RE: Great Planes Giant Ugly Stick    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: Great Planes Giant Ugly Stick
Page: <<   < prev  11 12 13 14 [15] 16 17 18 19 20   next >   >>
Login
RE: Great Planes Giant Ugly Stick - 10/22/2012 3:31 PM
underh2o2long
Score: 100
Last Login: 5/22/2013
Status: offline
No, you don't have too... its a vent line. When you remove the gas at the end of the day the fuel will be sucked back in so there should not be any leaking or dripping.....
Hide Signatures
(in reply to sgrady)
       Post #: 351
RE: Great Planes Giant Ugly Stick - 10/22/2012 3:33 PM
Super08
Score: 135
Last Login: 5/25/2013
Status: offline
No I don't mine are all stored out in the garage. I also store mine with the tanks at least 1/2 full. It depends on your situation. I have a friend that stores his in the house so he drains the tanks dry but does not cap the vent.
_____________________________
Quote: Hey, who put that tree there?
Ultra Sport brotherhood #125
Hide Signatures
(in reply to Hoghead385)
       Post #: 352
RE: Great Planes Giant Ugly Stick - 10/22/2012 3:44 PM
sgrady
Score: 100
Last Login: 5/14/2013
Status: offline
I leave fuel in mine all winter.  I was told it keeps the tank lines from "drying out"  The fuel I use does not have ethanol though, if you do< I would not leave the fuel in there.
Hide Signatures
(in reply to Super08)
       Post #: 353
RE: Great Planes Giant Ugly Stick - 10/23/2012 12:59 AM
mnourse26
Score: 100
Last Login: 2/23/2013
Status: offline
Hey guys glad to see this fourm is doing good. So i have been flying my gus for a while now it has the 55 dle on it and having a blast. But i have noticed that it does shake the plane like crazy! I was thinking about replacing it with a twin 40cc rcgf and using the 55cc for somthing eles. heard the twins have lower vibration. Is that true? I will finish the year on the 55 just wondering what your thoughts were. Thanks
Hide Signatures
       Post #: 354
RE: Great Planes Giant Ugly Stick - 10/23/2012 2:21 AM
Super08
Score: 135
Status: offline
Yes the twins less vibration. You can also run tail brace wires to stop the tail from shaking so much. The 55 is bordering on too much power albeit fun, I had one set up with a 55 last year. I went back to the DLE30 as I find it flys better with a bit less weight and it has much more prop clearance.
Hide Signatures
(in reply to mnourse26)
       Post #: 355
RE: Great Planes Giant Ugly Stick - 10/23/2012 3:48 PM
Hoghead385
Score: 100
Last Login: 2/24/2013
Status: offline
Thanks for all the replies folks. Super08, like the Williams Bros tires on you GUS, what size are they? Really set the plane off.
Hide Signatures
       Post #: 356
RE: Great Planes Giant Ugly Stick - 10/23/2012 4:08 PM
Super08
Score: 135
Status: offline
They are the Dubro version. 4.66".
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPJZ2&P=7
Hide Signatures
       Post #: 357
RE: Great Planes Giant Ugly Stick - 10/23/2012 6:29 PM
opjose
Score: 280
Last Login: 5/24/2013
Status: offline
If you want an even better look try these instead: Click me!
Don''t worry, be happy and fly something!
Hide Signatures
       Post #: 358
RE: Great Planes Giant Ugly Stick - 10/23/2012 9:18 PM
Hoghead385
Score: 100
Status: offline
Wow opjose, now those are cool too! Decisions, decisions?
Hide Signatures
(in reply to opjose)
       Post #: 359
RE: Great Planes Giant Ugly Stick - 10/24/2012 2:42 AM
Gizmo-RCU
Score: 100
Status: offline
I have Dubro 5" Tundras on mine, they also help prop clearance. They work very well on grass and uneven ground.
