RE: Opensource CDI ignition
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
CRRC-pro GF26i-V2 Free Shipping!, USA Warranty! - RTF
Seller:  Gravitybites
Details:   $239.98   |  11/16/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: Opensource CDI ignition
Page: <<   < prev  3 4 5 6 7 8 9 10 11 [12]
Login
RE: Opensource CDI ignition - 3/26/2009 10:17 AM
bluejets
Score: 100
Last Login: 11/3/2009
Status: offline
See how I go and I will post back success.
Built a few engines before and although this will initially be used in a test bed single cylinder, intention is for final use in V8.
Have 4 cylinder 25cc in scale Rivierra (1930's era) but this is methanol and glow. (Hull 60% complete)
Hide Signatures
(in reply to Bigboat)
       Post #: 276
RE: Opensource CDI ignition - 3/26/2009 11:36 AM
bluejets
Score: 100
Status: offline
Need assistance on capacitors quoted in diagram as C3 and C7. These are shown as being 100 nano electrolytic.
I have been around electronics for many years and have never seen an electrolytic under 470 nano and rare at that. None are listed in any suppliers here in Aus.
Can these be substituted by 100 nano MKT / 50 volt? (MKT = metalised polyester film)
or/ is there an error in the diagram and parts listing?
Hide Signatures
(in reply to bluejets)
       Post #: 277
RE: Opensource CDI ignition - 3/26/2009 1:12 PM
Bigboat
Score: 100
Last Login: 11/19/2009
Status: offline
Maybe your not long enough into electronics....
http://parts.digikey.co.uk/1/1/357489-cap-0-1uf-100v-elect-vr-radial-uvr2a0r1mda.html
_____________________________
CU, Rob - www.modelbouw.gompy.net
Hide Signatures
       Post #: 278
RE: Opensource CDI ignition - 3/26/2009 2:05 PM
bluejets
Score: 100
Status: offline
50 years apparently not long enough...... thanks for info all the same.
No digikey in Australia though..... maybe look at RS
Hide Signatures
       Post #: 279
RE: Opensource CDI ignition - 3/28/2009 12:03 AM
bluejets
Score: 100
Status: offline
Found suppliers of various parts in Australia for anyone interested.
Jaycar..... (C6) 470n/400 cap (630v in this case) RG-5247
Farnell..... (C3 and C7) 0.1uF/63V electrolytic order code 9452729
Hall sensor (Allegro) A3240EUA-T order code 1141949 (used these before with other ignition systems I've built)
Oatley Electronics ..... Surplus fluro inverters for ferrite trigger transformer ($4.00) part No. CFLINV
Also small magnets 3 x 1.5 .....part No. G58 ($0.25)
(use these before also and they work ok... leave about 2-3mm gap between magnet and sensor)
All other parts from Futurlec (on-line http://www.futurlec.com.au/Components.jsp )
I have not at this stage wound the trigger coils onto the above transformer bodies. So I do not know if they will work or not however, they seem to be the right size and I will re-post the results.
Hide Signatures
       Post #: 280
RE: Opensource CDI ignition - 3/28/2009 12:13 AM
bluejets
Score: 100
Status: offline
By the way, if you really want to go the Digikey way, here are the responses from the US supplier and the New Zealand supplier.
The following is for the supply of 5 only 0.1 capacitors with a cost of 15 cents each.
Thank you for the email to Digi-Key Corporation. I am sorry that shipping is so expensive.
Our only options for shipment are UPS, FedEx, DHL or sometimes we can use the Unites States Postal Express. I did check UPS Express and it shows $70.00. Fed Ex express is 75.24. I did check the Postal Express and found that to be around - $35.00 or so and they say it could take 5 to 7 days for you to receive them.
I do believe the other carriers would have them to you in a couple of days.
By the way, Digi-Key Corporation is located in the United States, in Thief River Falls, Minnesota and our only warehouse is here. If you checked our New Zealand site, the shipping is still from here.
