RE: Opensource CDI ignition
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Roto Motors 25V / 35Vi / 50V2
Seller:  shosho
Details:   $419.00   |  11/9/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: Opensource CDI ignition
Page: <<   < prev  3 4 5 6 7 8 9 [10] 11 12   next >   >>
Login
RE: Opensource CDI ignition - 11/23/2008 3:12 PM
Futterama
Score: 100
Last Login: 11/17/2009
Status: offline
Hi,
I have now received both the LT3750 and the DA2034 but I don't know when I will get the time to work with it. The coil looks nice and small and the LT3750 is a 10-Lead Plastic MSOP and that is smaller than the SOIC I'm used to work with, so there is a challenge for me just to solder the LT3750
Uwe, please notice the Recommended Board Layout on page 11 in the LT3750 datasheet before testing
/Martin
Hide Signatures
(in reply to Futterama)
       Post #: 226
RE: Opensource CDI ignition - 11/23/2008 6:31 PM
aerodactyl
Score: 100
Last Login: 11/5/2009
Status: offline
Hi Martin,
last Friday I received the coils, but I'm still waiting for the LT units.
The coils I ordered were the small and the medium version 3A and 6A (each 3 parts ) They really looks nice and small. Let's see how they will work.
Yes, I'm aware of the layout. Next week I propably will find time to make a test layout for my system.
I will keep you informed.
Best regards from a snowy Germany
Uwe
Hide Signatures
       Post #: 227
RE: Opensource CDI ignition - 11/23/2008 9:25 PM
captinjohn
Score: 135
Last Login: 11/21/2009
Status: offline
BigBoat, I have a question. I am hooking up different sensor wires that use 3 wires to pick-up. I was wondering what happens when the + and minus leads are unsoldered and switched, leaving the center where it is. Will the ignition still work...by fliping the magnet in hub thus changing polarity (North & South poles). Or will the system not work at all? Thanks Capt,n
Click to see fullsize image.
Click for fullsize
< Message edited by captinjohn -- 11/23/2008 9:27 PM >
_____________________________
I never met a engine I did not like!
Hide Signatures
       Post #: 228
RE: Opensource CDI ignition - 11/23/2008 9:39 PM
Bigboat
Score: 100
Last Login: 11/19/2009
Status: offline
The problem can be a variable ignitiontime.
The ignitiontime must be exact and not *somewhere*.
By using two magnets, one for the ignition and one to filpback, maybe it will work.
BUT, the charge-time will be shorter, your missing the piece between the two magnets, and also the max-rpm will be lower.
CU, Rob - www.modelbouw.gompy.net
Hide Signatures
(in reply to captinjohn)
       Post #: 229
RE: Opensource CDI ignition - 11/24/2008 3:32 AM
captinjohn
Score: 135
Status: offline
The system I was working on did not fire and I found a unsoldered pin in a connector lead to pickup sensor. Would this ruin the picup sensor or other parts in the CD unit itself? Thanks Capt,n
Hide Signatures
(in reply to Bigboat)
       Post #: 230
RE: Opensource CDI ignition - 11/24/2008 10:23 PM
Bigboat
Score: 100
Status: offline
NO.
If the lead was the +, and contact the pulslead the cdi fired, if the + contact the -, the cdi didn't do anything at all.
Hide Signatures
       Post #: 231
RE: Opensource CDI ignition - 11/25/2008 3:17 AM
captinjohn
Score: 135
Status: offline
quote:
ORIGINAL: Bigboat
NO.
Big boat...what are the normal wire colors that go to sensor? You know ...like 3 wires...3 connections. Is red + ? Black - ? and middle wire??? In other words what color goes where in a normal setup? Thanks again Capt,n
Hide Signatures
       Post #: 232
RE: Opensource CDI ignition - 11/25/2008 5:17 PM
Bigboat
Score: 100
Status: offline
Red = +, black = - and every other color can be te puls.
