RE: Opensource CDI ignition
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: Opensource CDI ignition
Page: <<   < prev  3 4 5 6 [7] 8 9 10 11 12   next >   >>
Login
RE: Opensource CDI ignition - 12/13/2006 10:59 AM
Maku
Score: 100
Last Login: 6/28/2007
Status: offline
quote:
ORIGINAL: hogboy
Hi all,
I've downloaded the schematics and pcb layouts from the GOMPY site and constructed it. CDI works well on the bench in test hi and lo modes and with magnet mounted to an electric flywheel the hall sensor fires the circuit well also. Can any one help though with the rotten excel spreadsheet. I've done everything as listed on this post regarding the ADD INNS for excel and still get the DEC@HEX macro problem. I would now like to be able to manipulate the advance curves but can't until I can get spreadsheet working. Also better way of contructing transformer is to use a split ferrite core and bobbin. Wind on 16meters of .2mm, 20 turns of .5mm and 10 turns of .2mm. Look forward to any positive responses to excel problem.
Hi hogboy,
I am also new to this forum and trying to build the CDI too. The excel sheet has an error on the command DEC to HEX. The solution from lumpylumpy is given below.
Could you give some more information on your Transformer, and some specs on the core (core size, type, producer etc)??
Maku.
Hi,i had problems with the exel sheets too,have instaled office severel times,instaled all addins and still not worked! then i did a little research and found out that there is a little error in the formulas calculating the lines for the asm. ; this is how it should loke like =IF(B16<$D$8,CONCATENATE(" ",$E$14,DEC2HEX(D16),$E$15,$A$142,ROUND(D16/10,1),$A$149,INT(B16),$B$14))
and this is how it loked originaly =IF(B40<$D$8,IF(D40>10,CONCATENATE(" ",$E$14,DECHEX(D40,2),$E$15,$A$142,TRUNC(D40/10,1),$A$149,INT(B40),$B$14),CONCATENATE(" ",$E$14,DECHEX(D40),$E$15,$A$142,ROUND(D40/10,1),$A$149,INT(B40),$B$14)),$E$16)
i have deleted a portion of the formula,and where it writes dechex i have replaced it with de2hex,as you could notice in the formula! you have to have the next addins instelled:anallysis toll pack and solver add-in!!!!!!!
you copy the formula in to the first line off the exel (cell e16) and press enter;after that copy/paste on each line until finsh(do not paste severel lines at once, one line at a time so you dont have to modify the formula!!!!)
this is made for the exel map 42 ;you can do the same with the other exel maps,but the formulas not the same! so be careful what you delete from the formula!!!
I hope it helps you,and i did not write it two complicated!I am not so good at english.
rpm adv. nr loops lines to insert into asm.
1,010 6.0 50 retlw 31h ;5ms 1010rpm 1,010 6.0
1,017 6.3 49 retlw 30h ;4.9ms 1016rpm 1,017 6.3
1,024 6.5 48 retlw 2Fh ;4.8ms 1023rpm 1,024 6.5
1,031 6.8 47 retlw 2Fh ;4.7ms 1030rpm 1,031 6.8
1,038 7.0 46 retlw 2Eh ;4.6ms 1038rpm 1,038 7.0
1,045 7.3 46 retlw 2Dh ;4.6ms 1045rpm 1,045 7.3
1,053 7.6 45 retlw 2Dh ;4.5ms 1052rpm 1,053 7.6
this is how it should look like.
Regard ,Zoli.
Hide Signatures
(in reply to hogboy)
       Post #: 151
RE: Opensource CDI ignition - 12/16/2006 8:18 AM
KI8FR
Score: 100
Last Login: 11/2/2009
Status: offline
It is a good thing some one know how to read that. lol....
I was thinking of trying to make me one but as I read on I does not look to be a ez thing to do..
I will have to do some more reading.
Paul
Hide Signatures
(in reply to Maku)
       Post #: 152
RE: Opensource CDI ignition - 12/22/2006 12:00 AM
acgeorge
Score: 100
Last Login: 12/10/2008
Status: offline
Looks like the CDI's are finally becoming available. BCMA has them for $85 w/auto advance.
