aws23
IL, USA Status: offline
I certainly agree with bdavison about the difference between the XRB and the MX400. If you are new to helis of any kind and you have been flying an XRB, when you get your MX400 you start all over in the learning process. Put on your training gear and try to keep it low till you learn to hover. Keep it low till you are sure you are controlling it and it isn't controlling you, then learn to move it from place to place. Then I try to insist (sometimes with little success) that before you take the training gear off, learn to hover nose-in. This one manuever is by far the most important manuever to learn, and it isn't easy. Everyone wants to get up in the sky and blast about with great speed. This is fairly easy to do, somewhat like flying a plane, but to do this you have to hover to get started and after blasting about you have to get the thing slowed down, back to a hover in front of you and settled to the ground. It is hard to accomplish all this without it being nose-in to you at some time. If you haven't practiced this, you are in trouble. If you are blasting down wind, turn upwind, the thing will stop, you looking at the nose for a second or two and down it goes. The best way by far is to practice this on a simulator. Why should I buy a $200 dollar sim just to learn to hover nose-in????? I have been flying helis for 35 plus years and I still fly a simulator a lot. Without question over the years, that $200 dollars has saved dollars many, many times over the cost. All this is probably quite primary to some of you but to the new guys it will hopefully be helpful. A question I hear a lot-------How long has it taken you to learn to fly like this? Answer-- I don't know, I am still learning. Another question--Are helis harder to fly than planes??? Answer--No it just takes longer to learn. Question----How long did it take you to learn to fly inverted?? Answer, About 5 seconds-----
_____________________________
Al
