Brian_in_IN
IN, USA Status: offline
quote:
ORIGINAL: mglavin I duplicated all your programmed parameters with my Optic 6 and I do not have the flap up condition you’re experiencing. Let’s eliminate the variable associated with the flap slider position. Move the slider all the way up and re-center the servos arms and see what happens. Your EPA settings for aileron/flap at 40% seem rather LOW? What kind of model is this? I am using the ailerons for flaps, I dont have flaps. Seems to me that if I setup the servos as you say, then my servos wont be in their natural neutral position. Correct me if I'm wrong, but I dont think my servos have 180 degrees of rotation, so if I start out with them turned partially one way, then they will have more travel one way then the other, and also might hit the stop when going the way that they are past center??? And with less then 180 degrees rotation, how can I get the servo horn to be perpendicular to the control surface hinge?? My servos have never been able to turn 180 degrees. My plane is a .46 Cap 232 and can be seen in my gallery pics at http://www.rcuniverse.com/community/profile.cfm?section=gallery&memid=42412 .... Now remember, the Optic 6 is new to me and this is the first plane I am setting up in it. I had a Focus 4 and Focus 6 before this radio, so this is all new to me. I have the manual, but it is a bear to follow when you're first learning. And just for the record, it does great at telling how to program it, but lacks in telling how to use it. ie ... the 3 different flight modes, where in the manual does it cover what you can do with this?? I adjusted the epa for the ailerons to 40% because they have ALOT of throw and this is my first aerobatic plane, and I dont want it to be so sensitive where I am over "steering" for lack of a better term. SO I figure I can fly it like this, get used to it, and then adjust the epa higher as I gain experience. Sound like a good idea??. well enough for now. I'll reply again with more later. Brian
_____________________________
Brian in IN Fly what you like and like what you fly
