RE: Opensource CDI ignition
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
RCGF 100CC Gas Engine (Side Intake CNC Crank Case)
Seller:  Furyflyer2
Details:   $699.99   |  11/6/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> RE: Opensource CDI ignition
Page: <<   < prev  3 4 5 6 7 [8] 9 10 11 12   next >   >>
Login
RE: Opensource CDI ignition - 4/9/2007 12:07 AM
KI8FR
Score: 100
Last Login: 11/2/2009
Status: offline
What do you use for the Hall Sensors?
Hide Signatures
(in reply to Bigboat)
       Post #: 176
RE: Opensource CDI ignition - 4/9/2007 12:17 AM
Bigboat
Score: 100
Last Login: 11/19/2009
Status: offline
Any uni-polair hallsensor can do the job.
TLE 49xx, H501, HAL506PA
_____________________________
CU, Rob - www.modelbouw.gompy.net
Hide Signatures
(in reply to KI8FR)
       Post #: 177
RE: Opensource CDI ignition - 4/10/2007 6:51 AM
KI8FR
Score: 100
Status: offline
There was a post on here about a part # at Radio Shack for the magnet. Does any one rember that part #?
Hide Signatures
       Post #: 178
RE: Opensource CDI ignition - 4/10/2007 7:14 AM
KI8FR
Score: 100
Status: offline
I got it sorry it was (Radio Shack, item number 64-1895)
Hide Signatures
(in reply to KI8FR)
       Post #: 179
RE: Opensource CDI ignition - 4/16/2007 12:42 AM
KI8FR
Score: 100
Status: offline
What is a good way to fason the hallsensor to the hallsenser mount. and what is a good way to fasen the magnet in the fly wheel.. I have the hallsenser mount made and i have the fly wheel made.. now I need to know a good way to fasen them in.. I was thinking of useing epoxey or jb weld..
Sorry I do not spell good..
Paul
Hide Signatures
(in reply to KI8FR)
       Post #: 180
RE: Opensource CDI ignition - 4/28/2007 7:01 AM
venomxx
Score: 100
Last Login: 6/20/2009
Status: offline
someone post some nice pics of the CDI unit on here
Hide Signatures
(in reply to KI8FR)
       Post #: 181
RE: Opensource CDI ignition - 4/28/2007 7:42 AM
venomxx
Score: 100
Status: offline
This may sound funny but how do you start the engine with this CDI ?
Is it possible to have a push-button start ?
Hide Signatures
(in reply to venomxx)
       Post #: 182
RE: Opensource CDI ignition - 7/29/2007 8:36 AM
sparkyone
Score: 100
Last Login: 10/2/2007
Status: offline
Hello Big Boat
I am a first time person to this forum. I congratulate you and your parteners in this project. It is nice to see someone share the knowledge they have gained over the years with other people. Well Done.
I have built the small rc board and had it working for one hour ok. I also built the first board design with problem in the timming circuit.
I used the small board to check voltages and it to stopped. Both boards are ok on the high voltage. The problem is the trigger voltage from the pic output pin six. Im only getting .07 volts out max ,the thyristor needs aprox 5volt on the gate. It is the same for both boards. Can you Help with this problem and what would limit the output from the pic.
best regards to all
sparkyone
Hide Signatures
       Post #: 183
RE: Opensource CDI ignition - 7/29/2007 11:45 AM
jpanhalt
Score: 100
Last Login: 11/6/2009
Status: offline
quote:
ORIGINAL: sparkyone
The problem is the trigger voltage from the pic output pin six. Im only getting .07 volts out max ,the thyristor needs aprox 5volt on the gate. It is the same for both boards. sparkyone
Hi Sparky,
I have a very similar system working. The main difference is that I use an NPN instead of PNP transistor with appropriate other modifications. The SCR/thyristor trigger is basically the same. Can you provide a little more information about the voltage that you see on the trigger?
How did you measure it? It is a short pulse at the SCR pin, and you need a scope to measure it.
Have you isolated the trigger circuit (i.e., the RC part) from the chip and looked at only the output from microcontroller? Again, you will need a scope for that. That test is to be sure the micro is programmed and working properly.
