RE: FSA Clubhouse
Tower Hobbies
Logged in as Guest
  Printable Version
JMP Firebird RTF - RTF
Seller:  volkan
Details:   $16,000.00   |  8/16/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> The Clubhouse >> RE: FSA Clubhouse
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: FSA Clubhouse - 10/20/2005 7:31:24 PM
kkling77
Status: offline
quote:
ORIGINAL: Montague
Fwiw, I have been working on a clarified version of the heli flight rules. This is a draft version. There may be changes.
- Helicopters must take off and land from the center of the runway. Putting the helicopter on the edge of the runway (just past the white line) does not provide enough seperation space between the helicopter and the pits. (This is simular to the expectation that fixed wing aircraft will take off and land roughly in the middle of the runway and should not be trying to take off and land right on the runway edge). This means that all helicopters must be carried out to the center of the runway prior to take off.
- All flying of helicopters must take place beyond the far edge of the runway, over the tall grass. This speicifically includes all extended hovering.
- After taking off from the runway, all helicopters must move directly outwards over the tall grass or to the left and then out over the tall grass. (This avoids having a helicopter depart directly across in front of other pilots in the pilot boxes).
- When landing, helicopters will always approach from the left, and land to the left of the flight boxes. (This avoids crossing directly in front of the other pilot boxes at a low altitude and close in).
- Acrobatic takeoffs (high rate of ascent, piretting, etc) shall only be done at the far left end of the runway, and only after the helicopter has taken off normally, flown, and landed at the extreme end of the runway.
- Autorotations and other acrobatic landings shall be performed as a normal landing, ie, only from the left, and not extending to the right of the helicopter pilot box.
- The helipad is for hovering only. No transitional flight or forward flight is allowed in the helipad area. The space is too small for such activity.
- When flying at the helipad, the pilot will stand with their back towards the parking lot. At no time shall the helicopter be closer to the parking lot than the pilot.
Why are people getting so bent out of shape about helicopters in general when it is in fact just one individual who people are really having a problem with? A helicopter CAN be operated just as safely as an airplane. The proposed "rules" above seem to be overkill, and in some cases absolutely ridiculous.
For instance, "All flying of helicopters must take place beyond the far edge of the runway, over the tall grass. This speicifically includes all extended hovering." I agree with this rule, however isn't this also a rule for fixed wing aircraft also? Just about every time I am at the field I see this rule broken at least a handful of times. In fact, Mr. president, I have actually seen you fly down the middle of the runway with your combat plane hit the propeller on the ground and deadstick on the runway. Afterwards you were so excited, exclaiming to others "did you see that?" If this rule is going to be enforced, than it should be enforced for EVERYBODY!! If not, than let's make it a free for all and see who can fly the fastest, lowest to the ground, and closest to the flight boxes.
The next rule, "After taking off from the runway, all helicopters must move directly outwards over the tall grass or to the left and then out over the tall grass. (This avoids having a helicopter depart directly across in front of other pilots in the pilot boxes)." Airplanes take off left and right don't they? What is the difference with a helicopter taking off left or right if it is in the center of the field? This means that we should make all fixed wing aircraft make a 90 degree turnout over the high grass as soon as they lift off so as not to cross in front of other pilots.
The next rule, "When landing, helicopters will always approach from the left, and land to the left of the flight boxes. (This avoids crossing directly in front of the other pilot boxes at a low altitude and close in)." So that means if there is a 15 mph wind from the left you still expect me to land from the left? How ridiculous does this sound. Personally I tend to land anything I fly into the wind. Again, why is it an issue to cross in front of the pilot boxes at the centerline of the field. You say "at a low altitude and close in." That isn't any closer than where fixed wing aircraft are landing.
Next rule, "Acrobatic takeoffs (high rate of ascent, piretting, etc) shall only be done at the far left end of the runway, and only after the helicopter has taken off normally, flown, and landed at the extreme end of the runway." Should we limit fixed wing aircraft to a certain 'rate of ascent' also? That's the beauty of a helicopter, YOU CAN GO STRAIGHT UP! Why is this a safety issue? Does this mean that fixed wing aircraft are not allowed to pull vertical after takeoff anymore because that is a "high rate of ascent"?