BCMA
Hide Signatures
(in reply to KI8FR)
       Post #: 153
RE: Opensource CDI ignition - 12/22/2006 1:15 AM
jpanhalt
Score: 100
Last Login: 11/6/2009
Status: offline
Can any of the commercial units be user programmed? Thanks. John
Hide Signatures
(in reply to acgeorge)
       Post #: 154
RE: Opensource CDI ignition - 12/22/2006 3:50 AM
RysiuM
Score: 100
Last Login: 11/18/2009
Status: offline
quote:
ORIGINAL: acgeorge
Reading instruction I found funny thing (maybe it is not quite funny, but plain wrong).
quote:
...If you run electronic ignition Radio Interference is always a possibility. If you encounter this problem here are some ways to help reduce or eliminate this problem....
If you are still experiencing problems, here are some more extreme measures:
· Wrap your ignition module with Aluminum Foil.
· If your ignition module is mounted on your firewall, apply HVAC foil ducting tape to the firewall.
· If your ignition module is inside a compartment, line the compartment with either Aluminum foil or HVAC foil ducting tape.
· Upgrade to a PCM type radio system.
The last "extreme" is a real hardcore. The most stupid thing would be masking interference by using PCM.
< Message edited by RysiuM -- 12/22/2006 3:51 AM >
_____________________________
Mather Aerospace Modelers, Inc. AMA Gold Leader Club, Charter #1243, Sacramento, CA
Visit us at www.masmrc.com
Hide Signatures
       Post #: 155
RE: Opensource CDI ignition - 12/22/2006 3:59 AM
captinjohn
Score: 135
Last Login: 11/21/2009
Status: offline
Forget the...PCM...Get a Spectrum spread 7 channel Radio and give that a try! Capt,n
I never met a engine I did not like!
Hide Signatures
(in reply to RysiuM)
       Post #: 156
RE: Opensource CDI ignition - 12/27/2006 12:02 AM
PilotTiger
Score: 100
Last Login: 2/25/2009
Status: offline
BigBoat, is it possible that you have an error on your web page and that when one clicks on the incircuitprogramming the small pcb layout comes up?
Yoram
Fly fast drive slow!!
Yup, that's me.
Hide Signatures
(in reply to captinjohn)
       Post #: 157
RE: Opensource CDI ignition - 12/27/2006 11:16 AM
Bigboat
Score: 100
Last Login: 11/19/2009
Status: offline
I don't know, wat pic do you mean ?
This one is the incircuitprogramming
And this one not
< Message edited by Bigboat -- 12/27/2006 12:52 PM >
CU, Rob - www.modelbouw.gompy.net
Hide Signatures
(in reply to PilotTiger)
       Post #: 158
RE: Opensource CDI ignition - 12/27/2006 11:33 AM
PilotTiger
Score: 100
Status: offline
BigBoat, if you go to your page http://www.modelbouw.gompy.net/cdi/cdi.htm the "Layout small PCB" and the "Layout small PCB for incircuitprogramming" comes up the same. Didn't you had a layout for a programmer or was it only a figment of my imagination? I don't mean the link to a programmer that you have on the new cdi page.
Yoram
Yup, that's me.
Hide Signatures
(in reply to Bigboat)
       Post #: 159
RE: Opensource CDI ignition - 12/27/2006 11:39 AM
PilotTiger
Score: 100
Status: offline
Also, in the new cdi, if I don't want the flash, I can take out the transistor too, right?
Yup, that's me.
Hide Signatures
       Post #: 160
RE: Opensource CDI ignition - 12/27/2006 11:41 AM
Bigboat
Score: 100
Status: offline
Both pcb's looks the same, but the pins are differend to the 16f84.
Hide Signatures
       Post #: 161
RE: Opensource CDI ignition - 12/27/2006 11:43 AM
Bigboat
Score: 100
Status: offline
You can take out the transistor, but it's very handy to use for timing the engine.
Hide Signatures
       Post #: 162
RE: Opensource CDI ignition - 12/30/2006 5:44 PM
KI8FR
Score: 100
Status: offline
I was not able to find any thing in this form on the fly weel.. what do I have to do about a fly weel.
Hide Signatures
       Post #: 163
RE: Opensource CDI ignition - 12/30/2006 5:59 PM
Bigboat
Score: 100
Status: offline
Nothing.....you don't need it anymore if you gone use a prop.
You have to put somewhere a small magnet, but not into the flywheel becourse he is magnetic too.
The hallsensor must be placed about 40 degrease BTDC.
