jimk2
Joined: 8/13/2005 From: Houghton Le Spring, UNITED KINGDOM Status: offline
quote:
ORIGINAL: saintlouis I made my shock spacers like this. in this way i will save my shock caps from lose threading during high impact landing on high jumps. (The black plastic strap will prevent pressure from the spring to go through the shock caps) The collar on the black plastic strap has to be cut or remove so you will need an extra black plastic strap set for larger adjustments in the future. (don't worry about the spring it will be replaced depending on the corse of the track or whatever you deserve) in this way you could also avoid oil leaks on your shock caps. well, critic boy give me what you've got eeeha! Saintlouis that SP2 is looking good mate, A few nice touches. I like the dust caps on the wheel nuts where did you get them? What is going on with the lay down steering servo, I've never seen that before, Nice K factory chassis braces too. My SP2 hop ups consist of king headz front knuckles, rear hubs and chassis braces. Some say stock chassis braces are best as they allow the chassis to flex. It's all about preferance and taste. Will try to get some pics of mine uploaded to show you Jim