Thank you for your email! Part number UVR2A0R1MDA-ND is a non-stocking part for us. We do not stock it but we can order it for you. The minimum orderquantity is 2800 pcs. We do stock the rohs compliant/lead free version. It is part number493-1136-ND and we have 5 pcs in stock. The unit price is $0.15, $0.75 forall 5 pcs. You will have to order through our US site as you are in Australia. You canonly order through the NZ site if you are shipping to NZ.
Sorry for the bad news.
Hide Signatures
       Post #: 281
RE: Opensource CDI ignition - 3/28/2009 12:30 AM
jpanhalt
Score: 100
Last Login: 11/6/2009
Status: offline
I don't understand why you need the electrolytic capacitor at that location in the circuit. Why not use a ceramic? If you need more ESR, add a resistor.
John
Hide Signatures
       Post #: 282
RE: Opensource CDI ignition - 3/28/2009 3:03 AM
bluejets
Score: 100
Status: offline
Asked this question myself (go up a couple of posts) Apparently not according to bigboat.
Hide Signatures
(in reply to jpanhalt)
       Post #: 283
RE: Opensource CDI ignition - 3/28/2009 11:11 AM
jpanhalt
Score: 100
Status: offline
Sorry about that. I interpreted that discussion to be about availability, not necessity for using electrolytics.
C3 is used for firing the SCR. I reverse engineered two commercial CDIs (a Chinese import and an RC Ignitions from the USA). Both used mylar/polyester. On the bench, I have used ceramic as well for that function. I can't see that a high esr would be any advantage in that application.
C7 is for the oscillator. The reverse engineered units used aluminum electrolytics, but they used much higher values of 1 or 10 uF. ESR might make a difference, but I am not so sure a lower ESR would be bad. A common, small tantalum at 0.1 uF would have an ESR of about 10 ohm (not low esr version), which is comparable to the esr of the larger electrolytics. Nichicon didn't list the esr of the 0.1 uF in the datasheet I had. By comparison to others, it probably has an esr of at least 10 ohm or as high as 100 ohm. That is just a rough calculation based on the inverse relationship of esr and capacitance given the same tan delta.
John
Hide Signatures
       Post #: 284
RE: Opensource CDI ignition - 3/28/2009 1:08 PM
Bigboat
Score: 100
Status: offline
If you are using a higher value to C7, the ocsilatrofrequentie will be lower.
If the ocsilatorfrequentie is lower, the load of C6 will be lower.
If C6 have a low loadfrequentie, the sparkintencie will be lower.
This CDI is made for high rpm (>25,000), the commecial CDI you can buy handles till <10,000 rpm.
You can change C3 into a 0.1 uF MKM capacitor opens theT1 gate for X-time.
But.....the time with a MKM will be shorter then when your using a aluminum electrolytic.
The spark will also be shorter, less spark, if the X-time you create is shorter.
But, it's a opensource project so you can change everything you like.
If you can make it better, be my gast
< Message edited by Bigboat -- 3/28/2009 1:10 PM >
Hide Signatures
       Post #: 285
RE: Opensource CDI ignition - 3/28/2009 1:46 PM
jpanhalt
Score: 100
Status: offline
Re:C3 An SCR gate will stay open until the current through the SCR drops below the holding current. Since that is not a GTO SCR, once fired, there is no control of the open time, except for that discharge period. Most datasheets for SCRs will give the firing criteria, which is generally something like a pulse with a minimum duration, voltage, and dA/dt (i.e., Vgt and Igt). The BT151 is characterized at a dI/dt of 5A/uS, which gives a turn-on time of 2 uS. I didn't study the datasheet that carefully, and there may be more data, but I did not see a minimum or maximum dI/dt for the gate. Consider a 0.1 uF capacitor with an esr of 100 ohm. The time constant for that alone is 10 uS. Using another capacitor with an esr of 10 ohm, which gives a minimum time constant of 1 uS should not affect the gate opening.
The point here is not to criticize or to redesign the circuit, but to find available components that can be substituted and will work. Even in the USA, I am not about to buy the minimum quantity of 0.1 uF aluminum electrolytic capacitors from DigiKey.
John
Hide Signatures
       Post #: 286
RE: Opensource CDI ignition - 3/28/2009 4:06 PM
Bigboat
Score: 100
Status: offline
quote:
ORIGINAL: jpanhalt
I don't think this is a point, over 100,000 people read the CDI topics and no one complains about the componets we have used.
