RE: Field Stand
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> RE: Field Stand
Page: <<   < prev  1 2 3 4 5 [6] 7 8   next >   >>
Login
RE: Field Stand - 2/1/2006 3:12:20 PM
grinder-RCU
Status: offline
ec121connie I sent you an PM. I can email you the plans if you like. These are not my plans but supplied by another RCU'er.
Grinder.
_____________________________
That tree wasn''t there when I took off.
(in reply to ec121connie)
       Post #: 126
RE: Field Stand - 2/4/2006 5:18:15 AM
Prop Nut
Status: offline
I build one slightly different. I did these today to take to a swap meet. I am not sure where the original plans came from, I altered mine from another guy who had a folding table at our club. You can see a folded one against the dressers and two fully open. The rack along the bottom is perfect for a flight box and the fuse arms are peg ajustable. They stow along the bottom rail for transport.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Scope? Listerine? Or Prop Wash?
(in reply to grinder-RCU)
       Post #: 127
RE: Field Stand - 2/4/2006 5:20:00 AM
Prop Nut
Status: offline
And a couple more
Click for fullsize
Click for fullsize
(in reply to Prop Nut)
       Post #: 128
RE: Field Stand - 2/4/2006 11:50:46 PM
Prop Nut
Status: offline
A couple of people have asked me for the plans for those tables, I have no way to scan a drawing (I am no great hand with a drawing program either) but I did email them these instructions and cut list. I thought I would post it here.
Legs: 4 - 38 x 1 1/2 x 3/4 Drill a 1/2" hole 7/16" from one end, 16 inches center to center to the next hole (the hole in the middle is for the scissors joint) Center the holes on the piece.
Cross pieces on the legs. 2 - 20 3/4 x 1 1/2 x 3/4 with two pre drilled holes on the ends to attach to the legs.
Cross pieces on the legs. 2 - 22 3/8 x 1 1/2 x 3/4 with two pre drilled holes on the ends to attach to the legs. The first set are 3 inches from bottom and the next are set 10 inches above the first. Pre drill dowel holes in these before assembly to store the fuselage supports. One set of legs will be slightly wider than the other set so that they will fit together to lay flat.
Table top.
Start with;
2 - 1/2 plywood cut 24x13
4 - 1 1/2 x 24 x 3/4 lumber with a 1/4 x 1/2 dado cut one side of each running the length. Glue these to the long edges of the plywood. I also used pins to keep them in place until the glue dries. The bottom of the lumber must be flush with the bottom of the plywood.
4 - 1 1/2 x 24 x 34 lumber with a 1/2 hole bored 7/16" from the end. These are the top supports
Glue the top supports to the underside of the table tops that you glued up in the above steps. They should stick out 8 1/2 inches or so from the sides of the table top. One set can be glued flush with the sides. The other set VERY IMPORTANT must be inset enough on each side to allow the whole unit to fold together. The inset is about 2 1/2 inches but do a dry fit to be sure everything will clear.
Assembly.
Sandwich the two sets of legs together, the center 1/2" holes should line up. Take a 1 3/8 " piece of 1/2 PVC tubing and slide into the lined up holes. Drill a hole through the outside set of legs and insert a screw to hold the tube in (this is your pivot joint). Line up the holes in the wider table top assembly with the holes in the end of the wider set of legs and insert PVC tubing again. Be careful how you assemble the inner legs with the narrower table top assembly as you might need to take it apart again if you are on the wrong side of the other table top assembly. Again use PVC to fit them together. The PVC acts as joints for everything. Make sure no PVC extends outside of the joints though, as this may catch on the parts when they are folding together.
I am pretty sure that no RC kit company would want to hire me to write their assembly books so ask questions if you need answers I will try to take more detailed photos of the tables when I get the chance. Hopefully I will sell them tommorow though, gotta get my Balsa USA Fix..........want thier Neuiport 28 next....or maybe thier Fokker DVIII (I wrecked mine).........hmmm so many choices. I have thier Fokker DVII, Fokker Eindecker, Sopwith Pup and a Dynaflite SE5.....I kinda like the WWI birds.
       Post #: 129
RE: Field Stand - 2/5/2006 4:58:55 AM
Pa-18cub150
Status: offline
Hay Grinder
Do I understand correctly, do you have a copy of Greg Finan’s field stand plans that you are shearing? I have tried direct contact and the links with no luck. If so would you be so kind as to send a set to me at garysue@threeriver.net
Thank you
Gary
Good judgment comes from bad experience, and a lot of that comes from bad judgment.
       Post #: 130
RE: Field Stand - 2/6/2006 9:57:31 PM
Brad Boyes
Status: offline
send me your email address to brad_boyes@hotmail.com. I will send you the zip files
       Post #: 131
RE: Field Stand - 2/20/2006 2:15:06 AM
Pa-18cub150
Status: offline
Brad Boyes
Thanks for the files I am starting a cutting list tonight.
(in reply to Brad Boyes)
       Post #: 132
RE: Field Stand - 2/28/2006 4:14:05 PM
K01S
Status: offline
Hi Jimmyd56,
I know this is an old thread but I just down loaded Greg Finan's Field Stand drawings. Thank you very much for posting them!! Also, Thank you Greg Finan if you are still reading this thread. - K01S
(in reply to jimmyd56)
       Post #: 133
RE: Field Stand - 2/28/2006 6:02:35 PM
Rodney
Status: offline
Prop nut, those plans were some I designed and they were published in RCM a few years back.
(in reply to K01S)
       Post #: 134
RE: Field Stand - 2/28/2006 8:08:57 PM
Prop Nut
Status: offline
Really? I have heard that same thing from many other guys (no offense) but if you are the originator, I applaude you. I really like this setup.
(in reply to Rodney)
       Post #: 135
RE: Field Stand - 2/28/2006 8:31:36 PM
K01S
Status: offline
My thanks to you then Rodney. I'll post pictures after I'm done. - K01S
       Post #: 136
RE: Field Stand - 3/21/2006 2:45:08 PM
wck3
Status: offline
Can someone send me Greg Finan’s field table plans? I can't seem to get the download to work properly. I'll post a link for it up on my site once I get the file. Thanks.
cklemm@wck3.com
(in reply to K01S)
       Post #: 137
RE: Field Stand - 3/21/2006 2:52:07 PM
Joe14580
Status: offline
quote:
ORIGINAL: wck3
cklemm@wck3.com
Sent .
(in reply to wck3)
       Post #: 138
RE: Field Stand - 3/21/2006 3:34:29 PM
wck3
Status: offline
Thanks.
I am hosting it on our club site as well, for those that are having problems like I was.
http://www.farcc.org/Field%20Stand%20Plans.zip
(in reply to Joe14580)
