Great Planes Giant Ugly Stick    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> Great Planes Giant Ugly Stick
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
Great Planes Giant Ugly Stick - 10/21/2005 9:41 PM  1 votes
hookemut
Score: 105
Last Login: 9/5/2009
Status: offline
Greetings,
Several factors prompted me to consider adding another model to my fleet. These factors were:a) the cost of glow fuel, and b) my fondness for the Zenoah G-23.
So not surprising, I acquired one of the newly released GP Giant Ugly Stick.
There has been a number of posts wrt this model, but I haven't seen one using the G-23, which I have done. I mounted the G-23 with a 1/4 inch standoff plate. Subsequently I had to add 8oz. of weight just aft of the firewall-suggests that G-23/G-26 users might use a 1/2 to 3/4" mounting standoff.
The model is VERY well assembled, with aluminum 'L's screwed in place at the firewall and landing gear plates. Flight tests were a real pleasure! The model is a hoot to fly, and practically lands itself! My G-23, swinging an APC 17x6 prop, flies the Stick at half throttle. I did add a tapered shim under the landing gear which effectively moved the landing gear axles forward-the kitted location of the landing gear is too far aft.
Cosmetically, GP has the poorest covering ever at the ailerons, flaps, elevator, and rudder. The covering on these surfaces has massive amounts of wrinkles which defy all attempts at ironing or blowing them smooth. Still, the Giant Stick is a great addition and I look forward to many flights.
Hide Signatures
       Post #: 1
RE: Great Planes Giant Ugly Stick - 10/21/2005 10:25 PM
pettit
Score: 125
Last Login: 5/23/2013
Status: offline
My Giant Big Stik flys well with a G-26. No added weight on nose, battery just behind fuel tank. 12.6 pounds ready to fly minus fuel.
Try coupling flaps to elevator, up elevator/down flaps and vice versa. Loops are tiny! Both ways, inside and outside.
Click to see fullsize image.
Click for fullsize
_____________________________
Dick Pettit
WACO Brotherhood #168
If You Can Not Stand Behind Our Troops, please Feel Free To Stand In Front Of Them!!!!!
Hide Signatures
(in reply to hookemut)
       Post #: 2
RE: Great Planes Giant Ugly Stick - 10/28/2005 1:17 AM
tlnibert
Score: 100
Last Login: 8/31/2012
Status: offline
I have the Big Stick on the way, is there away to make it triclcle with a Zenoah 38 engine
Thomas
Hide Signatures
(in reply to pettit)
       Post #: 3
RE: Great Planes Giant Ugly Stick - 10/28/2005 1:21 AM
d_wheel
Score: 100
Last Login: 5/25/2013
Status: offline
Where are you guys getting the giant stiks? They are still on back order status from Tower.
Later;
D.W.
Gettin'' old ain''t for sissies.
Hide Signatures
(in reply to tlnibert)
       Post #: 4
RE: Great Planes Giant Ugly Stick - 10/28/2005 2:50 AM
tlnibert
Score: 100
Status: offline
Local hobby shop sells them for $219 plus tax. He usually drops the price another 10 percent.
I don't care much for tail draggers, I want a Zenoah G-38 or Ryobi 31. Instructions suggest tail wheel with gas.
I don't pick up the kit for a few days, so I have check it out yet.
Thomas
Hide Signatures
(in reply to d_wheel)
       Post #: 5
RE: Great Planes Giant Ugly Stick - 10/28/2005 2:52 PM
pettit
Score: 125
Status: offline
No room for the nose wheel bushing to be mounted on the bottom of the firewall with G-38, or G-26 either.
Dick Pettit
Hide Signatures
       Post #: 6
RE: Great Planes Giant Ugly Stick - 10/28/2005 3:48 PM
scottfl78
Score: 110
Last Login: 5/2/2012
Status: offline
My guess is that there are not that many G-23's around just G-26's.. When I heard of the release of the Giant Stik I knew it would sell.. My 40 and 60 size were great flying planes!
Scott
Fort Worth Thunderbirds
Hide Signatures
       Post #: 7
RE: Great Planes Giant Ugly Stick - 10/28/2005 4:03 PM
tlnibert
Score: 100
Status: offline
I learn to fly with the original Jensen Ugly Stick in 1972 and I'm fly a 40 size Stick now. I've been flying it for two years. I pickup an OS 61 for it yesterday.
Has anyone tried using the stand off mount with a gas engine??? I see that you can get one for it. I won't have my Stick until Wed.
Thomas
Hide Signatures
(in reply to scottfl78)
       Post #: 8
RE: Great Planes Giant Ugly Stick - 10/28/2005 8:05 PM
pettit
Score: 125
Status: offline
The majority of gas engines in use today have backplate mounts. The further you put the engine forward, the more tail weight you'll need to balance.
Here's mine with a G-26, which will hover this plane at 12.5 pounds.
Take off the restrictive stock muffler and replace it with a high flow type and unlimited veritcal may be possible
Click for fullsize
Dick Pettit
Hide Signatures
       Post #: 9
RE: Great Planes Giant Ugly Stick - 10/28/2005 8:24 PM
d_wheel
Score: 100
Status: offline
tlnibert ,
What is the phone # for your lhs?
Later;
D.W.
Hide Signatures
       Post #: 10
RE: Great Planes Giant Ugly Stick - 10/28/2005 8:39 PM
Don M.
Score: 100
Last Login: 3/11/2013
Status: offline
I am considering one of these for my Saito 270 twin, am I crazy or is it doable ?
I can only please 2 people every day and #2 just left.
