E-Flite Brushless Conversion (I did it!)
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> E-Flite Brushless Conversion (I did it!)
Page: [1] 2 3   next >   >>
Login
E-Flite Brushless Conversion (I did it!) - 10/2/2005 9:00:18 PM
arpitman
Status: offline
I have had my Blade CP for about a month. I love it! I mainly have been flying planes. I had a gas Heli a long time ago, but didn't get much beyond hover before giving up on it. I saw a used Blade for sale for $200 without knowing you could buy them new for $220. I bought the used one thinking it was a steal and fixed the broken parts. I was amazed at how cheap it was to fix after each crash (yes I crashed a lot at first).
I am now flying pretty good. I don't crash as much and am enjoying....
Now to the reason for the posting, brushless conversion. I was very bummed when I first realized that the 4 in 1 seemed to preclude the possibility of adding a brushless. Having flown planes I have learned the great benefits of brushless for planes. I figure the same features will come to Heli if I could only do it.
I don't have the money for a new radio with Heli mixing and all the stuff that would be needed to convert the Blade to new electronics. I am a software developer who works with electronic hardware engineers and turned to one of them to help. We came up with a plan to build a small module that would convert the brushed motor output to servo input that could be used to drive a brushless ESC. During the pre-development stage of this I discovered something about the 4 in 1 controller.
WARNING: following from here and doing what I did will for sure void the warranty of your 4 in 1 controller. Don't do it if you ever hope the make a warranty claim for your 4 in 1....
I was looking at it and realized that all of the servo channels are there. If you cut the plastic that covers channels 3 and 4 (throttle and rudder on most receivers) you will find that the pins are there, they are just very short. If you take a screw driver and remove the cover completely you will find that the receiver is pretty much a basic 6 channel receiver. I would guess even than you could replace this half of the 4 in 1 with just about any receiver as long as the pins lined up.
You will also notice that the pins on channels 3 and 4 are not missing or just short, E-Flite has simply taken the pins connector and put it on the OTHER side of the receiver. It plugs into a connector on the OTHER half of the 4 in 1. I would guess it goes right into a mixer that outputs to 2 ESC's....one for the main motor and one for the tail.
The conversion I did is simply to solder pins onto the "normal" side of the receiver to channel 3 so that you can connect a brushless speed controller to it. DON'T connect the main motor output from the 4 in 1 to anything. Connect a brushless ESC to channel 3. You must also still plug the receiver back into the 4 in 1 like normal. When you are done the only difference to the 4 in 1 is that you have soldered on extension pins to channel 3 so that you can connect your brushless ESC to channel 3. Oh yea, and cut off the small piece of plastic that normally covers channels 3 and 4. Once you have done this you can connect everything back together like normal, except don't connect the main motor connection on the 4 in 1 to ANYTHING. Instead connect your brushless ESC to channel 3 and then to a brushless motor. Install the brushless motor in place of the normal brushed one and away you go!
Not knowing the RPM or KV rating of the stock motor at first I chose a E-Flite brushless "Park 370" with a KV of 5400. This worked ok except that the RPM was so high that the motor got really hot because of the strain on it. I lowered the pitch a bunch and that worked better until I reached the stall speed of the rotor because the RPM was so high.
I did some further research on the forums and came across a posting about needing to be in the 3600 to 4100 KV range. My LHS didn't have the Park 370 rated at 3600 so I got the Park 400 rated at 3700 KV instead. It is a little taller, but fits. I am not sure yet if I will have a problem with the rotor hitting the top of it in extreem flexing situations, but so far so good.
The RPM is about right now with the pitch set good. I have not flown this yet because we are having a strong front move through and the winds are beyond my comfort level, but I hope to try it tomorrow.
I know it will work, however, because even with the 5400 KV 370 motor it flew great! the motor and battery just got hot. The conversion itself works. Mixing happens because the receiver is still plugged into that side of the 4 in 1 like normal, but the brushless ESC gets its setting directly from channel 3 on the new pins I installed.
I had a hardware friend do the actual solder job for me because he is much better at it. We decided the best way to connect the pins is to solder them in the same line horzontally as the short pins, but offset to the right as you look at the 4 in 1 from the receiver side. This required cutting a small bit of plastic just to the right of that so the brushless ESC servo connector fits.
