Montague
That looks great, Kelly. I'm sure you'll get that stuff figured out. I'm going to be shooting some clear coat on my tiger moth real soon now, I think. This weekend, I finally managed to get the "how fast" and "how high" packaged together on to a bit of scrap balsa that I can tape to the underside of a wing and take readings from. I was playing with my LT-40, and was surprised by some of the numbers recorded. I took the plane way way waaaaaaaaaaay up there. The "how high" claimed just over 1,700ft, which makes sense, it was really small. Cruising around at about "normal" training altitude, it was recording between 240 and 320ft (I took several samples). Once the plane was way up there, I did a terminal velocity dive with power off, and recorded 90mph. I also recorded 90mph in a full throttle dive at a moderate angle. I didn't get a level flight max speed. But I did get a couple of readings around 20mph while parking the plane in the high winds, and one around 15mph just before stalling. Cruising back and forth at low throttle was mostly reading around 40-45mph, which is about right. I'll play with it some more and then move it to some other planes to see what they read for comparison. I'm wondering how high up the Wild Hare gets during a normal IMAC routine, for example. And, of course, I need to ge the airspeed of the Mossie. And anyone else wants to try to readings from their planes.
< Message edited by Montague -- 5/5/2008 5:04:38 PM >
_____________________________
Kirk Montague Adams RCCA 560