Hide Signatures
       Post #: 11
RE: Great Planes Giant Ugly Stick - 10/28/2005 11:58 PM
tlnibert
Score: 100
Status: offline
A friend is selling me a Zenoah G-38 that I plan on using for the Stick. I have a new G-26, but thought it would be to small.
I haven't seen on of the Sticks yet. I was planning on mounting the nose gear bearings on the inside of the firewall to give me clearance for the motor. Not having seen one, I can't do much planning.
Tom
Hide Signatures
(in reply to Don M.)
       Post #: 12
RE: Great Planes Giant Ugly Stick - 10/29/2005 3:41 AM
hookemut
Score: 105
Status: offline
quote:
ORIGINAL: tlnibert
Tom
Hi Tom,
My G-23 is very adequate for this model-I seldom go over 1/2 throttle! Dick Pettit hovers his using a G-26. One of my flying buddies performed a full rolling circle with my Giant Stick. IMHO, you would be delighted with your G-26 up front!!
Go for it!!
Jim
Hide Signatures
       Post #: 13
RE: Great Planes Giant Ugly Stick - 10/29/2005 4:22 AM
uncleTom
Score: 105
Last Login: 4/7/2013
Status: offline
I have one with a Brison 2.4 and a 20x8 prop sweet, needs taller gear with this combo. Also still had to add some weight to the fire wall with stand offs too!
Tom Jenkins
Hide Signatures
       Post #: 14
RE: Great Planes Giant Ugly Stick - 10/29/2005 4:27 AM
tlnibert
Score: 100
Status: offline
I'll try a 3/4 stand off plate to clear the wheel bearing or move the bearing inside the body. I've never care much for tail draggers.
The post are helpful.
Did anyone us a switch to shut off the engine by radio.
Tom
< Message edited by tlnibert -- 10/30/2005 1:24 PM >
Hide Signatures
(in reply to uncleTom)
       Post #: 15
RE: Great Planes Giant Ugly Stick - 10/30/2005 4:06 AM
tlnibert
Score: 100
Status: offline
Guys, don't know what I do until I see the plane. Not sure on which engine yet after hearing about the G-26 being so great.
Thomas
Hide Signatures
       Post #: 16
RE: Great Planes Giant Ugly Stick - 11/4/2005 2:28 AM
tlnibert
Score: 100
Status: offline
I got the Big Stick and I don't see any problem with using a gasoline engine and tricycle landing gear. I've already mounted the nose wheel bearing inside the tank area.
Tom
Hide Signatures
       Post #: 17
RE: Great Planes Giant Ugly Stick - 11/4/2005 7:44 PM
d_wheel
Score: 100
Status: offline
Once again, where are you guys getting your giant stiks? I want one but can't find anyone who has them in stock. Phone numbers please!!
Later;
D.W.
Hide Signatures
       Post #: 18
RE: Great Planes Giant Ugly Stick - 11/4/2005 7:50 PM
pjw_75
Score: 100
Last Login: 4/24/2009
Status: offline
You can try :
Trains & Planes Toys and Hobbies: Main Store
(713) 974-1277
(713) 977-1420
8914 Westheimer Rd
Houston, TX 77063
They usally do 10 percent off Tower prices
www.downonthedeck.com
Hide Signatures
       Post #: 19
RE: Great Planes Giant Ugly Stick - 11/4/2005 10:30 PM
d_wheel
Score: 100
Status: offline
Thanks pjw_75 ,
Called and they don't have them. Anyone else?
Later;
D.W.
< Message edited by d_wheel -- 11/4/2005 11:13 PM >
Hide Signatures
(in reply to pjw_75)
       Post #: 20
RE: Great Planes Giant Ugly Stick - 11/5/2005 2:01 PM
tlnibert
Score: 100
Status: offline
I've started my Giant Stick, it looks great. I need details on how to rig the engine kill switches, one by radio and the other a manual switch on the outside. I'm going with a Zenoah G-26 or G-38.
Thomas
Hide Signatures
       Post #: 21
RE: Great Planes Giant Ugly Stick - 11/6/2005 2:35 AM
cadconversions
Score: 105
Last Login: 3/20/2013
Status: offline
I had thought about using a roto 35vi on one with the great planes motor mount that would allow nose gear. As long as the gasser uses beam mounts (MVVS / Evolution, Roto, RCS) nose gear wouldn't take any reworking.
Kevin
Hide Signatures
       Post #: 22
RE: Great Planes Giant Ugly Stick - 11/6/2005 2:44 PM
tlnibert
Score: 100
Status: offline
Many years ago when we installed the nose wheels bearings inside the fuel tank compartment. I look the giant Stick over and I don't see any problems. I'm mounting the back wing and tail today, so I should be working on the engine soon. I don't know yet if I'm using a G-26 or G-38.
Tom
Hide Signatures
(in reply to cadconversions)
       Post #: 23
RE: Great Planes Giant Ugly Stick - 11/6/2005 4:11 PM
NM2K
Score: 161
Status: offline
quote:
ORIGINAL: pettit
So mount it on the back of the firewall.
I didn't say it would be easy. <G>
"Practice makes prefect"
Hide Signatures
       Post #: 24
RE: Great Planes Giant Ugly Stick - 11/6/2005 5:17 PM
4 stroken ron
Score: 100
Last Login: 2/17/2012
Status: offline
So move the mains forward and mount the steered wheel in the rear. Where it belongs.
All sticks should be tail draggers.
Ron
Hide Signatures
(in reply to NM2K)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.125RCU1
