kpm
MD, USA Status: offline
This is from the Futaba 7c Fasst Manual. They also have a very specific picture on the recommended position. See page18. http://manuals.hobbico.com/fut/7c-2_4ghz-manual.pdf *********** Transmitter Antenna 1. The transmitter antenna is adjustable so please make sure that the antenna is never pointed directly at the model when flying as this creates a weak signal for the receiver. 2. Keep the antenna perpendicular to the transmitter's face to create a better RF condition for the receiver. Of course this depends on how you hold the transmitter, but in most cases, adjusting the transmitter antenna so that it is perpendicular to the face will give the best results. Please adjust the transmitter antenna to the way you hold the transmitter. 3. NEVER grip the antenna when flying as this degrades RF quality. ************ quote:
ORIGINAL: SpitfireMkII quote:
ORIGINAL: kpm Now the Futaba Fasst manual specificaly states what position the antenna should be in for best reception. That is a good thing because it gives the end users a good point of reference. quote:
ORIGINAL: SpitfireMkII I'm still curious why it would be used with the antenna sideways.........what is the logic ? We've had one system that has been flakey with ground testing, I tried a different TX and it seemed to work better, at least the attenuated range check was back on our spec. Out on the tarmac doing full range checks I again found it was not acting in what we would consider a "normal" manner. The plane flew and there were no issues but I have now replaced the RX in an effort to get it back to what we see as "normal" performance. That is the only trouble I have seen at the office. At homebase, when I set up the DvII we had noise from the ignition getting into the RX via the battery (an amplifier) and servos. We moved the battery and I changed all the control surface servos to digital. Apparently, digitals have additional filtering (?) to prevent feedback to the RX. She's been solid since. The 2.4 is the best step towards a safe and happy flight yet, still we have to set up the plane properly and use our limited radio knowledge to insure the system performs properly. Which direction is that ?
_____________________________
Sam
