bob27s
OH, USA Status: offline
Hey Jack, Thanks for writing.... Ive actually had a few inquiries from people on the Mojo 60 lately, and a few about the bigger OMP birds. Jett builds four engines that are specifically built for aerobatics, fun-fly and 3D applications. Big props - lower rpm - light weight - lots of power. The SJ-60LH (hover version) and the BSE-76L are both "40" size engines. The 60LH turns 12x4 size props around 14,000 (with a lite-jett untuned muffler), and the BSE-76L turns 14x4 and 14x6 props up around 10-11K rpm (with the same muffler). Yes, these are "OS.46" size engines. For your application, the BSE-100L and BSE-120L engines are ideal. These are the same size/appx weight as the OS61/91FX engine - same bolt pattern - but they are designed for some outstanding top end power at lower rpm with big props. The BSE-100L would be more at home with the 15x4. It will turn that up around 12,500 rpm. The engine typically turns a 15x8 prop around 10,000. This engine you would want to keep propped between 9500 - 13,000 peak rpm on the top end. Higher rpm is not recommended. The BSE-120L is a real monster. Same size. This turns a 16x8 at 9500 rpm. Makes its best power between 9000-10,500 rpm. Definately not a high rpm engine - Prop the engine with a peak top end rpm not exceeding 11,500 rpm on the ground. For 3D stuff, folks have found that a 16x6 works very well. A 15x4 is too small. Some folks are running 17x6 and 18x4 props (although Im not sure where they got the 18x4 props from). The 100L and 120L are supplied with the jett-stream tuned muffler, but pipe-step is not an issue at these lower rpms - the pipe stages smoothly. All of these engines are prepared with special carbs that give outstanding midrange performance and smooth transition. Break it in, set it up with the flight prop, set the high end needle about 500 rpm down from peak, and enjoy ! I hope this is helpful. Bob
_____________________________
Bob Brassell Jett Engineering - Engine Mfg Support Forum Host