Hide Signatures
       Post #: 233
RE: Opensource CDI ignition - 11/26/2008 2:59 PM
captinjohn
Score: 135
Status: offline
quote:
ORIGINAL: Bigboat
I guess I got to read more on your website and maybe simular ones too. Best Regards Capt,n
Hide Signatures
       Post #: 234
RE: Opensource CDI ignition - 12/12/2008 2:15 AM
Happymcc
Score: 100
Last Login: 9/30/2009
Status: offline
Hi to all
Is anyone selling the EEprom's already programed ?
Fly Lite Fly Right
Hide Signatures
       Post #: 235
RE: Opensource CDI ignition - 1/8/2009 5:05 PM
Phatburner
Score: 100
Last Login: 3/25/2009
Status: offline
Hello everyone;
I found this forum while looking for information on home made CDI. I want to thank those who have done so much work and for sharing. I would like to join in the development work with the LT3750 and am ordering it along with the DCT20EFD transformer made by TDK which is available from the local supply. I am surprised you guys can run a CDI from batteries as I did the scratch pad calculation to reveal that with 80mJ spark at 12000 rpm that means 16 watts if the efficiency is 100% so it must require around 20 watts from the battery. This is no small power and I am wondering if your engines have a generator??
Joe
Hide Signatures
(in reply to Happymcc)
       Post #: 236
RE: Opensource CDI ignition - 1/8/2009 5:14 PM
Bigboat
Score: 100
Status: offline
No generator, only batteries and the CDI can run for about 6 hours on a 6V 2000mA NiMh.
Hide Signatures
(in reply to Phatburner)
       Post #: 237
RE: Opensource CDI ignition - 1/9/2009 8:48 PM
Bigboat
Score: 100
Status: offline
quote:
ORIGINAL: Happymcc
Hi to all
A preprogrammed PIC is not possible becourse you need the curve of your engine programmed.
Not all engine start at 30 degrees befor TDC.
You have to make the curve by yourself and program the PIC with it.
Hide Signatures
       Post #: 238
RE: Opensource CDI ignition - 1/10/2009 4:37 AM
Happymcc
Score: 100
Status: offline
Thanks Bigboat
Thats to bad though
Would'nt RC engines be pretty much the same across the board ?
Fly Lite Fly Right
Hide Signatures
       Post #: 239
RE: Opensource CDI ignition - 1/12/2009 9:57 AM
STMCU
Score: 100
Last Login: 3/29/2009
Status: offline
Dear Rob,
I am the new comer but i gone though the topic. I have some questions and would like you to answer.
1. Is your CDI be able to work on 4 strokes engine ?
2. I have to use coil sensor ( instead for hall sensor), is it possible ? If not, how i adjust the schematic ?
I intend to build a CDI for motorbike engine ( 100 cc). Now i will start and hope to get your help.
Thanks in advance.
Tung.
Hide Signatures
       Post #: 240
RE: Opensource CDI ignition - 1/12/2009 10:34 AM
jpanhalt
Score: 100
Last Login: 11/6/2009
Status: offline
Happymcc,
If you are unable or unsure of how to program the PIC chip, there is lots of help available. Many electronics hobbyists will be able to do it for you. Almost certainly, high schools and local colleges also have the ability. It should cost nothing and takes almost no time to do, once you have the code in electronic format.
Check around. If you strike out, I would be happy to do it for you using the "standard" code.
John
Hide Signatures
       Post #: 241
RE: Opensource CDI ignition - 1/12/2009 4:29 PM
Bigboat
Score: 100
Status: offline
The CDI can be used on any engine even on a 4 cilinder.....with a little help of a electronic/mechanic switch.
It doesn't matter if you generate a spark in the exhaustrotation, the petrol is all ready be burned.
You can also use a counter IC (CD4017) or flipflop who release the spark every second count.
I don't understand a coilsensor ?
A CDI need a exact ignitionpoint to spark, it's much faster then a normal pointswitch.
You can also use a opto-sensor with a black/white disk or a hole into a white the disk.
Something like this, only with one white line
< Message edited by Bigboat -- 1/12/2009 4:34 PM >
Hide Signatures
(in reply to jpanhalt)
       Post #: 242
RE: Opensource CDI ignition - 1/13/2009 1:01 AM
Happymcc
Score: 100
Status: offline
jpanhalt
And all others that replied . Thank you for your time and info .
I have been using C&H ignitions for years and have gotten good service from them .