I will try to get some pictures of the mod tomorrow when I am at work where I have a camera that can do it. Ask any questions. I will be happy to answer if I can.
Enjoy....
       Post #: 1
RE: E-Flite Brushless Conversion (I did it!) - 10/2/2005 9:14:24 PM
arpitman
Status: offline
DISCLAIMER: I am not sure how these forums go, but being new to it I thought I should add a disclaimer to my posting. I am sure you will void your warranty if you make the modification I suggest. Although it worked for me it may not work for you. You might destroy your helicopter. You might get hurt or killed or hurt and kill someone else. You might damage and destroy property.
Having said that I hope none of it happens to anyone. If you are willing to accept the risks youself, this modification could help in performance
After posting this I also realized something about this conversion. I don't know if IDLE UP will work in this configuration or not. It will depend on whether the IDLE UP signals are generated by the mixer or by the transmitter if they are generated by the transmitter then it should work fine. If by the mixer on the 4 in 1, then it won't work.
I am not advanced enough to be at the point of using the IDLE UP mode myself yet. I turned it on once while the heli was still on the ground and played around just enough to see what it was doing. I have NOT flown in IDLE UP mode for fear of over controlling and crashing badly.
I will, however, try to test the IDLE UP tomorrow and see if it works with the modification or not. I don't think I will destroy the Blade if it doesn't work, I should just not get the possitive throttle change when I lower the lever on the transmitter which should not cause a problem. If it does work, then all the better! I will let everyone know....
(in reply to arpitman)
       Post #: 2
RE: E-Flite Brushless Conversion (I did it!) - 10/2/2005 9:19:05 PM
sparkling_fist
Status: offline
so to sum it up in a "SHORT" sentence.. how did u get the brushless motor instead of the brushed..
_____________________________
Barbarian for life.
Stuff happens then you die.
       Post #: 3
RE: E-Flite Brushless Conversion (I did it!) - 10/2/2005 9:29:56 PM
arpitman
Status: offline
It was kind of a lengthy post, wasn't it. Sorry about that. Short version:
1. Cut the plastic covering channels 3 and 4 on the 4 in 1 controller.
2. Unscrew the screws and remove the cover on the receiver side of the 4 in 1.
3. Carefully solder metal pins onto the 3 short pins of channel 3. Offset them to the right but in line horizontally. You could try to solder them right on the ends, but I doubt you will be able to and if you do they probably won't hold very long in the vibration of the heli.
4. Put the cover back on the 4 in 1 and screw it down.
5. Plug any normal brushless ESC into the newly installed channel 3 pins.
6. Do NOT connect anything to the normal main motor output of the 4 in 1.
7. Remove the stock motor and replace it with a 370 size brushless motor or similar. Make sure the KV rating is between 3600 and 4100. Also make sure you use the 8 or 9 pin gear on the motor, no bigger!
8. Make sure everything is connect properly.
9. Add a connection from the brushless ESC battery plug to the 4 in 1 battery input (I forgot this in the original posting, sorry).
Put everything else back together like normal and away you go.
(in reply to sparkling_fist)
       Post #: 4
RE: E-Flite Brushless Conversion (I did it!) - 10/2/2005 9:40:31 PM
sparkling_fist
Status: offline
ok i get everything more or less.
except.. by "4 in 1" you mean the 4ch rx?
you should really get some pics..
Barbarian for life.
       Post #: 5
RE: E-Flite Brushless Conversion (I did it!) - 10/2/2005 9:44:29 PM
arpitman
Status: offline
By 4 in 1 I am talking about the Blade CP 4 in 1 controller. It is the all in one controller that the Blade CP comes with.
As I mentioned in my original posting I am going to upload some pictures tomorrow when I am at work because I have a camera there I can use to do it.
       Post #: 6
RE: E-Flite Brushless Conversion (I did it!) - 10/2/2005 9:48:24 PM
sparkling_fist
Status: offline
ok all good
Barbarian for life.
       Post #: 7
RE: E-Flite Brushless Conversion (I did it!) - 10/4/2005 7:18:56 PM
arpitman
Status: offline
These images are not the best, but should help some:
Heli1.jpg shows the connection to channel 3 on the 4 in 1 controller. It is a little blurry, but should give you the general location.
