How to clean engines
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> How to clean engines
Page: [1]
Login
How to clean engines - 1/13/2002 1:33:41 AM
scale buff
Status: offline
I have several engines and mufflers that could really use a good cleaning. I used to use Sunbeam fry pan cleaner, but that product is no longer made. What works good now? I've heard that the currently available engine cleaners don't really work all that well. Have I been misinformed? Any help would be appreciated.
       Post #: 1
clean - 1/13/2002 2:50:29 AM
kamlooper
Status: offline
I read on a newsgroup to use an old crockpot and some antifreeze. Disasemble the entire engine and put contents (minus o-rings) into the pot and heat for 8~9 hours. When done rince with hot water and dry everything with a soft cloth. Then lubricate with oil (didnt say what type, WD-40 or after run should do) Also be ware of YS engines with pumps, dont clean them with the above method.
I havent tried this myself yet but I just recently found a crockpot to use and will soon try it out. Of course DO NOT use the pot again for cooking food!!!!
I used to use a popular engine cleaning chemical (z best) but that stuff would dry up just sitting around and is quite expensive. The crock pot should be cheaper and safer to use....hopefully it works good. I'm going to use it outside to avoid any fuses escaping into the house.
Let ya know how it works for me. Later.
(in reply to scale buff)
       Post #: 2
results - 1/15/2002 3:08:40 AM
kamlooper
Status: offline
9hrs on low temp, rinsed-dried-lubed. here it is, works pretty good!
Click to see fullsize image.
Click for fullsize
       Post #: 3
How to clean engines - 1/15/2002 9:40:29 AM
scale buff
Status: offline
Boy, it looks great. Now to find an old crock pot. I wonder if she would miss........... Naw, better not.
Thanks for sharing.
       Post #: 4
How to clean engines - 1/15/2002 10:14:16 AM
Elwood
Status: offline
When was the last time you had stew? Go ahead. If she gets mad, tell her how much money and time you saved over cleaners and elbow grease!
_____________________________
Born in the U.S.A.......Not quite as long ago as Art!!!!!!!
       Post #: 5
Go buy her a new crockpot - 1/16/2002 7:42:02 PM
John B
Status: offline
then take the old one out to the garage and use it for cleaning engines. my crockpot still looks pretty new so I took a black magic marker and wrote "POISON not for food stuffs" on the side.
Once you use antifreeze in it it permeates (sp?) the pot and will leave traces in everything you put in after so dont cook with it after you have cleaned a engine with it .
John
       Post #: 6
How to clean engines - 1/16/2002 8:02:46 PM
Philip
Status: offline
Promise her a new one and take the old one. It worked for me. You know how they like new stuff.
I have a ? though about this method. I have cleaned my 2 strokes in the past with this method and it worked great.
I now need to clean my Saito .72 and was concerned about the rubber on the lift rod post on the outside of the engine. Should I remove these?
I would assume so, but would like an experienced opinion. Thanks!
       Post #: 7
How to clean engines - 1/17/2002 5:07:49 AM
Volfy
Status: offline
Seriously though, a new small crock pot cost $15-$19 at Wlamart. It's chump change compared to what we throw at our planes day in and day out.
Don't mess with wife's and go buy yourself one. Or better yet, as suggested, pamper her with a $30 top-of-the-line delux model and take her old one.
       Post #: 8
How to clean engines - 1/17/2002 5:29:23 AM
Fuelman
Status: offline
Demon Clean.
Outstanding stuff, it does not get any better. safe for all engines.
Fuelman
Fuelman
Cooper Fuels LLC
       Post #: 9
How to clean engines - 1/17/2002 7:07:55 AM
scale buff
Status: offline
Fuelman, what is Demon Clean and where do you get it? Thanks, guys, about the suggestions to buy her a new one and take her old one. Can't beat it, I get what I need and I'm a hero, all at the same time.
       Post #: 10
Demon Clean - 1/19/2002 12:37:16 PM
Fuelman
Status: offline
It was developed by David Geirke specifically for removing the brown crud off our aluminum model engines. It's very low odor, I believe non flamable and it works great.
this should get you to his site.
http://www.aviatronics.com/dgfm.htm
He's the only one that sells it other than a few of the finer hobby shops.
Fuelman
Fuelman
Cooper Fuels LLC
       Post #: 11
How to clean engines - 1/20/2002 7:43:33 AM
GoNavy
Status: offline
Does the warm antifreeze bath method remove carbon deposits inside the engine? Does Demon Clean??
Z best requires two to three applications with brushing and still won't achieve Kamlooper's results. I just spent two days cleaning a 4 stroker and a 2 stroker and I'm still at it. Soaking in solvent alcohol per Harry Higley removes varnish but very slowly.
Does anyone use ultrasonic cleaning, and how are the results?
GoNavy
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
