J Lachowski
NJ, USA Status: offline
Just finished assembly, ran the motor up and took some readings. Bad news is it came out heavier than I was hoping for. 6lbs-9ozs w/lipos and it balances right on the recommended CG using two Thunder Power 3S4P 5300ma Prolite narrow packs. A UBEC and smaller wheels could reduce the weight about 2 to 3 ozs. without affecting the CG. I am using no wheel pants and Dave Brown lightweight 2-3/4" wheels. Also, using Duralite 950ma Lion w/6V regulator, JR770 Rx, and JR3421SA servos and Jeti 77 Opto controller. No spinner, just spinner nut that comes with motor. I ran the motor, Eflite 60BL, up tonight in the basement for about 30 seconds or so and was reading 50A plus and 1100 plus watts on the meter with a 15X10 APCE at full throttle. Didn't get a chance to tach it though.
_____________________________
Joe Lachowski NSRCA 330
