RE: Mechanical Retract Dilemma
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> RE: Mechanical Retract Dilemma
Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
RE: Mechanical Retract Dilemma - 10/27/2005 8:52:10 PM
macdona
Status: offline
I would prefer the 3/16th strut also.
(in reply to Furyflyer2)
       Post #: 26
RE: Mechanical Retract Dilemma - 10/27/2005 8:54:10 PM
Furyflyer2
Status: offline
They are 3/16" but how long would you like them?
_____________________________
Paul G,
www.3dxhobbies.com
(in reply to macdona)
       Post #: 27
RE: Mechanical Retract Dilemma - 10/28/2005 5:30:16 AM
saramos
Status: online
Length is a bit tougher of a question. I would think the longer the strut, the more likely it is to bend the strut out of shape on rough landings, but I don't have enough experience to suggest a length. I would most likely end up using robostruts, or some other brand of shock strut. I think it would be nice if 3/16" stubs were included in addition to the wire struts.
Scott
       Post #: 28
RE: Mechanical Retract Dilemma - 12/2/2005 4:08:41 AM
Furyflyer2
Status: offline
We are talking pre-orders, their is limited 1st run availability here is a update and info- http://www.3dxhobbies.com/cart/index.php?main_page=product_info&cPath=2_45&products_id=63
< Message edited by Furyflyer2 -- 12/2/2005 6:32:00 PM >
Paul G,
www.3dxhobbies.com
(in reply to ldelbert)
       Post #: 29
RE: Mechanical Retract Dilemma - 12/2/2005 7:50:57 PM
Red B.
Status: offline
Another alternative for very high quality mechanical retracts is available from www.einziehfahrwerk.de
There are several sizes available as well as different retract geometries. Here is a link for the 18 lbs ones, link. The end stops are fully adjustable for zero play and they are very strong.
I normally fly off grass fields and have had no problems whatsoever.
The really nice thing is that custom legs, be it oleos or piano wire, are available at very reasonable prices.
/Red B.
Click to see fullsize image.
Click for fullsize
/Red B.
       Post #: 30
RE: Mechanical Retract Dilemma - 12/2/2005 8:02:19 PM
mirwin
Status: offline
MinnFlyer,
I wonder if your new gear would work on the new 81" H9 P-47 that's soon to hit the streets. Speculation is that their included retractable gear is pretty beefy but I still like your model.
Mike
(in reply to MinnFlyer)
       Post #: 31
RE: Mechanical Retract Dilemma - 12/2/2005 8:11:13 PM
MinnFlyer
Status: offline
Mirwin, That may be in their upper range, but I don't think I would hesitate to at least TRY them.
But I would probably bore out the 3/16" strut hole to accept a 1/4" strut
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don't like them, I have others." - Groucho Marx
(in reply to mirwin)
       Post #: 32
RE: Mechanical Retract Dilemma - 12/13/2005 3:40:38 PM
Furyflyer2
Status: offline
Their is enough meat on the pivot, If their is enough interest I can bore them for a 1/4" wire for those who want them.
Paul G,
www.3dxhobbies.com
       Post #: 33
RE: Mechanical Retract Dilemma - 12/15/2005 6:05:25 AM
BigWes
Status: offline
seems to me you would want to allow for a long wire and let the consumer have the ability to trim as needed. not that I know how much extra would be appropriate.
Wes
       Post #: 34
RE: Mechanical Retract Dilemma - 12/15/2005 2:50:21 PM
Furyflyer2
Status: offline
quote:
ORIGINAL: BigWes
Wes
A long wire is included for the customer to cut..... the struts come 9" long.
Paul G,
www.3dxhobbies.com
(in reply to BigWes)
       Post #: 35
RE: Mechanical Retract Dilemma - 12/16/2005 6:26:30 AM
BigWes
Status: offline
quote:
ORIGINAL: Furyflyer2
quote:
ORIGINAL: BigWes
Wes
Well then!!! Seems to me they should get up off their wallets and buy some of your retracts. What have they to lose?
Good luck with your product!
Wes
       Post #: 36
RE: Mechanical Retract Dilemma - 12/16/2005 1:39:49 PM
Furyflyer2
Status: offline
Don't have many of these first run left.
Paul G,
www.3dxhobbies.com
       Post #: 37
RE: Mechanical Retract Dilemma - 12/16/2005 6:06:32 PM
Furyflyer2
Status: offline
Here is a pic of them
Click for fullsize
Paul G,
www.3dxhobbies.com
(in reply to saramos)
       Post #: 38
RE: Mechanical Retract Dilemma - 12/16/2005 6:14:19 PM
MinnFlyer
Status: offline
One of the things I like to point out is that they are not made of 2 extruded "L" brackets like many, but they are machined from solid, Aircraft-Grade aluminum stock.
Mike B.
       Post #: 39
RE: Mechanical Retract Dilemma - 12/17/2005 1:20:43 AM
impactiq
Status: online
You have my attention on these retracts. When will a nose gear be in the works? Also... can you provide some dimensions (Height, width, spacing of holes, depth, weight, etc....)
       Post #: 40
RE: Mechanical Retract Dilemma - 12/17/2005 1:34:34 AM
olstoney
Status: offline
Mike,
Are you going to ship me a set? I'll trade for some stone crab claws and clams Brian...
If One Lays Down With Dogs-They Should Not Complain About The Fleas