In Heli2.jpg the rounded yellow rectangle shows my brushless speed controller. Notice how close it is to the server arm. Make sure you position it somewhere that it will not interfere with anything else. I had it closer to the 4 in 1 and think I was getting some noise that caused radio interference. That is why I moved it over here. The circle is around the servo arm.
In Heli3.jpg location 1 is where you DON'T have the old motor plugged in. Location 2 is the speed controller again from the side. Location 3 is where I have spliced in a connector to give power to the 4 in 1 from the battery leads to the brushless speed controller. Location 4 is the new connector for the battery. This goes directly to the brushless speed controller.
I hope these images help some. Sorry they are not better quality.
Tony
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 8
RE: E-Flite Brushless Conversion (I did it!) - 10/4/2005 7:19:58 PM
arpitman
Status: offline
Sorry about posting the images twice. There are only 3.
       Post #: 9
RE: E-Flite Brushless Conversion (I did it!) - 10/4/2005 7:59:23 PM
bdavison
Status: offline
Im gonna have to try this.
Im assuming you are still using the stock tail motor plugged into the 4-in-1 box as normal to utilize the on board gyro.
This is a pretty slick set-up.
Ive seen some posts kind of like this before, but most of them are going to a complete brushless setup...including tail motor. which can be done but you are basically bypassing the onboard mixer and gyro. Kind of a waste if you ask me.
Ive got a few questions though, and some of them you may not be able to answer until you get some flight time on the new system.
1. Have you had any tail motor burnouts due to the tail motor having to work harder to counteract the increased torque from faster rotor head speeds.
2. Have you experienced any interference problems from the brushless ESC.
3. Have you done a tach on the rotor head to see what the rpm differences are between the stock and brushless set-ups
4. Does the idle-up still work?
You really should try flying in idle-up mode. Collective is more responsive. Just remember to spool the rotor head up to half throttle before flipping the switch to prevent stripping the main gear. Another benefit of the idle-up mode is landings. You can really stick a landing. Bring the heli in to your landing spot, once you get it directly over head and about 2" off the deck, start feeding in a little negative pitch and it will drop and glue itself right on to that spot. Makes landings look really good. Takes a little finesse to get it right.
teamflyingcircus.com
       Post #: 10
RE: E-Flite Brushless Conversion (I did it!) - 10/4/2005 8:35:52 PM
arpitman
Status: offline
1. The tail motor mixing is about the same. The only reason a tail motor would burn out any differently would be the higher voltage of the LiPo I am using.
2. I am not sure, but do think I was getting interference between the BL ESC and the receiver. That is why I moved it towards the back of the Heli instead of being on top of the receiver like I had it originally.
3. I have not. I don't have access to one. What I did do was find a posting from the E-Flite people talking about using a KV (RPM per volt) rating of between 3600 and 4100. The motor I am using is 3700 KV.
4. I just verified that in my current setup the Idle Up does NOT work right. The RPM gets too high compared to the pitch setting. I can fly it in normal mode, but when I switch to Idle Up mode the Heli squashes to the ground (I have not lifted off yet, thankfully or it would smash into the ground). I can tell this also by the fact that I am lifting off before the throttle is even half way and yet when I Idle Up the pitch is obviously going too far negative.
My plan on this last item is to switch to the 8 pin gear. Currently I have the 9 pin gear. With the 8 pin gear I should need a higher setting on the throttle before lift off and this should allow me to have the throttle high enough to work right. I will order in the 8 pin gear and let you all know what testing reveals.
It does fly GREAT in normal mode!
(in reply to bdavison)
       Post #: 11
RE: E-Flite Brushless Conversion (I did it!) - 10/5/2005 3:18:29 AM
tomcatt51
Status: offline
arpitman, Sounds like idle up is doing just what it's supposed to. Full down stick is full throttle, full negative pitch. Middle stick is 50% throttle, 0 pitch. Full up stick is full throttle, full positive pitch. Pitch and throttle curves for stock tx are shown on page 19 in the manual. Hope this helps. Tom
       Post #: 12
RE: E-Flite Brushless Conversion (I did it!) - 10/5/2005 3:42:48 AM
