Pay It Forward Build Thread!! Sig LT-40 build
#676
Doing good Reggie. Pictures are OK, could use a little more light it appears. Good to wsee you using the 90 degree brackets and pins.
Try this - put a T-pin on either side of the spar and stretch a small rubber band between them over the top of the spar. This will PULL the spar down snug. Do this in about every other bay for best results.
#677
RCU Forum Manager/Admin
My Feedback: (9)
ORIGINAL: RookiePilot
I finally see what all the comotion is about. Building from kits is tons of fun.When I opened the box and saw all the wood it was a little intimidating. When I starting laying out the parts, my 3 year old son goes gets his little plastic toolbox and says "Daddy we got work to do". I couldn't help to chuckle a bit.
Ken
#678
SC
Thats a great idea Bruce. I will definately do that from here on out. I love working with the carpenters glue. Maybe Im just slow, but the CA is dried before I get a part placed where I want it. The smell of the CA also scares me with my son around. Let me ask you guys a question, how differently does the Kadet fly compared to the nextstar? I fly the nextstar all over the place on Realflight. Just curious if the flight characteristics was close.
Reggie
Reggie
#679
My Feedback: (9)
Having flown both in the real world I would say that the Sig flies much better than the Nexstar. The wing is larger (900 sq. in on the LT-40 compared to 722 sq in on the Nexstar) on the Sig which smooths out the way that it flies. If I had to pick a best flying trainer of all the ones that I've ever had experience with I would say it would be the Lt-40!!
Ken
Ken
#680
Congratulations Ken!
That“s the best thread I“ve ever seen. I received a couple of days ago my Sig Kadet LT-40. Thank“s to your effort a lot of people (me too) will learn how to bild a plane.
I“m so impatient to beginn my project!!!
Does anybody know how to make a pdf file with the 28 pages of this thread?
I would like also to have a copy of the plans. A TIFF file is better than a pdf or Jpeg file?
Maybe the company Sig kann send me a copy of the plans in digital format if I have already purchased one of their kits.
#681
Reggie - thin CA is applied with the parts already positioned in their final places. There is a reason why they call it "instant" glue. Medium and thick CA have some positioning time but don't really penetrate as well. Don't try to use the thicker CA to make up for poor fit. There is no substitute for wood to wood contact.
CA fumes CAN be very hazardous and severe alergies can develop. This doesn't even take into account if your son should accidentally ingest some or get the liquid in his eyes. In a home with children, this is a VERY dangerous chemical. Treat it as such or get rid of it.
#682
SC
No worries, I locked it up along with the razors and saws and all that good stuff. The only time I will use it is for hard points when inserting screws, or when installing the hinges. Speaking of my son, here is a picture. The clamps weren't needed there, but I like to include him. Trying to get him started early. He flies on the simulator too (or attempts too).
Reggie
Reggie
#683
My Feedback: (9)
Now with the major part of this part of the wing done itās time to trim of the extra covering. One of the more difficult things I have found to do is get a straight line on the leading edge of the wing where the covering meets. I know there are people that try to apply the covering in a straight line on the leading edge and then cover the wing from there, but I have absolutely no luck doing it that way. Instead I will mark a straight line where I want it cut, and then cut it off on that line. If you take it slowly as you cut itās really pretty easy to cut it along that straight line. Because of the fact that the leading edge of the wing is curved it makes it a bit difficult to measure with a āhardā ruler because the area that needs measured is around the curve of the leading edge, so I do something a bit different when marking the line to cut on. There are actually many ways to measure something like this, like using a cloth measuring tape instead. And even easier (at least for me) is to cut a small āguideā, in picture #1 you can see that I simply used a scrap piece of Monokote to make this guide. Once I have the āguideā itās quick work to put this in place down the length of the wing to mark where we will cut the covering (picture #2). Picture #3 shows the marks I made down the leading edge. For marking like this I prefer to use a Sharpie marker, as I stated earlier. This is because it marks easily on the covering, will not rub off as I work, and can easily be removed with a little bit of alcohol last on. With the guide marks in place use a straightedge to draw our cut line down the length of the leading edge (picture #4). Picture #5 shows our line in place and ready to cut on. Unfortunately I didnāt get a picture if actually cutting the covering, but itās not too difficult. The best advice I can give is to position your hand so that it rests on top of the wing so that it keeps your hand steady as you cut along the line. Donāt get in a hurry and take your time and cut along the line down the length of wing. After you have the cut made use a paper towel with alcohol on it to remove and left over marks from the Sharpie. Use a covering iron to seal down the edge of the covering after you cut it (picture #6). Pictures #7 & #8 show the leading edge after we are finished up. Not bad, nice straight line!