Gizmo
Hide Signatures
       Post #: 360
RE: Great Planes Giant Ugly Stick - 11/20/2012 5:45 AM
Hoghead385
Score: 100
Status: offline
Just checking in and updating my progress on the GUS. Wings, tail surfaces, main gear, engine (DLE 35) mounting complete. Need to mount tank, ignition box/battery along with receiver battery and button up the internals. Waiting delivery of spinner and props so I can do my first CG check and see where I'm at. Bird went together pretty easily but the covering was a nightmare. I spent a great deal of time shrinking and trying to iron things down the best I could. Hope to get it in the air before the weather craps out, we'll see!
Hide Signatures
(in reply to Gizmo-RCU)
       Post #: 361
RE: Great Planes Giant Ugly Stick - 11/20/2012 2:28 PM
Super08
Score: 135
Status: offline
The covering on my latest one was so bad I gave up and recovered the stab and elevator.
< Message edited by Super08 -- 11/20/2012 4:59 PM >
Hide Signatures
       Post #: 362
RE: Great Planes Giant Ugly Stick - 11/20/2012 6:08 PM
opjose
Score: 280
Status: offline
quote:
ORIGINAL: Hoghead385
I find that having both an iron and a heat gun helps with ARFs.
Often trying to use an iron alone can be frustrating.
I'll go over seam and edge points with an iron, then use the heat gun to get rid of bubbles and tighten up the covering.
This worked very well with my Big Stik.
Hide Signatures
       Post #: 363
RE: Great Planes Giant Ugly Stick - 11/21/2012 11:01 PM
Hoghead385
Score: 100
Status: offline
I used an iron and gun also but it's a 20 footer! Must have been covered on a Monday? Happy Thanksgiving to all!
Hide Signatures
       Post #: 364
RE: Great Planes Giant Ugly Stick - 11/23/2012 6:03 PM
Hoghead385
Score: 100
Status: offline
Did my initial CG check while I had the GUS assembled with all the batteries/ignitiion gear in the nose behind the firewall. I'm using the aft position under the wing leading edge for my tank location. I'm happy at this point, will need about 6 ounces to bring it to the 5 7/8 - 6" location suggested in the manual. I'm using the DLE 35 with stock stand-offs/muffler and Tru-turn big bird spinner.
Hide Signatures
       Post #: 365
RE: Great Planes Giant Ugly Stick - 1/1/2013 2:29 PM
TunnelBill
Score: 100
Status: offline
I'm on a budget and was looking for ideas on what servos to get? Open to any ideas. Thanks Bill
Hide Signatures
       Post #: 366
RE: Great Planes Giant Ugly Stick - 1/1/2013 4:14 PM
Gizmo-RCU
Score: 100
Status: offline
Hi Bill,
I have been using Dymond 5000 servos, metal gear, BB, 125 oz. and at $15.00 ea. these standard size servos have worked well for me on several projects. My GUS has a 40 cc and the servos have worked for my style of flying which is
not really severe but putting the plane thru it's paces.
Gizmo
Hide Signatures
(in reply to TunnelBill)
       Post #: 367
RE: Great Planes Giant Ugly Stick - 1/7/2013 6:12 PM
TunnelBill
Score: 100
Status: offline
This thread is slow....
I am building one, I was going to try the RCG 26cc motor I have. I know it is a low power motor but just looking for a sport plane. What do you guys think about the motor, will it work?
Bill
Hide Signatures
       Post #: 368
RE: Great Planes Giant Ugly Stick - 1/7/2013 7:01 PM
opjose
Score: 280
Status: offline
You should be just fine.
Prop the plane for maximum thrust, not speed.
The Stik is not a pylon racer anyway...
If you keep the plane light you'll even be able to hover it at altitude.
Your biggest problem will be getting the C.G. right ( note the manual has it a bit further forward than what I fly it at... )
I suggest putting your packs, choke and throttle servos, and ignition module in the provided compartment, just aft of the firewall.
