EdMan-RCU
Joined: 3/5/2002 From: tallahassee, FL, USA Status: offline
I checked out the I4C Digital Voltmeter. WOW, at $60 its alittle expensive. I noticed it puts either a 500mah, 1amp, 1.5 amp load on the pack. That seems a bit much, doesn't it? The Hobbico only puts a 250mah load.......... What is the proper load for a standard 5 servo draw? Whats inaccurate about the Hobbico voltmeter? Does it not read proper voltage, or is it the load it puts on the pack? How bout the old loaded analog meters, they just state they put a standard R/C load on the pack. Are they know to be inaccurate? My old one never failed me, it's just that it's about had it. (I have to thump it to get it to read the pack, then it seems to be intermittent ) Anyways, I just would rather upgrade to an digital. Thanks Again, EdMan