Pictures
1. Cut a measuring guide from a scrap piece of Monokote.
2. Use the guide to mark the leading edge for cutting.
3. Marks on the leading edge.
4. Use a straightedge to mark the cut line on the covering
5. Cut line in place
6. Use a covering iron to seal down the covering after cutting it.
7. Completed leading edge.
8. Completed leading edge.
Pictures
#684
My Feedback: (9)
Next up isnāt exactly a step in building planes, but trust me in that itās something that you will face all the time. Looking at picture #1 you can see what I officially call and āoopsā!!
As I was handling the wing the tip of the aileron it something and left a chunk taken out of the wood. So before covering the ailerons the ding needs repaired. Itās really a fairly easy repair to do. To start off with the area to be repaired needs to be shaped so that we can repair it, so cut the area to repair so that we have straight edges to glue to (picture #2). Use a scrap piece of balsa and glue it into the area to repair (picture #3), itās easier to use an oversized piece of wood and sand to shape than to try to cut to shape before gluing it in place (picture #4 & #5). Once the glue is dry on the wood itās a simple matter of sanding the wood to shape to match the aileron (picture #6). If you look at pictures #8 - #10 you can see that the repaired area is very hard to detect, and when itās covered it will not show at all. A simple easy repair to make and then we can move on with the project.
The point of this point was to simply point out that āstuffā happens as you build. But the best thing to do is what I said earlier āDonāt Panicā, repairs are usually easy to do. Just take your time and figure out the best way to fix the damage, fix it, then move on.
Pictures
1. Oops. A ding in the wood of aileron needs to be repaired before covering the aileron
2. Cut the wood of the damaged area
3. Glue in a piece of scrap wood in the area we just cut.
4. Glue in a piece of scrap wood in the area we just cut.
5. Glue in a piece of scrap wood in the area we just cut.
6. Sand the wood to the shape of the aileron.
7. Sand the wood to the shape of the aileron.
8. The repaired area is hard to see after itās completed.
9. The repaired area is hard to see after itās completed.
10. The repaired area is hard to see after itās completed.
Until next time
Ken
As I was handling the wing the tip of the aileron it something and left a chunk taken out of the wood. So before covering the ailerons the ding needs repaired. Itās really a fairly easy repair to do. To start off with the area to be repaired needs to be shaped so that we can repair it, so cut the area to repair so that we have straight edges to glue to (picture #2). Use a scrap piece of balsa and glue it into the area to repair (picture #3), itās easier to use an oversized piece of wood and sand to shape than to try to cut to shape before gluing it in place (picture #4 & #5). Once the glue is dry on the wood itās a simple matter of sanding the wood to shape to match the aileron (picture #6). If you look at pictures #8 - #10 you can see that the repaired area is very hard to detect, and when itās covered it will not show at all. A simple easy repair to make and then we can move on with the project.The point of this point was to simply point out that āstuffā happens as you build. But the best thing to do is what I said earlier āDonāt Panicā, repairs are usually easy to do. Just take your time and figure out the best way to fix the damage, fix it, then move on.
Pictures
Until next time
Ken
#685
My Feedback: (9)
All thatās left on the wing is to cover the ailerons and put the graphics on it. I always save doing the graphics on a plane until I have the plane completely covered, and then I will put graphics on both the fuselage and wing at the same time. So that leaves us with just covering the aileron. I do apologize on this step that I donāt have all the pictures of this step as those pictures were some of the ones lost when the memory card on my camera got corrupted. Iām posting all the pictures that I have left of this step and will explain what needs to be done.