Hide Signatures
(in reply to KI8FR)
       Post #: 164
RE: Opensource CDI ignition - 12/30/2006 7:40 PM
KI8FR
Score: 100
Status: offline
one of the things Im trying to do is take off the big fly wheel.. It will not fit under the cowl I was thinking of training the fly wheel down and put the magnet in it. I just do not know if I will have probs with it if I do that..
Hide Signatures
       Post #: 165
RE: Opensource CDI ignition - 12/30/2006 8:02 PM
Bigboat
Score: 100
Status: offline
The flywheel is not only for the ignition, but it helps also the engine a littlebit with the rotation.
The crank only itn't enough to let spin the engine, he needs also the (rotation) weight of the flywheel.
The prop is taken over the (rotation) function of the flywheel.
Hide Signatures
(in reply to KI8FR)
       Post #: 166
RE: Opensource CDI ignition - 12/30/2006 8:06 PM
KI8FR
Score: 100
Status: offline
Ok so your saying that I do not need the fly wheel cuz the prop will do the work?
Hide Signatures
       Post #: 167
RE: Opensource CDI ignition - 12/30/2006 10:23 PM
captinjohn
Score: 135
Status: offline
What I do is use a hole cutter in a drill press and cut out the center of the flywheel. Takes only about 3 min. Then I take and place the center of the flywheel and place it on a mandrel in metal lathe and cut to shape. You can add your magnet for the pick-up in a small hole drilled in hub. Good Luck......Capt,n
Hide Signatures
(in reply to KI8FR)
       Post #: 168
RE: Opensource CDI ignition - 12/30/2006 10:42 PM
KI8FR
Score: 100
Status: offline
Now that is the info I was looking for... I have not make a cdi yet Im still in the studding part of it.. It does not look that hard to do but well you know how it is lol
Paul
Hide Signatures
       Post #: 169
RE: Opensource CDI ignition - 1/9/2007 3:48 PM
epilot
Score: 100
Last Login: 3/8/2007
Status: offline
I have all the components, now I just need to etch the PCB and wind the coils. I agree that winding a toroid is a royal pain in the behind. Does anyone have a source for E cores and coil formers? I have a CNC coil winder so as long as I can get a hold of the formers, winding is a breeze. Maplins in the UK sell Velleman kits but NOT the FLPS
Michael
Hide Signatures
(in reply to KI8FR)
       Post #: 170
RE: Opensource CDI ignition - 2/9/2007 1:40 PM
panyasx
Score: 100
Last Login: 2/21/2008
Status: offline
quote:
Hide Signatures
       Post #: 171
RE: Opensource CDI ignition - 3/5/2007 12:29 AM
derek4210
Score: 100
Last Login: 11/20/2009
Status: offline
All you that are building the CDI please post on how well your engine runs. Also anybody who is interested, I slightly redesigned the above CDI project. I am using the TI MSP-430 micro-controller IC. This is so much easier to control your auto advance. Just a P.C /laptop w/USB port running hyperterminal allows you to change your auto advance timing settings in Flash Memory. Also there are no limits on what else you can dream up.
Derek.
Hide Signatures
(in reply to panyasx)
       Post #: 172
RE: Opensource CDI ignition - 3/5/2007 1:09 AM
jpanhalt
Score: 100
Status: offline
Derek4210,
Can you post the code for that microcontroller? I am a relative newbie with PIC and have no experience with the TI product. I also live pretty close to you. PM, if you want to discuss.
John
< Message edited by jpanhalt -- 3/5/2007 1:11 AM >
Hide Signatures
(in reply to derek4210)
       Post #: 173
RE: Opensource CDI ignition - 3/5/2007 12:11 PM
dinoslmn
Score: 100
Status: offline
Try following link. I received 3 pcs two weeks ago. $5.99 / each
http://www.hobbyengineering.com/H1958.html
Dino,
Israel
Hide Signatures
(in reply to epilot)
       Post #: 174
RE: Opensource CDI ignition - 3/5/2007 4:13 PM
Bigboat
Score: 100
Status: offline
Beware........not all coils can handle the high rpm......you need >15.000 rpm for a stock Zenoah.
Only weedeathers running slowly until 10.000 rpm.
Hide Signatures
(in reply to dinoslmn)
       Post #: 175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.531RCU1
