"
What Ill probably do is once I get it all set-up, Ill post TEXT including the settings so you can just dial them into your radio.
Im going to program it for the stock 4-in-1 box, and try to match the programming exactly like how the stock transmitter works to begin with.....then start tweaking it for max performance.
So far, This is what Ive got....
Swashplate type - SR-3
Ail Swash AFR = -50%
Norm Pit-Crv - 0,13.5,15.0,20.0,37.0
At 37.5 you start getting binding between the swashplate and the bottom of the main shaft. So far this mix, matches the stock mix pretty closely for normal mode.
       Post #: 33
RE: E-Flite Brushless Conversion (I did it!) - 10/7/2005 6:58:58 PM
arpitman
Status: offline
Awesome. I hope I get the 9C I bid on ebay.
       Post #: 34
RE: E-Flite Brushless Conversion (I did it!) - 10/8/2005 3:17:38 AM
blw
Status: offline
The Futaba settings would be a great thing to have when you post them up.
The CAMPac is a small module that isn't very expensive. Most radios come with them installed nowadays. Mine came with one from Tower Hobbies. I think you can store 6 or 8 models in it. I mostly use mine as a backup for my main radio memory...just in case. My 9C started draining batteries too fast and I had to send it in for warranty repair not long ago. A friend had a 9C that he has hardly used and he offered to let me borrow it. I plugged my RF module in his for my channel, and ran it off of my CAMPac without any problems. I had some complex settings for my pattern plane and I doubt that I would have put those in his radio if not for the CAMPac.
You cannot swap CAMPacs between 9Cs and the 9C Super. They will be erased if you do.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
       Post #: 35
RE: E-Flite Brushless Conversion (I did it!) - 10/15/2005 10:37:50 PM
DarkWombat
Status: offline
Yea I'm using a JR 6102 TX for my heli, great system and it's inexpensive. Sorry bdavision, I'm not a Futaba guy
< Message edited by DarkWombat -- 10/15/2005 10:43:23 PM >
We are the musicmakers, and we are the dreamers of the dreams.
(in reply to blw)
       Post #: 36
RE: E-Flite Brushless Conversion (I did it!) - 10/15/2005 10:39:02 PM
DarkWombat
Status: offline
This questions is directed to both you radio conversion guys and to the brushless conversion guys. I'm still toying with the idea of going brushless with my Blade. Had a crash recently so It's a reason to get an all-aluminum frame and tail boom and skids setup for my rebuild. But now I'm considering a brushless motor. It would be cool, no doubt. I've already converted my Blade to use a 6102 TX and I had an Eflite 2-in-1 controlling the main and tail motors. However in the crash the impact was so hard (the rotor blades smacked into a wooden post, the impact was so strong that the spindle actually snapped and the rotor blades took off in opposite directions landing almost 10 feet from the heli, it was one of those rare screw-up cases where I didn't realize how close I was getting to stuff, but anyways....) that my 2-in-1 actually burned out. So I can replace the 2-in-1 and go with the aluminum frame setup or I can use this as a reason to go brushless. Tail motor burnouts shouldn't be an issue because the aluminum frame comes with a dual tail motor mount that splits the work between two motors so they last a LOT longer. I expect to be using carbon fiber blades and if I go brushless I'll first get a Hyperion E-Meter which is a digital wattmeter and tachometer in one unit to post results. My 3S 900mah LiPo battery came out of the crash unscathed (thank God) so I will be using it again.
Anyways, the real question here is how to you get two separate speed controls to share the same battery pack? I expect to use a Phoenix brushless ESC for the main motor (will be an Eflite 370) and probably a pixie or some other brushed ESC for the tail motors, but how will the tail motor ESC get its power? Would I have a plug that connects the battery inputs for both speed controls and merges to a single battery connector, or are there other, better ways to go about this? Also, how will the gyro interface with the tail motor speed control (I'm using a GWS PG-03 gyro).
Of course there's always the possibility of using my burned-out 2-in-1 for the tail motors and just not using the main motor. The 2-in-1 only burned out the main motor speed control section; the tail motors, BEC and gyro system works fine still. I could use that to control the tail but I'd have to find some way to give power to the Phoenix running the brushless motor.
Any suggestions?
(in reply to blw)
       Post #: 37
RE: E-Flite Brushless Conversion (I did it!) - 10/16/2005 12:20:50 AM
thecheatscalc
Status: offline
do what I did on my 36 just patch the power wires into the Rx batt cables (the ones that have the deans/whatever connector and goes on the battery connector) though I'm not really sure how it works with a blade controler having the tail motor and all... you could just get a new Rx...
www.ushobbysupply.com - your #4 HQ!
All stock located in the U-S of A!
(in reply to DarkWombat)
       Post #: 38
RE: E-Flite Brushless Conversion (I did it!) - 10/16/2005 12:51:18 AM
bdavison
Status: offline
Since ive been playing with the pitch curves in my 9C, Ive noticed that it is possible to get the head to spool up so fast that the tail rotor cant spin fast enough to counteract torque....and thats with the stock motor. Im a little hesitant to put a brushless motor in there, because I think I would have to go brushless on the tail too to get it to work properly. A brushless motor only is going to put alot of strain on the tail motor to keep up.
Im almost finished with the pitch curves and programming....should have it up here shortly.
