toprudder
NC, USA Status: offline
quote:
ORIGINAL: jlkonn Just back from Radio Shack. I am the proud owner of a new digital multimeter. John was right...the old meter is off. The new meter reads 12.92 volts on the battery. 15.68 volts on the charger without it being connected to the battery. Too high right? What's that potiometer do on my charger in the picture? JLK I suspect the pot is to adjust the voltage. Sometimes a fixed voltage regulator is made into a variable voltage regulator by putting a pot in the feedback circuit. If I remember the pinout of the 7805, the left leg is input, the middle leg is reference (usually 0v or ground) and the right leg is the output. If the pot is used to adjust the voltage, the middle leg of the 7805 will be tied to the wiper of the pot, one leg of the pot will be tied to 0v, and the other leg of the pot will be tied to the output of the 7805 (probably through a resistor). Is this charger intended to be used only for lead-acid batteries? The reason I ask is that if it is intended for Nicads, the regulator is probably wired to act as a constant-current source. Not good for lead-acid batteries. It would be wired differently if that were the case. I have a regulated, variable power supply that I built when I first got into electronics. I set it to 13.6v and connect it to my 12v battery to charge it. The regulator that I used (317) has current limiting built into it, something like 1.5 amps. If the battery is really low, it will start at 1.5 amps but by the time the battery is charged the current will be less than 100ma. John, you are right, the range is small and a good meter is needed. I tend to be too frugal sometimes. It was hard for me to throw away an old analog meter that was 30 years old, even though a few ranges did not work any more. Bob R.
