 Pay It Forward Build Thread!! Sig LT-40 build >
Old 10-19-2005 | 10:37 AM
  #101
Flyboy76's Avatar
My Feedback: (14)
Default RE: Pay It Forward Build Thread!! Sig LT-40 build
Hey Ken was wondering if you would consider building another Hog Bipe and do the build like you are doing this one. I would like to build a Hog Bipe, but i have a couple of kits in front of it first. LT-40 (currently building) and a Goldberg Super Chip. It would be awesome to have a thread to reference a Bipe build with the detail like this one. I know this is a big request given how much you dislike biplanes.
Flyboy76
Old 10-19-2005 | 11:10 AM
  #102
While you wait for Ken's answer, you may want to look at this thread.
http://www.rcuniverse.com/forum/m_25..._1/key_/tm.htm
It is pretty good and I've seen Ken reference it before.
Old 10-19-2005 | 11:11 AM
  #103
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Flyboy,
Oh yeah, you really have to twist my arm to get me anywhere near a biplane!!!!
I don't know, it might be possible. Only problem is that I don't need another Sig Pig in my fleet. Let me rephrase that. I could always use another one there, I just can't justify it. I wouldn't have a radio or motor for it. But who knows, we'll see what happens.
Ken
Old 10-19-2005 | 03:54 PM
  #104
Flyboy76's Avatar
My Feedback: (14)
thanks for the link Bruce i have printed it all out and will use it as reference whein i build my BIPE.
Flyboy76
Old 10-19-2005 | 06:29 PM
  #105
Thanks you guys for all your input on servos. I will most definitely be replacing the battery, was planning on that. Just wanting to know if there were any brands of servos I should really stay away from. I think i will go ahead and get the Futuba servos.
RCKen, I look forward to you catching up to me. I will be taking a break this weekend as I am going camping with some friends.
Old 10-19-2005 | 06:50 PM
  #106
RCKen's Avatar
My Feedback: (9)
Only one last thing to do for the left wing panel to be finished (for the moment). As I said in my last post, I'm going to hold off setting the W1 rib until I have both wing panels finished and ready to be joined. I glued on the wing tip panel earlier, and now I'm going to finish that part up. I'm including some extra pictures for Tigerdude to see what the wing tip plate looks like. When we finish up this step there will be some semi-ugly holes left in the wing tip. Some my be tempted to fill those holes now while we are here, but I prefer to wait on doing any filling. As you are still building just isn't the time to fill. You may wind up with more to fill later on, you may find out that you don't need to fill after all, or you may damage what you filled as you work later on. In my opinion it's just easier to fill later on when we are working on the finish of the plane. But for now, let's finish up the left wing panel by taking care of the wing tip plate.
Remove the the tape that was holding the wing tip plate in place while the glue was drying. It should look pretty much like picture #1, with the leading edge, trailing edge, and the spars extending past the end of the wing tip plate. The next step is to cut off the extra. Some might thing that it would be better to cut of as close to the wing tip plate as possible. While this might seem easier, it usually will result in extra work. More often than not you will end up cutting too much away, or gouging wood out of the wing tip plate. When you cut these off just make a rough cut that is “closeâ€. Leave extra material. This is just the same principle as I said in an earlier post, it's better to do a little bit at a time because you can always cut a second time, but it's a pain to try and add material back. Pictures #2 & #3 show cutting these sticks off, leaving extra material there. As you can see in pictures #4, #5, and #6 you can see how it was a “rough†cut with extra material left. Use a sanding block to smooth down the rough cuts. Don't worry about getting a “covering ready†finish when you sand, we are just interested in getting it close. We'll worry about getting is smooth when we sand the entire plane in preparation for covering. In pictures #7 & #8 I used 80 grit paper on a small sanding block to “rough it inâ€. In picture #9 we can see how the top main spar sticks out past the edge of the wing tip, we'll want to sand that down too. Use your sanding block to rough shape it to the same shape as the wing tip. Pictures #10 and #11 show how they looked after being rough shaped. Picture #12 shows the final wing tip plate.
And there you have. We are finished with the left wing panel roughly finished. It wasn't has hard as you thought it would be was it? I'll let you in on a little secret, we just finished half of the hardest part of building an airplane. Yep, that's right. When we finish the right wing panel we will be done with the hard part. And see how easy it was to get here? That's why I am doing this build thread, to some people just how easy it is to actually build a plane.
