What the Best RC drift car?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Drifting >> What the Best RC drift car?
Page: [1]
Login
What the Best RC drift car? - 10/11/2005 3:28:47 AM
driftboy88
Status: offline
Can anyone tell me the best RC Drift Car?
Can anyone Name all the Brand or Name of the Best RC Drift Cars
Thanks!!!!!!!!!!!!!!!!
< Message edited by driftboy88 -- 10/11/2005 3:34:08 AM >
       Post #: 1
RE: What the Best RC drift car? - 10/11/2005 4:20:35 AM
ROYjovero
Status: offline
The Japanese regard the Tamiya TA-03F as the world's best RC drifter. Tamiya knows this and will be releasing the TA-03F Pro Drift Spec sometime this month.
As for what the best one is, it's all a matter of opinion. The only real requirement is 4WD. I think my Yokomo MR-4TC BD is the ultimate drifter, but with the $420 MSRP, most everyone else would look at something cheaper.
(in reply to driftboy88)
       Post #: 2
RE: What the Best RC drift car? - 10/11/2005 7:24:50 PM
killabud
Status: offline
why is it that RC drift cars are 4wd and you never see that on a full scale drifter?
(in reply to ROYjovero)
       Post #: 3
RE: What the Best RC drift car? - 10/11/2005 8:55:25 PM
gogita502
Status: offline
what are you talking about?? you do see it. drifting evo and sti and skyline
(in reply to killabud)
       Post #: 4
RE: What the Best RC drift car? - 10/11/2005 11:04:21 PM
ROYjovero
Status: offline
Evo's, Imprezas and GT-R's usually don't drift. If you didn't know, the Blitz ER34 and Yuke's Impreza in the D1 Grand Prix are rear-wheel drive. And as for an Evo, Rhys Millen was testing a RWD Evo 9 before he decided to stick with the GTO for Formula D.
Now when it comes to RC, 4WD is a must. Most every RWD RC has a mid-rear motor layout and since there is a lack of weight in the front, drifting is impossible. The front wheel power in a 4WD RC drifter will assist you in drift recovery.
(in reply to gogita502)
       Post #: 5
RE: What the Best RC drift car? - 10/12/2005 12:24:29 AM
gogita502
Status: offline
well a cheap 4wd 4WD Drift Special
       Post #: 6
RE: What the Best RC drift car? - 10/12/2005 12:25:59 AM
gogita502
Status: offline
and d1 is about to or thinking about letting this 550 beast com out of its cage
and i drift with 4wd in gran turismo hehehehe
< Message edited by gogita502 -- 10/12/2005 12:26:33 AM >
       Post #: 7
RE: What the Best RC drift car? - 10/12/2005 2:27:55 AM
driftboy88
Status: offline
which is better to drift with Gas or Electric?
Tell me if there any other brand that are best for RC Drifting
Thank You!!!
Origoto!!!
       Post #: 8
RE: What the Best RC drift car? - 10/12/2005 3:32:36 AM
gogita502
Status: offline
well i say electric cuz less hasle. nitro gas and engine trouble blehhhhhh
electric-yokomo, tamiya, hpi, schumacher, any electric hooby grade cars can drift.(belt or shaft) (4wd prefebly)
       Post #: 9
RE: What the Best RC drift car? - 10/13/2005 4:02:52 PM
Reaper_Unreal
Status: offline
Here's the scoop, any car can drift, electric is easier to drift, but nitro is fine as well. You'll probably want some decent drift tires, but you can make those yourself.
There's LOADS of best drift car threads on this forum, so next time just read. In fact, there's 3 of these threads on the FRONT PAGE right now.
As for 4WD vs. 2WD, RC drifters are 4WD because it's much easier to control a 4WD car that small. It has to do with grip, weight, and surface, but the point is that you could drift with 2WD (front OR back) as well, it would just be harder.
For full scale drifting, you can drift with RWD, FWD, AWD, 4WD, any of them. RWD is much easier to control while drifting for obvous reasons. 4WD and AWD tend to pull the car around the turn and make it difficult for the rear to slide out. FWD can be used for drifting (there's 2 FWD cars in D1GP) but they tend to drift much slower because they have to use the e-brake much more. RWD is usually used for drifting due to the variety of techniques that you can use to initiate a drift. You can only do certain types of drifting in RWD. Also, it's much easier to have a different wheel speed for front and rear in a 2WD car. The larger the differential, the more angle. This is how clutch kick, braking, power over, and e-brake drifting work.
If you want to know more about how drifting works, go watch the Drift King video, or if you're cheap or lazy go look it up on wikipedia.org.
       Post #: 10
RE: What the Best RC drift car? - 10/17/2005 7:09:55 PM
Nicadrauspro4
Status: offline
Here are pics of my Pro4 and FF01 classic with hop-ops (FRP upper & lower chassis decks, aluminum hex hubs, suspension & steering turnbuckles, aluminum shocks, custom rear stabilizers. I use the FF for drifting. Pretty easy to drift and control with PVC wheels.
_____________________________
HPI Pro4 v.1.1 - KO Propo VFS-1 Hara Twister 2 - Futaba 3PJS - Futaba R113iP Micro PCM - Hitec HS-5955TG
(in reply to Reaper_Unreal)
       Post #: 11
RE: What the Best RC drift car? - 10/17/2005 9:02:47 PM
gogita502
Status: offline
sexy lambo.......ugly corolla. isnt it for rally??
(in reply to Nicadrauspro4)
       Post #: 12
RE: What the Best RC drift car? - 10/18/2005 3:14:16 AM
drthunder
Status: offline
 Go with the TC4!! Drift Nashville!
       Post #: 13
RE: What the Best RC drift car? - 1/4/2006 3:56:20 AM
streak8838
Status: offline
another reason these cars almost have to be 4wd it is becaause the scale horsepower is like 2000 compared to a real car and how fast these things can go and it is like 10000 for nitros that is a major reason your average drift machine is about 400 to 500
(in reply to drthunder)
       Post #: 14
RE: What the Best RC drift car? - 1/4/2006 8:31:16 PM
gogita502
Status: offline
yea that but should have let this thread die. its a gravedig
(in reply to streak8838)
       Post #: 15
RE: What the Best RC drift car? - 1/5/2006 1:09:00 PM
RC-Drift UK
Status: offline
Basically there isn't a 'best' rc drift car, it's all in your setup just like the grip racing world
Take a skeet at the cars the sg drifters use, tt's tl's pro3's pro4's etc. etc.
Buy what you like and can get spares and accessories for then get on with it
I don't like the way my TC3 drifts but some love theirs, I don't think the TA03F is the ultimate but some would hang me for heresy, but I do love the way my losi street weapon drifts and I think the JRXS would be a killer drifter