I'll say it again, address the person causing the problems. Don't make ridiculous rules that don't address the true problem.
(in reply to Montague)
       Post #: 26
RE: FSA Clubhouse - 10/20/2005 7:31:32 PM
SpitfireMKI
Status: offline
Jeff, Nope........do a search on Spitfires in the database
Irish- yeah you're right but they need to be reposted.
Albert, I know you are a safety type, I really felt sorry that you had to endure a bully when only looking out for his own good.
Now, as far as heli's go, FSA (Previously HCRC, BTW) has been primarily a fixed wing club. My association with the club began with the Hobby Store in 1997, not as a member in 2000. So I have ' been ' around awhile and have heard how things were done. That's probably longer than most on this thread and ACTIVE FLYING members.
It is tough to mix helis and fixed wing, even in the full scale world. I bet you will find most members of this club tolerate the helicopters. But when they are not being operated properly and safely, the sleeping giant will stir. CBRC banned big aerobatic planes from their field for several reasons, one being they aggravated the body membership. Everything is 120 size and under now. So my advice for the heli pilots is: Tread lightly. Not a threat, just advice. I enjoy bringing my heli from work up to FSA, I would hate to not be able too. But it may come down to this.
When Roger, the Cuban and their croanies tried to throw David and myself out of this club, they were holding secret meetings and listening to tape recorded non-member ' spywitness ' accounts of our activities. I pray that it does not come down to this BS again.
The heli pilot in concern should be dealt with by the rules and bylaws, if he has had a verbal warning, then the next is a written document, if he then fails to follow the posted rules, his membership can be terminated.
The fact that on more than one occasion he has been physically threatening is grounds for immediate dismissal as the club rules read. I know because they were written stemming from an incident between the Cuban and myself. I was verbally very rude to him but with good reason, not known to many, a year later he apoligized for his actions towards me that day. An honorable thing to do in my book.
This is a model airplane club, it is supposed to be fun. The rules that are in place are fairly reasonable, if they are followed, our safety is not compromised.
MT
_____________________________
"What madness ? What secrets ? We Plunder,
All failure, We learn from.... Discovery"
(in reply to kregan)
       Post #: 27
RE: FSA Clubhouse - 10/20/2005 7:50:37 PM
SpitfireMKI
Status: offline
To open a can of worms, the old rule for low passes was " Low passes over the runway centerline and out when the only pilot on the line flying" if other pilots are flying then they are kept out over the tall stuff. (A rule that has been re-implemented but not written, like that "No smoke system rule" .
That low pass rule was modified to slap one person on the wrist, very much like where we are going. I think as Irish pointed out, the rules are already there.
That's what I was getting at previosly: Are these not the same rules already posted ? "
As for Rocket takeoffs and aerobatic T/O's, most F/W takeoffs actually occur on either end of the flight boxes, even those great Snaps into knife edges some hot shot does . But loading blades with negative and then slamming them full positive is just asking for a devestating disaster. Sorry don't agree with that KK. There's a lot of built up energy in those blades.
Having been on the receiving end of an out of control heli three times now (due to malfunctions) , I think I have some ground to stand on.
Yes, we do need to deal with the one individual and soon.......
MT
(in reply to SpitfireMKI)
       Post #: 28
RE: FSA Clubhouse - 10/20/2005 8:04:00 PM
DrDeath
Status: offline
I think that this boils down to a simple issue of having the individual spoken to by the executive committee. Field Marshal, President and Vice president, oh, we don't really have one since he is never around, never mind. Ok just the field marshal and president then. Anyway, the issue isn't Heli's it is this one heli pilot. This thread is starting to get way out of control. There is the old adage “Guns don’t kill people, people kill people”. This is true with heli’s, in this case heli pilot! I have seen this individual auto rotate with the wind coming at his face at about 8 – 10 MPH. He tore up the snow fence twice. The issue about his flying or concern for safety really isn’t this issue alone, it is a culmination of all of the events that have transpired around this one individual for the last 6 to 9 months. Give this pilot a written warning. We also need to give that old curmudgeon that drives the white pickup truck a written warning too . Today Ralph saw him taxiing into the pits, when Ralph told him about it he started with the same crap he does when anyone chastises him about flying in the pits. This guy is unsafe! He has fallen out while flying flew almost into Keith’s head and others, planting planes in the parking lot etc. I believe it is time to put this issue to rest on RCU and deal with it internally and the club officer level.