We have try to use no exotic componets and for all componets are replacements to buy.
But again, it's a opensource project and if you can change the CDI in positive way be my gast.
If your designe will be better, I'm happy to place the designe on our website with your name on it.
Hide Signatures
       Post #: 287
RE: Opensource CDI ignition - 3/29/2009 10:40 AM
bluejets
Score: 100
Status: offline
Reference (above)... Oatley Electronics ..... Surplus fluro inverters for ferrite trigger transformer ($4.00) part No. CFLINV
Disassembled one unit to see what parameters were. It has an output winding of 380 turns 33awg. I removed a second unit and left the output winding and insulation in place and re-wound primary and feedback. Seems to work ok on testboard but not sure of effect on available energy to main capacitor. Getting around 500Vdc
Hide Signatures
       Post #: 288
RE: Opensource CDI ignition - 4/24/2009 9:31 PM
aerodactyl
Score: 100
Last Login: 11/5/2009
Status: offline
Hi guys,
I want to continue with my project and wanted to test the version with the LT3750. I received the parts already several weeks ago but had not time to study everything. The LT3750 is so small (10 lead MSOP Pack), no way to make a layout and develop the board at home Pin to pin distance is just 0.5 mm/0.0197".
Has anybody an idea how to handle this? There are adapter boards available but board + shipment will cost about 12.- EURO.
The flyback transformer is no problem. Its big enough.
Thanks for your comments.
Best regards from Germany
Uwe
< Message edited by aerodactyl -- 4/24/2009 9:32 PM >
Hide Signatures
       Post #: 289
RE: Opensource CDI ignition - 6/8/2009 9:40 PM
aerodactyl
Score: 100
Status: offline
Hi all,
I'm looking for useful spark plug cables for 1/4"32 spark plugs. The cables should be shielded and the isolator inside the metal housing should be silicon made. Any idea where to buy these cables? I found some in the US but these were not shielded and have no metal housing.
Salut
Uwe
Hide Signatures
(in reply to aerodactyl)
       Post #: 290
RE: Opensource CDI ignition - 8/27/2009 2:06 PM
wilkxt
Score: 100
Last Login: 8/31/2009
Status: offline
Hi   sorry for my english
I built my own CDI to motorbike 600cm, i use 1.5uF capacitor to strong spark, if i use 0,47uF capacitor voltage wil be higher and curent wil be less. Don't use converter when igniton coil is disconnected or add resistor obout 100kohm instead ignition coil
schem  http://www.ust.tke.pl/wilk/przet.JPG
This is mesure for  0,75uF cap and V=12V VCC
t [ms]   Vcap [V]    I[A]
8             400        0,45
7             400        0,75
6            400         0,8
5            380          0,9
4            340          1,0
3            330          0,95
2            280           0,90  2 ms = 500Hz = 30000 rot/min
1             210          0,85  1 ms = 1000Hz = 60000 rot/min
regard's
Hide Signatures
       Post #: 291
RE: Opensource CDI ignition - 8/27/2009 2:58 PM
Bigboat
Score: 100
Status: offline
It doesn't matter if the Voltage is high and te current is low or visa versa.
P= UxI, if P=constant, U can be high and I low or if U can be low and I high.
Hide Signatures
(in reply to wilkxt)
       Post #: 292
RE: Opensource CDI ignition - 8/28/2009 7:02 AM
wilkxt
Score: 100
Status: offline
Converter's curent wil be low (not capacitor) becouse less capacitor is faster charge and if capacitor achieve approximately 400V (or less if I chanage PR1, max converter's voltage) this converter go off and avarage curent wil be less.
Hide Signatures
       Post #: 293
RE: Opensource CDI ignition - 8/29/2009 2:50 PM
Nosedragger
Score: 100
Last Login: 11/21/2009
Status: online
quote:
ORIGINAL: bluejets
Ask for USPS Priority Mail flat rate shipping in the small flat rate box. its $12.95 USD anywhere in the world for package weight under 4 pounds.
Hide Signatures
       Post #: 294
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.672RCU1