Right now I am working on converting a few glow engines to gasolline and strait methanol .
I have also seen a very simple internal oiling systme that I intend to try .
In researching engine conversions I ran across this thread on ignitions and maybe after
I get done experimenting on several 4 stroke conversions I think I will make one of these
ignitions .
Again thank you all and I will be back for help I am sure .
Fly Lite Fly Right
Hide Signatures
       Post #: 243
RE: Opensource CDI ignition - 1/13/2009 2:25 AM
STMCU
Score: 100
Status: offline
Dear Rob,
I meant coilsensor is magnetic or inductive sensor. Hall sensor produces square signal, using 3 wire (+/-/signal) and magnetic sensor produces a.c signal. I don't know if your CDI can be used with magnetic sensor ?
Regards,
Tung.
Hide Signatures
       Post #: 244
RE: Opensource CDI ignition - 1/17/2009 10:34 AM
Kymmy
Score: 100
Last Login: 4/25/2009
Status: offline
quote:
ORIGINAL: STMCU
Problem there is where to fire the coil on the resulting curve, also then temp variation would mean that it would fire sooner or later dependant on how hot/cold the circuit got... Best to stick with a latched Hall sensor
Kymmy
Hide Signatures
(in reply to STMCU)
       Post #: 245
RE: Opensource CDI ignition - 1/19/2009 9:30 PM
Futterama
Score: 100
Status: offline
quote:
ORIGINAL: Bigboat
Our HV-coil makes about 400 till 600 Volt, depent how the coil is wind and how the ocsilator is working.
Raisetime untill 150 Volt less than 3ms, 400 till 600 Volt within 3ms
I have just downloaded a simulation program for the Linear LT3750 and I set the cap to 470nF and the result is charge time 0.6ms to 150V and 2.9ms to 400V, so it looks promising.
Hide Signatures
       Post #: 246
RE: Opensource CDI ignition - 1/19/2009 9:38 PM
Bigboat
Score: 100
Status: offline
20ms = 50 Hz = 3000 RPM
2,9ms = ~350Hz = 21,000 RPM
The Voltage is also OK, it have to be between 400 and 600 Volt for a good spark.
Hide Signatures
       Post #: 247
RE: Opensource CDI ignition - 1/22/2009 3:39 AM
STMCU
Score: 100
Status: offline
Dear Rob,
I expecting your help to build the ignition advance timing curve for 4 strokes engine 100cc. Position of pickup sensor is 36o. Engine spark at 15o at low RPM and 27o at max RPM.
max RPM with full load is arround 8000 RPM and 12000RPM at no load.
I looked through the excel file which you showed to make timing curve but i don't know why you set POP (point of pickup) BTDC is 40 ?
Can you help.
Tung.
Hide Signatures
       Post #: 248
RE: Opensource CDI ignition - 1/22/2009 7:26 AM
Futterama
Score: 100
Status: offline
Hi again,
I wrote Linear and Coilcraft, and they suggested me to use the new Linear Technology LT3751 with a CoilCraft GA-3460-BL. This will charge a 200µF capacitor to 500V in 200ms with an input voltage of 12V. So I guess it could charge the 470nF in about 0.5ms with the input voltage at 12V. The voltage range goes all the way down to 4.75V so it will also run on 6V, but the charge time will increase, but I guess it will still be below 2ms.
My goal is a charge time around 2ms so I can use the CDI on a tuned Zenoah G260RC (on FG RC cars) - these can run above 20.000rpm so if the CDI can handle 30.000rpm (2ms), it will be fine.
Also, I think I will add a separate battery for the CDI, I don't think it will be a good idea to use the receiver battery because of the power consumption and electric noise.
I have another project going on, which will require 3 or 4 cells LiPo to be mounted on the FG car, so I will have 11.1-14.8V available for the CDI also.
Hide Signatures
(in reply to STMCU)
       Post #: 249
RE: Opensource CDI ignition - 1/22/2009 9:09 AM
Futterama
Score: 100
Status: offline
quote:
ORIGINAL: Bigboat
Bigboat, at which RPM can your CDI run for so long on that battery?
Hide Signatures
       Post #: 250
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.891RCU1