Let’s get back to ragging on fellow members about their fictitious stories or bad flying, or loosing to rookies or other more stupid stuff.
DD
< Message edited by DrDeath -- 10/20/2005 8:13:09 PM >
My Website http://mysite.verizon.net/ldharris84/
Club Site http://www.freestateaeromodelers.org/
       Post #: 29
RE: FSA Clubhouse - 10/20/2005 8:05:16 PM
doggscube
Status: offline
OK... I'll cross-reference the trademark name. Whenever I end up at airliners.net I get distracted for a while.
This is my current wallpaper.
Jeff
Click to see fullsize image.
Click for fullsize
       Post #: 30
RE: FSA Clubhouse - 10/20/2005 8:12:15 PM
Bruno Stachel
Status: offline
Oh man, I loved that helicopter when I was a kid! I used to run up and down my backyard pushing the button making the blades twirl. The copter is buried in hundreds of feet of trash by now, but I still have the GI Joe figure (the same one in your pic).
quote:
ORIGINAL: Advent
Ok, for the sake of peace on RCU I will post over here.
My take on this heli thing....
Our pit boxes are to close to the shelter, without redoing the whole field
I think the heli guys should walk the aircraft to the center of the field and fly
from a box.
If the Heli had been placed at the center of the field and the pilot forced to
stand in the flight box, I don't believe the flight would have happen...
it was so dark there is no way he would have tried from a safe distance.
Click for fullsize
< Message edited by Bruno Stachel -- 10/20/2005 8:15:01 PM >
       Post #: 31
RE: FSA Clubhouse - 10/20/2005 8:55:32 PM
Spirit In The Sky
Status: offline
Are you guys hiring I want to work with kelly his job site is cool and so is his new airplane. I will tell you guys this about Helis, I am learning to fly one but it will always no matter what or how good I get with it stay home and I will never bring a Heli to the field. I do have one question though, how can you sneak one in prison because after I kill the dog and cut off my wifes head and completly disfigure my home with this electric marvel I am sure my Irish ass will be locked up for many years............LMAO
John, B.A.C.C. member since 2007
Flying at FSA? We got your B.A.C.C. !!!
       Post #: 32
RE: FSA Clubhouse - 10/20/2005 9:06:56 PM
SpitfireMKI
Status: offline
You know DD, when things get heated you want to play politician, how about giving the Kirkster a run at the head spot ?
SCREW HELICOPTERS !
Heheheheheheheheheheheheeeee !
You got to admit, as dangerous as they are, love to watch em' tear themselves to pieces when they crash
MT
(in reply to Spirit In The Sky)
       Post #: 33
RE: FSA Clubhouse - 10/20/2005 9:13:04 PM
Spirit In The Sky
Status: offline
Ok I need some input on color and design schemes on my 540 Edge. I got all of the covering off and I am now ready for some covering. I am interested in any ideas that you guys may have and or links to design and color schemes. Thanks guys
       Post #: 34
RE: FSA Clubhouse - 10/20/2005 9:23:40 PM
doggscube
Status: offline
Find some pictures of a full-scale. That's what I did with my small Corsair, I sat down with the decal sheet and Google image search until I found one that I could replicate with the decals on hand. Is this the electric or a larger one?
I wouldn't worry about your heli. It's not so much the crashes but the reckless flying and belligerent attitude behind them that are the problem. If I ever end up with one of those E-flite Blades I'll bring it to the field.
-Jeff
< Message edited by doggscube -- 10/20/2005 9:26:34 PM >
       Post #: 35