Pictures
1. Rough ends of spars, leading edge, and trailing edge.
2. Cutting off excess rear spar.
3. Cutting off excess leading edge
4. Rough cut ends
5. Rough cut leading edge
6. Rough cut spars
7. Sanding down rough cuts
8. Sanding down rough cuts
9. Main spar extending past wing tip
10. Sanding main spar to shape of wing tip.
11. Trailing edge sanded to shape.
12. Wing tip finished.
Until next time
Ken
ID:	341297   Click image for larger version
ID:	341298   Click image for larger version
ID:	341299   Click image for larger version
ID:	341300   Click image for larger version
ID:	341301   Click image for larger version
ID:	341302   Click image for larger version
ID:	341303   Click image for larger version
ID:	341305   Click image for larger version
ID:	341306   Click image for larger version
ID:	341307   Click image for larger version
Old 10-19-2005 | 07:00 PM
  #107
RCKen's Avatar
My Feedback: (9)
Ok, with the left wing panel done the instructions say to go back and build the right wing panel in exactly the same way. Since I've posted details doing the left wing panel I'm not planning on posting anything for doing the right wing panel. What I am going to do is build the right wing panel and then my next construction post will be the next step after building the right wing panel, which will be actually joining the 2 wing halves. Hopefully it won't take too long to build the right wing panel.
I don't know about those of you out there reading this thread, but when I am following a construction thread I like to see as many pictures of the project. I've been putting in as many pictures as I can for each step, but like I said before, I'm limited to posting 12 pictures with each step. Trust me, I have a lot more pictures taken than just the ones that I've posted. Since I won't be posting for a little bit, I'm going to upload all the extra pics that I've got laying around for you all to look at. I'm not going to label them or put commentary on them, but if you have any questions about any particular picture please don't hesitate to PM me about it. I'd be more than happy to answer any questions you may have.
Later
Ken
ID:	341312   Click image for larger version
ID:	341313   Click image for larger version
ID:	341314   Click image for larger version
ID:	341315   Click image for larger version
ID:	341316   Click image for larger version
ID:	341317   Click image for larger version
ID:	341318   Click image for larger version
ID:	341320   Click image for larger version
ID:	341321   Click image for larger version
ID:	341322   Click image for larger version
Old 10-19-2005 | 07:03 PM
  #108
RCKen's Avatar
My Feedback: (9)
More pictures
Ken
ID:	341324   Click image for larger version
ID:	341325   Click image for larger version
ID:	341326   Click image for larger version
ID:	341327   Click image for larger version
ID:	341328   Click image for larger version
ID:	341329   Click image for larger version
ID:	341330   Click image for larger version
ID:	341332   Click image for larger version
ID:	341333   Click image for larger version
ID:	341334   Click image for larger version
Old 10-19-2005 | 07:05 PM
  #109
RCKen's Avatar
My Feedback: (9)
More pictures
Ken
ID:	341336   Click image for larger version
ID:	341337   Click image for larger version
ID:	341338   Click image for larger version
ID:	341339   Click image for larger version
ID:	341340   Click image for larger version
ID:	341341   Click image for larger version
ID:	341342   Click image for larger version
ID:	341344   Click image for larger version
ID:	341345   Click image for larger version
ID:	341346   Click image for larger version
Old 10-19-2005 | 07:07 PM
  #110
RCKen's Avatar
My Feedback: (9)
More pictures
Ken
ID:	341348   Click image for larger version
ID:	341349   Click image for larger version
ID:	341350   Click image for larger version
ID:	341351   Click image for larger version
ID:	341352   Click image for larger version
ID:	341353   Click image for larger version
ID:	341354   Click image for larger version
ID:	341356   Click image for larger version
ID:	341357   Click image for larger version
ID:	341358   Click image for larger version
Old 10-19-2005 | 07:09 PM
  #111
RCKen's Avatar
My Feedback: (9)
More pictures