John
Hide Signatures
(in reply to sparkyone)
       Post #: 184
RE: Opensource CDI ignition - 7/30/2007 10:09 AM
sparkyone
Score: 100
Status: offline
Hello John
Thankyou for your reply. I have found that the 22nf caps I had purchased was labled wrong. They were in fact 2nf.
I changed the cap for 22nf and now have 4.5v measured with a cro.
I have 275v output on the small board to the ht coil as measured with a multimeter, but no sparks.
Also the older board has the same problem. This I checked with the same ht coil so I think I will wind another ht coil and see how that works. Again thankyou.
regards sparkyone
Hide Signatures
(in reply to jpanhalt)
       Post #: 185
RE: Opensource CDI ignition - 7/30/2007 10:19 AM
Bigboat
Score: 100
Status: offline
Buy yourself a transformer, most handmake transformers don't work very long.
The CD45 looklike the best, low input - high output
http://www.amazing1.com/transformers.htm
High Voltage Pulse and Trigger Transformers
These high voltage pulse transformers supply the voltage pulses used for igniters, shockers, stun guns and triggers for laser flash tubes and high power spark switches. They are used with capacitor discharge circuitry where a capacitor is charged and then allowed to discharge into the primary where a high voltage pulse is generated in the secondary output winding. The high voltage output pin is isolated with connection leads on the opposite end. 25KV output at .5 JOULES. Use a 300 volt 1 mfd capacitor with sidac trigger for line direct operation or conventional inverter with SCR. 1" round by 1.25" long in fully potted enclosure.
Quantity
CD25B - Transformer.............$16.95
10-99 @ $9.95ea. 100-999 @ $5.95ea. 1000-4999 @ $2.95ea. 5000+ @ $1.95ea.
45KV output at .5 JOULES. 1.25" round by 1.25" long in fully potted enclosure.
CD45 - Transformer...............$18.95
Hide Signatures
       Post #: 186
RE: Opensource CDI ignition - 8/21/2007 10:58 AM
acus
Score: 100
Last Login: 8/27/2007
Status: offline
@bigboat can u helpme i don't understand about timing the ignition...
i have motorcycle 4 stroke automatic max power 8,000 rpm ...
i want to build cdi to boost engine over 8000 rpm... atleast 10,000rpm or 16,000rpm can i do that?
can u give explanation how to setting up the ignition timing for my engine..?
which one circuit do i use for that?
sorry for my bad english languange...
Hide Signatures
       Post #: 187
RE: Opensource CDI ignition - 8/21/2007 1:19 PM
captinjohn
Score: 135
Last Login: 11/21/2009
Status: offline
I am not bigboat...but timing alone is not going to give that engine 2000 or 4000 more RPM. You need to do many engine mods to get much higer RPM. By then your engine will not last long. A timing curve is to help the engine run smooth at all RPM. Mostlly at idle and as you go from above idle. Capt,n
I never met a engine I did not like!
Hide Signatures
(in reply to acus)
       Post #: 188
RE: Opensource CDI ignition - 8/21/2007 3:53 PM
acus
Score: 100
Status: offline
thanks for reply captinjohn.. .
and how to make timing curve for engine run smoothly at all RPM...
Hide Signatures
(in reply to captinjohn)
       Post #: 189
RE: Opensource CDI ignition - 6/19/2008 2:29 PM
Futterama
Score: 100
Last Login: 11/17/2009
Status: offline
So did anyone ever fully complete this project?
I'm very interested in building my own, the problem is the high voltage circuit, I don't know a whole lot about high voltage but I do know lots of PIC's and programming them.
Hide Signatures
(in reply to acus)
       Post #: 190
RE: Opensource CDI ignition - 6/19/2008 7:32 PM
Bigboat
Score: 100
Status: offline
A lot of people visit my site and the (new) cdi is number one in the ranklist.
Top 100 (of 12955) Referrers
[Hits / Referring URL]
71983 www.modelbouw.gompy.net/
68196 -
23815 www.modelbouw.gompy.net/cdi/cdi.htm
23635 www.modelbouw.gompy.net/newcdi/newcdi.htm
22962 www.modelbouw.gompy.net/wild_thing/wild.htm
I was also hope some people let us know how there projects be ending.
