codepunk
WA, USA Status: offline
Well, after finally getting everything put together I took it out to the garage to see if it would hover (oh, it's a MX400-Pro). Did it? Nope, unfortunately not. Even at full throttle, it just stayed on the ground. This is my first CCPM heli and my first ARF heli (previous 2 heli's were already put together) so it's a learning curve. Here's some questions. 1. What should I do to get this thing to lift off the ground? Adjust the pitch? If it's that, how do I go about doing that, on the radio, adjust servo arms, something else? 2. I am using the motor that came in the box. I had to go buy a 1.5mm hex key to actually put that little screw into the pinion to secure it to the motor shaft. However, it keeps coming loose. I asked my LHS if I should loctite the pinion screw and he said I wouldn't need to (I'm guessing he told me wrong). So, should I take that screw out, put some loctite on it and hurry and screw the pinion onto the motor shaft? Is there a better way to do that? Thanks for all the help. BTW (and I'm stabbing in the wind) if anyone lives in the Seattle area and can help, I would seriously appreciate it. I'd give you my first born...well...ok, maybe not that but we could work something out.