Ken
ID:	341360   Click image for larger version
ID:	341361   Click image for larger version
ID:	341362   Click image for larger version
ID:	341363   Click image for larger version
ID:	341364   Click image for larger version
ID:	341365   Click image for larger version
ID:	341366   Click image for larger version
ID:	341368   Click image for larger version
ID:	341369   Click image for larger version
ID:	341370   Click image for larger version
Old 10-19-2005 | 07:11 PM
  #112
RCKen's Avatar
My Feedback: (9)
Last batch of pictures for now
Ken
ID:	341372   Click image for larger version
ID:	341373   Click image for larger version
ID:	341374   Click image for larger version
ID:	341375   Click image for larger version
ID:	341376   Click image for larger version
ID:	341377   Click image for larger version
ID:	341378   Click image for larger version
ID:	341380   Click image for larger version
ID:	341381   Click image for larger version
Old 10-19-2005 | 07:56 PM
  #113
Looking good as usual Ken, I'm starting to get excited for SeeBee and his daughters! I can't wait to see the finished plane. I hope it gets done before I have to go back to work, while I have the time to watch your progress on a daily basis. I see your watching as well SeeBee, starting to look like an airplane isn't it? The Master Builder @ work[sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif][sm=tongue.gif]
Mark
Old 10-19-2005 | 09:28 PM
  #114
Ken:
Looking great man! I'm thinking sig should include your pics/illustrations and instructions from this thread with all their LT-40 kits
Old 10-19-2005 | 09:58 PM
  #115
This is the best build thread ever Ken. Give yourself a pat on the back!
MountaineerFan: Hows it going? Haven't seen you around lately. How is the 4*60 doing? Hope all is well.
Patrick
Old 10-20-2005 | 08:56 AM
  #116
bubbagates's Avatar
My Feedback: (32)
ORIGINAL: MountaineerFan36
Ken:
As well as your build thread for the 4*
Old 10-20-2005 | 09:02 AM
  #117
bubbagates's Avatar
My Feedback: (32)
ORIGINAL: RCKen
Flyboy,
Ken
Hey Ken, I'll bet I could get you to justify getting the WildHare Ultimate
Oh yea folks, you don't have to twist his arm much when it comes to bipes. All I have to do is mention my WH Ultimate and he finds a way to try to talk me out of it. The latest was me saying he could have it when he could pry my dead cold fingers from it and he asked can he do it while my fingers were still warm.
Old 10-20-2005 | 09:03 AM
  #118
RCKen's Avatar
My Feedback: (9)
ORIGINAL: bubbagates
Ken:
[sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif] Ditto on that feeling. Mountaineer did a fantastic job on his 4*.
Ken
Old 10-20-2005 | 10:52 AM
  #119
Katrina +Rita+ Wilma + New Baby = No flying
My company does a lot of work with electric utility's...and I've been spending a lot of time down south working storms...so not much flying.
I hope things slow down a bit and I can get some flying time in before the snow starts to fly.
Old 10-20-2005 | 10:59 AM
  #120
RCKen's Avatar
My Feedback: (9)
ewwwwwwwwwwww, snow!!!! [:'(]
Bad word, bad word. We don't use language like that around here young man!!!!
Ken
Old 10-20-2005 | 11:17 AM
  #121
MountaineerFan: Sorry to here that, but that is what I suspected. I was hoping to hear that you had snuck in a little time on that beautiful 4*60 you worked so hard on. Well, if it wasn't for work we couldn't afford this hobby. I know how it goes. I was in construction back in the early 90's when hurricane Andrew devastated Miami. I was snowed under with work for a year before I was so burnt out I had to quit.
Good luck to ya,
Patrick
Old 10-20-2005 | 11:25 AM
  #122
Now figment uses the "snow" word. What is this an epidemic? [:'(]
Old 10-20-2005 | 11:36 AM
  #123
Hehehehe, Bruce, musta been stuck in my head from previous comments . I hardly think it is time to start worrying about snow when we can't even get through with hurricane season [&o].
Patrick
Old 10-20-2005 | 02:14 PM
  #124
Ken is a great builder in my eyes!!! Ken if there is anything I Can do let me know!!!
Thanks Jim
Old 10-20-2005 | 03:49 PM
  #125
[] [sm=thumbdown.gif]SNOW [sm=punching.gif][sm=crying.gif]
[:'(] Not knowing how to fly [sm=thumbdown.gif][sm=thumbdown.gif][sm=thumbdown.gif]