CU, Rob
Hide Signatures
(in reply to Futterama)
       Post #: 191
RE: Opensource CDI ignition - 6/19/2008 8:18 PM
Futterama
Score: 100
Status: offline
Bigboat, when I read about the "New CDI" on your website, I'm missing information about the bobine and the rewinding of the FLPS-1 transformer.
Hide Signatures
       Post #: 192
RE: Opensource CDI ignition - 6/19/2008 10:22 PM
Bigboat
Score: 100
Status: offline
Every (small) bobine can be used, mopeds - weedeathers, but also the grey Zenoah-coil can be used.
The HV-coil (FLPS-1) must be wind like the ring-coil, 400 - 8 - 16 wdg
Hide Signatures
       Post #: 193
RE: Opensource CDI ignition - 6/20/2008 7:14 AM
Futterama
Score: 100
Status: offline
The bobine will have to have that extra input for shorting the magnetic field to stop the engine, right? And then we use that input to put in the voltage from the HV coil to generate the spark, am I correct?
The grey Zenoah coil, is that this one:
It seems black to me so I'm not sure. This is the one for Zenoah/CY engines used on largescale cars (FG, HPI Baja, MCD). The Zenoah engines are called G230RC and G260RC.
The windings for the FLPS1 should be 0.2mm???
If you can answer all my questions I will seriously build this project and adapt it to a Zenoah G260RC and I will ofcource post all about it here
< Message edited by Futterama -- 6/20/2008 7:45 AM >
Hide Signatures
       Post #: 194
RE: Opensource CDI ignition - 6/20/2008 4:59 PM
Bigboat
Score: 100
Status: offline
The picture you show is a electro-magnetic-coil, not a bobine.
A bobine don't have iron ends to follow the magnet of the flywheel.
Your coil need the magnbetic of the flywheel to generate the HV.
If your using a CDI-ignition, you don't need the flywheel anymore.
Hide Signatures
       Post #: 195
RE: Opensource CDI ignition - 6/24/2008 10:32 AM
Futterama
Score: 100
Status: offline
I ordered the gray Zenoah coil, it will arrive in a few weeks.
I have a question about the high voltage circuit: Is there a special reason why T1 is a thyristor and not e.g. a MOSFET?
Is it because the PIC gives a short trigger pulse to T1 and T1 will conduct only until the bobine will give a burst of flyback voltage? So the thyristor will shut down automatically when all the energy from the capacitor has been released?
I also have a question about the rewinding of the FLPS1 E-core: is it possible to disassemble the E-core so it's easy to wind the copperwire? I think it is possible to disassembly the E-core on the middle so you end up with 2 E's. But that does not make it much easier to wind. How did you (Bigboat) do it?
I'm thinking something like make a stick the same size and shape as the inner of the E-core, and put some paper and tape around it, and then wind the copperwire onto the stick/paper/tape, and then transfer the finished windings with paper and tape to the E-core and reassemble it. But I don't know if this would make a good transformer...
Hide Signatures
       Post #: 196
RE: Opensource CDI ignition - 6/30/2008 12:38 AM
Bigboat
Score: 100
Status: offline
We don't try a FET (to expencive and not anywhere to buy), but maybe it's possible to use.
I *cut* the E-core with a sharp nife just at the outside an clue it together with superclue when I'm ready to rewinde the coil.
I don't use paper between the winds, the wire-isolation it selfs is enough.
Hide Signatures
       Post #: 197
RE: Opensource CDI ignition - 6/30/2008 4:55 PM
RunningMan
Score: 100
Status: offline
If you use a mosfet or something like that, you have to know when to shut it off. The SCR does that all by itself.
Steve
Hide Signatures
       Post #: 198
RE: Opensource CDI ignition - 6/30/2008 5:12 PM
Bigboat
Score: 100
Status: offline
Uhhh.....we talking about the transistor for the E-core not the SCR for the ignitioncoil
Hide Signatures
(in reply to RunningMan)
       Post #: 199
RE: Opensource CDI ignition - 6/30/2008 8:13 PM
Futterama
Score: 100
Status: offline
quote:
ORIGINAL: Futterama
When looking at the schematic, there should be no doubt of what I'm talking about when I say T1.
Click to see fullsize image.
Click for fullsize
< Message edited by Futterama -- 7/1/2008 9:47 AM >
Hide Signatures
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.719RCU1
