RE: Opensource CDI ignition
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: Opensource CDI ignition
Page: <<   < prev  3 4 5 [6] 7 8 9 10 11 12   next >   >>
Login
RE: Opensource CDI ignition - 4/2/2006 9:41 PM
Bigboat
Score: 100
Last Login: 11/19/2009
Status: offline
quote:
ORIGINAL: Bigboat
I have test today the CDI and find some problems.
Sometimes I missing a spark, sometimes a spark at the wrong time or to muts sparks at the same time.
It seems to me a EMC-problem in the pcb I use, the pic making (or not) his own sparks.
Also the energy for the capacitor is to small when the engine runs high rpm.
If I calculate the power I need (5 Watt), the capacitor must be ~4,7uF instead of 1uF.
Inside the cylinder the pressure is ~12bar on 4000 rpm, with this pressure there isn't a spark anymore.
Back to the drawingbord
Update, the diode in the powerline must be rotate 180 degrees.
This resolve the *lost spark* problem.
Test to 12.000 rpm (I can't higher with my electric motor) is no problem anymore.
_____________________________
CU, Rob - www.modelbouw.gompy.net
Hide Signatures
(in reply to Bigboat)
       Post #: 126
RE: Opensource CDI ignition - 4/13/2006 10:33 AM
wimmerma
Score: 100
Last Login: 1/11/2007
Status: offline
I don't know why but I've problems running the map423 calculation sheet. The addins are installed but it's not working anyway.
Can someone do this work for me before I'm going crazy? Or give me hints to get this sheet running...
My ignition is built for the Zenoah G260 PUM.
As described in the manual idle rpm is 3000rpm
advance timing is 30°/7000rpm
What advance timing values are you people using? I made some considerations about optimizing output of my G260PUM. What do you think?
-To start engine easily, advance timing at 0-2000 rpm should be 0°or even after TDC.
-max. rpm should be at 20.000rpm (=no rpm limiter)
Thanks for your replies
mit freundlichen Gruessen - best regards
Hide Signatures
       Post #: 127
RE: Opensource CDI ignition - 4/13/2006 11:00 AM
Bigboat
Score: 100
Status: offline
Map423 needs the hex2dec-file from Office, you have to install this option.
After install you have to click on all lines to activate the hex2dec.
You never get a engine start with a 0 or -0 TDC degree-angle.
Only if the engine is running, the degree-angle can be 0 TDC.
Normal engine (also PUM) have a max of 5 degrees TDC on hig rpm.
Start degree-angle must be ~30 degrees.
BTW, it's dangerous to set the degree-angle on start at 0 (or -0) degrees.
It's posible the explosion will be inside your carter and blow the carter up !!
Your ports will be opened after a few degrees when the piston goes down.
Hide Signatures
(in reply to wimmerma)
       Post #: 128
RE: Opensource CDI ignition - 5/16/2006 3:00 AM
Mitty
Score: 100
Last Login: 4/20/2009
Status: offline
I got a question...What method do you use to print and etch a pcb?
http://aviaportal.net is biggest online community of avitors.
Hide Signatures
       Post #: 129
RE: Opensource CDI ignition - 5/16/2006 3:21 AM
captinjohn
Score: 135
Last Login: 11/21/2009
Status: offline
I got a question. What does this ignition look like you guys are working on. The way it looks now.....in last experiments. Thanks Capt,n
I never met a engine I did not like!
Hide Signatures
(in reply to Mitty)
       Post #: 130
RE: Opensource CDI ignition - 5/16/2006 4:42 PM
Bigboat
Score: 100
Status: offline
Hide Signatures
(in reply to captinjohn)
       Post #: 131
RE: Opensource CDI ignition - 5/16/2006 4:49 PM
Bigboat
Score: 100
Status: offline
quote:
ORIGINAL: Mitty
Sorry, in dutch Etsingmachine
Use to translate
Hide Signatures
(in reply to Mitty)
       Post #: 132
RE: Opensource CDI ignition - 5/16/2006 11:44 PM
Mitty
Score: 100
Status: offline
What's that 6pin chip for? Is it a part of advance or part of HV circuit?
Is schematic on the http://www.modelbouw.gompy.net/cdi/cdi.htm working or you already changed it ? Which program should i burn in the chip :Zenoah 2.hex?What if i want to change advance settings?Which spreadsheet do i use then?
I hope not too many questions..I read all the info on cdi i could find and got so excited..I am ready to jump on a project.
Bigboat please advice!
Mitty
quote:
ORIGINAL: Bigboat
< Message edited by Mitty -- 5/17/2006 12:46 AM >
Hide Signatures
       Post #: 133
RE: Opensource CDI ignition - 5/17/2006 1:24 AM
jmj
Score: 100
Last Login: 10/22/2009
Status: offline
This is a new version of the CDI. The PIC is changed to a 16F628, and will be changed to a 16F88 soon.
The 16F88 is the best 16X PIC yet, lots of new possibillities, and an internal osc at 8 Mhz.
