RE: Building a Bonanza
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Building a Bonanza
Page: <<   < prev  6 7 8 9 10 11 12 [13] 14 15   next >   >>
Login
RE: Building a Bonanza - 1/26/2008 1:04:16 AM
jetmech43
Status: offline
Ok guys im having a problem using the vtail function on my 9c do you need some sort of servo reverseer to make it work, im using channel 2 and 4 like the book says but just not working properly
_____________________________
smooth pass
(in reply to Grotesquebass)
       Post #: 301
RE: Building a Bonanza - 1/26/2008 2:03:21 AM
jetmech43
Status: offline
ok Im assuming on the full scale vtail acts like ailerons when rudder is applied
smooth pass
(in reply to jetmech43)
       Post #: 302
RE: Building a Bonanza - 1/26/2008 4:57:27 AM
Beechbum
Status: offline
Jetmech, I had a Bonanza for just over ten years. I remember moving the tow bar to the left would raise the left ruddervator, but it seems like it only came up to, or just above neutral. The yoke was a rest in a full forward position. The right, as I recall, would deflect a little bit further down. ( Its been a long time, my memory is a bit fuzzy!) Most of the time I checked the rudder during flight control checks with the yoke forward, hands off, not in the elevator neutral position. This was to let the yoke move and check the aileron interconnect. I always assumed the ruddervators moved in equal, and opposite directions if the control yoke was in an elevator neutral position. I seem to remember full up elevator, and full left rudder input would lower the right ruddervator, and the left would stay full up. There was a totaly cool system of cables, springs and levers to mix this all together. In flight it control input worked just like any other "normal" aircraft. Maybe this answers your question. Hope so.
       Post #: 303
RE: Building a Bonanza - 1/26/2008 5:21:34 AM
jetmech43
Status: offline
well I do have some time in an A36, but not a vtail
smooth pass
(in reply to Beechbum)
       Post #: 304
RE: Building a Bonanza - 1/27/2008 1:32:49 PM
teamscalepilot
Status: offline
Hey guys !! all the parts for the Barron 55 will fit the TF Bonanza. Speed slope canopy, gear doors.
       Post #: 305
RE: Building a Bonanza - 1/27/2008 4:39:53 PM
jetmech43
Status: offline
the problem im having is I cant get the servoes to move in the opposite direction when rudder is applied, and the same direction with elevator imput
smooth pass
(in reply to teamscalepilot)
       Post #: 306
RE: Building a Bonanza - 1/27/2008 7:00:39 PM
Beechbum
Status: offline
Sorry, kind of got off on the full size, there. I cann't help with the 9C programming. Perhaps the manufacturer suport guy can help you over in the radio forum.
Teamscale has a good product. I got his parts for the Baron build. Good stuff.
       Post #: 307
RE: Building a Bonanza - 1/27/2008 8:02:08 PM
jetmech43
Status: offline
I got it figured out
smooth pass
       Post #: 308
RE: Building a Bonanza - 1/27/2008 8:26:36 PM
jetmech43
Status: offline
anybody do any mods to theirs they would like to share, I replaced the push rods with carbon fiber ones
smooth pass
       Post #: 309
RE: Building a Bonanza - 2/10/2008 8:52:10 PM
jetmech43
Status: offline
anybody out there in Bonanza land know what color this is
Click to see fullsize image.
Click for fullsize
smooth pass
       Post #: 310
RE: Building a Bonanza - 2/10/2008 11:25:48 PM
ShortField
Status: offline
I'm not sure what color it is but here is a link from the F.A.A. Registry for the owner of that airplane. You can contact the owner and find out.
http://registry.faa.gov/aircraftinquiry/NNumSQL.asp?NNumbertxt=96RF&cmndfind.x=18&cmndfind.y=13
RunWay? What RunWay??
       Post #: 311
RE: Building a Bonanza - 3/24/2008 6:46:51 AM
frequent flyer
Status: online
Well, This is a great thread , I bought a kit a few months ago when I saw them at Tower Hobbies, always wanted a V-Tail. I'm half way through the build and I am also putting a 91FX in it . About the Muffler I am installing a custom Made in cowl muffler I mad from one of the TF muffler connected to a second one on the other side of the engine connected by a cross over tube. This gave me the need volume for the larger engine and it runs cool in my testing of 3 hours. It also give me dual exhaust ports. I think it even improved the sound.
I am even thinking of possibly trying to fit the 120 FX with this custom dual exhaust set up. All aluminum .049 wall tubing tig welded and I think the weight of the 120 would even ballance the bird a little better. I'll post some Pictures as soon as I have time to do it for you guys that are into this plane.
I always like to have power to spare.
Frequent Flyer
Waco brotherhood #91
FREQUENT FLYER
(WACO BROTHERHOOD # 91)
(in reply to ShortField)
       Post #: 312
RE: Building a Bonanza - 3/24/2008 2:48:37 PM
ShortField
Status: offline
I would really like to see your pictures of your custom muffler. I have not started my build yet and have not bought an engine yet either. I've been thinking of the O.S. 75 but if your custom muffler looks good I might use your idea. I have access to a welding shop. I did get the in cowl muffler and the TF exhaust header. I've been collecting everything I need for the build and was going to wait till this fall to start.
(in reply to frequent flyer)
       Post #: 313
RE: Building a Bonanza - 3/24/2008 4:22:02 PM
jetmech43
Status: offline
yes so would I mine is almost ready to go except for the muffler thing
smooth pass
       Post #: 314
RE: Building a Bonanza - 3/24/2008 11:11:28 PM
teamscalepilot
Status: offline
check the thread on the Barron 55 for the pictures of tie Speed Slope windshield.