Covering the ailerons is a very straightforward step, and doesnāt take too much time. Cut a piece of covering cover the aileron with (picture #1). As with everything else we do when cutting covering, cut it oversize so that we have covering to pull on as we apply it, weāll cut the excess after we are finished. Start off here just like everything else we have done by tacking down one corner of the covering (picture #2 & #3), line up the covering with the inside edge of the aileron and weāll pull and tack the covering using this edge as a guide. Now pull the covering tight and tack the other end of the aileron covering in place. Now go to the middle of the aileron and pull the covering down until the edge of the covering lines up with the edge of the aileron (picture #4), and tack it in place (picture #5). Continue pulling and tacking along this edge down the length of the aileron (picture #6). Here is where I ran out of pictures, so Iāll just describe what to do. After you have the edge tacked in place now we need to go ahead and iron down the covering to the aileron. On some planes with bigger aileron surfaces we could use the heat gun to shrink the covering before ironing it down like we did on the wing tips, but these ailerons arenāt really big enough to do that so weāll just iron them in place. For this I prefer to use the iron with the hot sock on it. Itās pretty easy to do, just pull the covering tight and use the iron to seal the covering down to the aileron. When you have the entire aileron sealed then trim the edges and make sure that they are sealed down after trimming. Now go finish covering the rest of the aileron surfaces.
And that is it, with the exception of the graphics the wing is now covered. Take a few minutes and look over the work and make sure there arenāt any things that were missed. The biggest thing I usually find it edges that may not be completely sealed down. Taking the time to check for them and fix them now will save you tons of headaches later on when you start flying the plane, so it pays to spend a few minutes now making sure the covering is correct.
Next up weāll start on covering the fuselage. So put the wing in a safe place until later and weāll get ready to move on.
Pictures
1. Cut covering for the aileron.
2. Tacking down the corner of the covering.
3. Corner of the covering tacked in place.
4. Pull the covering in the middle so it lines up with the inside edge of the aileron.
5. Tack along the inside edge.
6. Tack the covering all along the inside edge of the covering.
Until next time
Ken
Pictures
Until next time
Ken
#686
ORIGINAL: RCKen
#687
My Feedback: (9)
ORIGINAL: bruce88123
Fess up Ken. Ya stuck the wing into the running ceiling fan.
ORIGINAL: RCKen
I was hoping you wouldn't bring that up!! But it is true, that's how I dinged the aileron. I was turning the wing around and the wing tip was hit by the ceiling fan that was running!!! [:@] Oops!!!!
Ken
#691
What a great idea - pinning small right angle brackets this way. I've never seen this before - excellent idea.[sm=thumbs_up.gif]
#692
If you drill a small hole (just a tad bigger than pin diameter) in each leg of the angle, you can pin right through it. Less chance of movement.
#693
#694
quinoa,
I'll tell you what. If you can wait until I get done with the rest of the build I'll create a PDF for you.
Thank“s in advanced
Alberto
#697
SC
You convert it one page at a time. Once you have all them converted, you open the first page in acrobat , then go to document->insert pages. Once complete, you will have one large file and can delete the rest
#699
SC
Well if you could find a way to show all 28 pages of this thread on one page you could do it. Otherwise, one at a time.
Reggie
Reggie
#700
I was looking to do the same on pdf. I ended up using Micrsoft Works then copy -n- pasted all the posts by RCKen regarding the build. It came up to 99 pages (printed out in library for $10 [:@] ) but it was worth it. I am building a LT-40 and using RCKens build posts/thread as a guide. Of coarse I added a bibiliography of where i got it and put down RCKen as the Author (just to be safe to avoid any plagerism).
If there is a easier way to fit all his build posts into fewer pages please let me know. Until then I will keep reading the 99 pages multiple times (not that bad if dedicated to reading 99 pages!!
Thanks For this thread, it has helped me out greatly (since this is my first kit build) as well as others
And if i did anything bad or wrong by copy and pasting onto works let me know (again to avoid plagerism ).
).Thanks For this thread, it has helped me out greatly (since this is my first kit build) as well as others