The 16F84 is outdated, and i guess we will not work more on the code for it.
The code is totally rewritten, and is now in C, and there is a new Excel sheet to manipulate the curve.
Nothing of this is released on the net yet, as it is still very much under construction.
The code works, and has been run on a real engine, but there are some bugs yet.
The hardware is also modified (by Bigboat), and under construction, but the new code/PIC16F88 will work on the old hardware with some modifications.
When this will be released is not decided yet, we have done a lot of work on the new CDI in the last month, but right now we have a little break...
For now, use the old code and the old schematics.
Hide Signatures
(in reply to Mitty)
       Post #: 134
RE: Opensource CDI ignition - 5/17/2006 2:51 AM
Mitty
Score: 100
Status: offline
You mean old code from transmic design? Thats where excell sheet with curves and source is?I ,so as a few others can't get excel sheet to work.Even though addins are all installed i still ger an error messages.Please anybody help
Thanks alot for advice!
Mitty
quote:
ORIGINAL: jmj
< Message edited by Mitty -- 5/17/2006 4:07 AM >
Hide Signatures
(in reply to jmj)
       Post #: 135
RE: Opensource CDI ignition - 5/17/2006 11:46 AM
lumpylumpy
Score: 100
Last Login: 6/20/2007
Status: offline
Hi,i had problems with the exel sheets too,have instaled office severel times,instaled all addins and still not worked! then i did a little research and found out that there is a little error in the formulas calculating the lines for the asm. ; this is how it should loke like =IF(B16<$D$8,CONCATENATE(" ",$E$14,DEC2HEX(D16),$E$15,$A$142,ROUND(D16/10,1),$A$149,INT(B16),$B$14))
and this is how it loked originaly =IF(B40<$D$8,IF(D40>10,CONCATENATE(" ",$E$14,DECHEX(D40,2),$E$15,$A$142,TRUNC(D40/10,1),$A$149,INT(B40),$B$14),CONCATENATE(" ",$E$14,DECHEX(D40),$E$15,$A$142,ROUND(D40/10,1),$A$149,INT(B40),$B$14)),$E$16)
i have deleted a portion of the formula,and where it writes dechex i have replaced it with de2hex,as you could notice in the formula! you have to have the next addins instelled:anallysis toll pack and solver add-in!!!!!!!
you copy the formula in to the first line off the exel (cell e16) and press enter;after that copy/paste on each line until finsh(do not paste severel lines at once, one line at a time so you dont have to modify the formula!!!!)
this is made for the exel map 42 ;you can do the same with the other exel maps,but the formulas not the same! so be careful what you delete from the formula!!!
I hope it helps you,and i did not write it two complicated!I am not so good at english.
rpm adv. nr loops lines to insert into asm.
1,010 6.0 50 retlw 31h ;5ms 1010rpm 1,010 6.0
1,017 6.3 49 retlw 30h ;4.9ms 1016rpm 1,017 6.3
1,024 6.5 48 retlw 2Fh ;4.8ms 1023rpm 1,024 6.5
1,031 6.8 47 retlw 2Fh ;4.7ms 1030rpm 1,031 6.8
1,038 7.0 46 retlw 2Eh ;4.6ms 1038rpm 1,038 7.0
1,045 7.3 46 retlw 2Dh ;4.6ms 1045rpm 1,045 7.3
1,053 7.6 45 retlw 2Dh ;4.5ms 1052rpm 1,053 7.6
this is how it should look like.
Regard ,Zoli.
Hide Signatures
(in reply to Mitty)
       Post #: 136
RE: Opensource CDI ignition - 5/17/2006 12:15 PM
Bigboat
Score: 100
Status: offline
The 6 pin chip is a optocoupler placed between HV and advance to eliminate interferance from the HV.
All schematics on the site are working.
It depent wat hex-file you will use, the Zenoah-file ingrease the ignition......not all engine love this.
The best way to use the timingtable is, start with all settings on zero (no delay)
If your cdi is working, start with a small delay (1msec) for the complete table.
If everything goes fine, make your own table for your engine.
BTW, most normale engines have a degrease table (ignitionpoint + x-degrees)
Wait untill we (JMJ and I) are ready with the new cdi.
I put everything online if we are ready and will post the link here on the msgboard.
Hide Signatures
(in reply to Mitty)
       Post #: 137
RE: Opensource CDI ignition - 5/25/2006 2:04 AM
Mitty
Score: 100
Status: offline
guys,
where do you order a rare earth magnets of needed size?I assume it's a 1/4 inch round? What's the part number from digikey ? I saw it on the forum somewhere but can't find it
Please someone help
Hide Signatures
       Post #: 138
RE: Opensource CDI ignition - 5/25/2006 11:09 AM
Bigboat
Score: 100
Status: offline
Magnetshop
Hide Signatures
(in reply to Mitty)
       Post #: 139
RE: Opensource CDI ignition - 6/9/2006 2:39 PM
Bigboat
Score: 100
Status: offline
For those who don't have see the new TOPIC, here is the link to the New CDI JMJ and I have make.