I put my tank on the spar ( there are two tank mounting locations in the plane ) as this prevents fuel levels from affecting flight characteristics.
I went with a 30cc Syssa engine as I knew I was going to target the heavier side ( big batteries ).
Hide Signatures
       Post #: 369
RE: Great Planes Giant Ugly Stick - 1/7/2013 7:49 PM
TunnelBill
Score: 100
Status: offline
I plan on mounting everything forward. I was going to move my Elev & Rud servos forward in the plane and run Carbon Fiber push rods back to them. I do not like the tail wheel so I ordered a carbon fiber tail wheel and will run pull-pull cables to the tail wheel. I'm going to use robart 1/8 hing points on everything. Do you have to use epoxy on the hinge points or is it OK to use white glue or Tite bond II wood glue?
Bill
Hide Signatures
       Post #: 370
RE: Great Planes Giant Ugly Stick - 1/7/2013 7:58 PM
phakur
Score: 100
Status: offline
Be a bit careful about robart hinge pointsmuch of the internal support isn't there. If you are not intending on opening up the covering and adding blocks of wood (I didn't) then I would suggest using epoxy and squirt enough extra in there to form sort of a bulb at the end of the hinge point so that it for sure would not come out.
That's what I did and it seems to be holding up well for the year I have flown the plane.
I happen to like the servos in the rear, your choice.
If I had it to do over though, I would extend the engine out a bit further to help with balance. I am using a DLE 30 which is pretty light and had to add over a pound of lead up front to balance.
I think moving the engine out perhaps a half inch or so would help trmendously.
Larry
Hide Signatures
       Post #: 371
RE: Great Planes Giant Ugly Stick - 1/9/2013 2:36 AM
SCOTT42
Score: 105
Last Login: 5/21/2013
Status: offline
Hello all, I have this plane and just now getting started on putting it together, now im at a loss on what to do about the powerplant for this plane. I have a new OS 1.60 with a pitts bison muffler, also have a zenoah G-45 gas engine and not sure which to use. Now in all reallity I want to use the gas engine but not sure if it weighs too much for it. I really cant afford to just go out and buy a new DLE for it like most of you guys are running on yours, so whats the best choice for what I have to work with? My style of flying is balls to the wall when I can.
Cub brotherhood #113
Hide Signatures
(in reply to phakur)
       Post #: 372
RE: Great Planes Giant Ugly Stick - 1/9/2013 2:48 AM
phakur
Score: 100
Status: offline
I think the 45 is a heck of a lot of engine for this planebut I don't think it will be too heavy.
It flys great with a 30 cc.
Hide Signatures
(in reply to SCOTT42)
       Post #: 373
RE: Great Planes Giant Ugly Stick - 1/9/2013 8:17 PM
opjose
Score: 280
Status: offline
I had the both the Syssa 30cc and the Zenoah G-45 available when I was putting mine together.
I went with the 30cc.
The Zenoah is a relatively heavy engine and it is larger than the fuselage.
A 26cc is closer to what the manual calls for power wise, but that seems a bit underpowered to me.
Hide Signatures
       Post #: 374
RE: Great Planes Giant Ugly Stick - 1/9/2013 10:09 PM
proteus_X3
Score: 100
Status: offline
SCOTT42
I think you'll be  Ok with your G45 it is only slightly heaver 78oz  than the Fuji 32 ccBT [72 oz] called for in you manual,of coarse the G45 is more powerful so throttle management is required.
On mine I didn't move the elevator or rudder servos forward next to the throttle servo,I did place both of my batteries a 3800mah life for my servo and receiver and a 2000mah nmh for the engine ignition.My powerplant is a DLE 35RA and to get the aircraft's CG at the recommended staring point of 150mm I still needed to add 11.7 oz  lead at the firewall. maybe with the your G45 you willn't need any weight  up front.
Cheers: Rich
Hide Signatures
       Post #: 375
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.594RCU1
