3D foamy F-18
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> 3D foamy F-18 Page: [1]
Login
3D foamy F-18 - 10/11/2005 11:02:55 PM
ram3500-RCU
Status: offline
Thought you might like to see my F-18. Having a ball. I added an inlet just under the nose to allow air to flow through the speed controll and batt. compartments. I cut holes in the back of the interior box for exit air. It flys well with no flaps or rudders installed. I love the flat spin i can get with it. Really cool and a crown pleaser. Exit at will is no problem and can be made at any heading desired. Also shown is the tail protector i made to keep the delicate elevator lincage from getting damaged in stansit. I had this happen to me.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ram3500-RCU -- 10/11/2005 11:06:37 PM >
       Post #: 1
RE: 3D foamy F-18 - 10/12/2005 2:38:46 AM
vicman
Status: offline
Nice job! Now clean up your room ! What did you paint it with? Here is number 8 for me.
Click for fullsize
_____________________________
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
(in reply to ram3500-RCU)
       Post #: 2
RE: 3D foamy F-18 - 10/12/2005 11:36:14 AM
ram3500-RCU
Status: offline
Painted it with Krylon H2o latex spray paint (Ace Hardware). Almost a perfect match for the Blue Angels look. I'll work on the room.
(in reply to vicman)
       Post #: 3
RE: 3D foamy F-18 - 10/12/2005 12:55:46 PM
vicman
Status: offline
LOL, I used the same thing.
       Post #: 4
RE: 3D foamy F-18 - 10/12/2005 5:38:44 PM
ram3500-RCU
Status: offline
Nice sceam. Looks easy to see.
       Post #: 5
RE: 3D foamy F-18 - 10/12/2005 5:44:21 PM
vicman
Status: offline
Thanks it worked out better than I thought. Its kind of a Canadian Club morphed tiger meet - revver brotherhood - late night induced paint attack scheme
       Post #: 6
RE: 3D foamy F-18 - 10/13/2005 12:59:10 PM
ram3500-RCU
Status: offline
Funny, that's exactly what I thought it was.
Had my speed control literally melt in my F-18. The chips acually dropped off the board. Plane went in like a lawn dart but all it did was get the nose all muddy. I have installed a new control but have yet to try it. I had 50 flights or more on the old one. Will be sending it back to Castle Creations.
       Post #: 7
RE: 3D foamy F-18 - 10/13/2005 1:29:04 PM
vicman
Status: offline
Was it that obvious? So far I have had awsome results with the onboard stuff with these models. GWS rx and servos, Castle 25, Eflite park 370 in an MPI gear box, and Kokam 3s 1500, hard to beat ! Like I said before this is number 8 I have begun saving the noses and a few tails to make an F-18 mosaic .
Here are a few earlier versions.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 8
RE: 3D foamy F-18 - 10/13/2005 1:40:39 PM
c-grain
Status: offline
Ram,Vicman,Those Hornets look really Good!!!I'm thinking of doing 4 of them in a formation like the guy in the Blue Angels formation post formation post did.Did you guys see that!Vic,you probably have 4 laying around somewhere
Rich Karp,
Revver Brother#113
< Message edited by c-grain -- 10/13/2005 1:45:56 PM >
       Post #: 9
RE: 3D foamy F-18 - 10/13/2005 2:32:47 PM
vicman
Status: offline
HA ! I would if I didn't re-use so many of the parts. All the electrics are the same as day one along with contol horns and stabilator.
(in reply to c-grain)
       Post #: 10
RE: 3D foamy F-18 - 10/13/2005 9:03:52 PM
ram3500-RCU
Status: offline
It was a Castle 25 that melted down on me. Appogee 1570, highmax 2015 5400, 9X6 prop. Do you see any problems with that setup? I know a lot of guys are having great success with it. I had great performace till the melt down. I don't stretch my batteries and just don't know what happened. A guy at the LHS said Castle had redesigned the 25 and the new one I got does look differant on the circuit board. Wonder if others are having any trouble with this?
quote:
ORIGINAL: vicman
       Post #: 11
RE: 3D foamy F-18 - 10/13/2005 9:14:58 PM
vicman
Status: offline
Mine is one of the new ones. I also had the LHS program it removing the soft start and brakes. It also has the low voltage cut-off in there. I run mine till it stops or 10 min whichever comes first. It does pull the bat pretty hard at wot. I also have one of the new Eflite ESCs in my delta a much better deal IMO. No programming needed just plug and play, it was also quite a bit cheaper.
       Post #: 12
RE: 3D foamy F-18 - 10/13/2005 11:16:14 PM
ram3500-RCU
Status: offline
Good feedback. Thanks.
       Post #: 13
RE: 3D foamy F-18 - 10/25/2005 5:44:47 PM
lwatson
Status: offline
Do you guys like the 3D foamy F-18 better than the F-15? Is it the same size and weight class? What is the AUW?
Larry
       Post #: 14
RE: 3D foamy F-18 - 10/25/2005 6:35:46 PM
vicman
Status: offline
Haven't finished the F-15 yet so I can't tell you. I have heard a clubmate of mine has one and likes it just as well at the
F-18. He is using a little hotter set-up than I am tho. If I recall I was 17oz unpainted with 19 oz thrust.
(in reply to lwatson)