< Message edited by Bigboat -- 6/9/2006 2:41 PM >
Hide Signatures
       Post #: 140
RE: Opensource CDI ignition - 6/9/2006 5:40 PM
Antique
Score: 105
Last Login: 11/20/2009
Status: offline
Your computer has a search forum called Google...There are more magnet sources there than you will ever need....All you gotta do is go there....One of the first entries shows magnets for $7.99 per 100...Perfect size, very small and made from the strongest magnetic material in the world...
Hide Signatures
(in reply to Mitty)
       Post #: 141
RE: Opensource CDI ignition - 6/11/2006 10:39 PM
lumpylumpy
Score: 100
Status: offline
Hi,i have a question to Bigboat: is it posible to use pin 10 from pic16f628 as a reverse output?
To use it for a TCI ignition?
Or is it for the pick-up signal?like a test led for pickup?
Regards,Lumpy
Hide Signatures
(in reply to Antique)
       Post #: 142
RE: Opensource CDI ignition - 6/11/2006 10:52 PM
Bigboat
Score: 100
Status: offline
Pin 10 is using for a flashlight to test where the ignition will take place.
The flash will taken place at the same time as the spark.
Pin 6 is high and go to ground for the spark, pin 10 is low and will be high for flash.
Hide Signatures
(in reply to lumpylumpy)
       Post #: 143
RE: Opensource CDI ignition - 6/12/2006 8:39 PM
Bigboat
Score: 100
Status: offline
Programfiles now including testfunction.
You can test your cdi without mounting the hallsensor on a rotating engine.
With two jumpers you can generate 300 or 7500 sparks / minute.
Please see "Config-file Micro-C (ZIP-JPG)" to setup Micro_C.
Hide Signatures
       Post #: 144
RE: Opensource CDI ignition - 6/24/2006 7:07 AM
jirvin
Score: 100
Last Login: 11/18/2009
Status: offline
E-Coil wind?
quote:
ORIGINAL: Ben_C
My high voltage coil is wound on an E-core. I would rather spend $200 on a professional CDI than wind another toroid coil! The E-core coil only took about 20 minutes to wind.
Ben
Hi intersted in having a go at building this CDI for a Ryobi whipper Snipper
I too find the idea of winding a toroidal intimidating!
I have been looking for a tutorial on how to wind a E-Core?
Closest so far is this-
http://www.repairfaq.org/sam/jshidbal.htm
Anybody have links or pictures on how to do an E-Coil wind?
cheers jeff
A walk through on programming a pic would be good also (my wsishlist)
Hide Signatures
(in reply to Ben_C)
       Post #: 145
RE: Opensource CDI ignition - 11/10/2006 12:47 PM
lumpylumpy
Score: 100
Status: offline
HI,how can i use an inductive pickup to trriger the pic (pin 7 on 16f628)?tried many things but did not work,i am thinkink through an optocoupler ,but how must pin 7 bee? high or low? Regards ,Lumpy
Hide Signatures
(in reply to jirvin)
       Post #: 146
RE: Opensource CDI ignition - 11/10/2006 4:04 PM
Bigboat
Score: 100
Status: offline
High to ignite.
Hide Signatures
       Post #: 147
RE: Opensource CDI ignition - 11/15/2006 4:15 AM
hogboy
Score: 100
Last Login: 12/13/2006
Status: offline
Hi all,
I've downloaded the schematics and pcb layouts from the GOMPY site and constructed it. CDI works well on the bench in test hi and lo modes and with magnet mounted to an electric flywheel the hall sensor fires the circuit well also. Can any one help though with the rotten excel spreadsheet. I've done everything as listed on this post regarding the ADD INNS for excel and still get the DEC@HEX macro problem. I would now like to be able to manipulate the advance curves but can't until I can get spreadsheet working. Also better way of contructing transformer is to use a split ferrite core and bobbin. Wind on 16meters of .2mm, 20 turns of .5mm and 10 turns of .2mm. Look forward to any positive responses to excel problem.
Click to see fullsize image.
Click for fullsize
Click for fullsize
AUS Hogboy
Hide Signatures
(in reply to jmj)
       Post #: 148
RE: Opensource CDI ignition - 11/15/2006 5:36 PM
Bigboat
Score: 100
Status: offline
Wat spreadsheet do you use.....?
Not this one, http://home.online.no/~jon-mj/Download/Source1.asm
You have modify the timetable by hand.
Hide Signatures
(in reply to hogboy)
       Post #: 149
RE: Opensource CDI ignition - 11/21/2006 9:03 AM
insane_x97
Score: 100
Last Login: 3/18/2007
Status: offline
hi there.
this is my first post but this thread realy helpd me a lot .
i am planing to make a msd(multi spark discharge) type cdi .
can a brain here suggest some better circuit which uses battry (12v)and makes enough volts as well as amps which could drive a big ignition coil.
Sorry for my poor english..
Hide Signatures
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.063RCU1
