Great Planes new DC charger/cycler
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Great Planes new DC charger/cycler
Page: [1] 2 3 4 5   next >   >>
Login
Great Planes new DC charger/cycler - 11/5/2002 8:14:18 PM
Scorch
Status: offline
[URL=http://www.electrifly.com/accys/gpmm3150.html]New from Great Planes[/URL]
I'm curious, do y'all think this is a good investment? Do y'all think it will be high quality, do the job and be worth the price? A buddy at the flying field has the AstroFlight 110D and this appears to be more feature packed, and it's nearly the same price.
I know it's not out yet, so I'm just curious in opinions.
Thanks guys.
_____________________________
Dustin Wright
Columbia, MO
       Post #: 1
Great Planes new DC charger/cycler - 11/5/2002 9:29:59 PM
Red Scholefield
Status: offline
Expect to have GP Triton for review by the Battery Clinic as soon as they become available. Will have preliminary performance report within 2 weeks after receipt of product. It will appear electronically at RC Universe http://www.rcuniverse.com/ and in hard copy in RC Report.
From reading the press releases on the product I will stick my neck out and say it is probably worth waiting for.
Red S.
AMA 951 Leader Member
(in reply to Scorch)
       Post #: 2
Great Planes new DC charger/cycler - 11/5/2002 9:41:27 PM
Wright Flyer
Status: offline
Dustin,
Maybe it's just me being a bit dim but I don't see a price (?) so it's difficult to judge how much of a bargain it is. But anything that can be used for Li as well as NiCd/NiMh seems like a great idea right now with the Kokams becoming generally available.
Cliff
       Post #: 3
Great Planes new DC charger/cycler - 11/5/2002 9:55:30 PM
Scorch
Status: offline
It's $130. The AstroFlight 110D is $110 That link is to the manufacturer. Not a seller.
Thanks, I may go ahead and pre-order this guy.
Dustin Wright
Columbia, MO
       Post #: 4
Great Planes new DC charger/cycler - 11/6/2002 7:39:33 AM
Roscoe
Status: offline
I have one on order now. Expect it to be shipped in early Dec. I will give my opinion ( for what it's worth ) after I check it out. The reason I ordered this one is that it will work with most batteries and packs we now use in RC.
Roscoe
He who dies with the most toys....WINS
       Post #: 5
Great Planes new DC charger/cycler - 11/6/2002 12:50:08 PM
Scorch
Status: offline
That was my thought. I had considered the AstroFlight 110D but it does not cycle. I also like the fact that I can charge literally ANY battery I have now. I too am going to order and will submit my $.02 when I get it.
Thanks guys.
Dustin Wright
Columbia, MO
       Post #: 6
Great Planes new DC charger/cycler - 11/11/2002 4:53:16 AM
coomarlin
Status: offline
Will the triton be DC only, or will it have AC capabilities? Would be nice if I could use it at home and at the field.
       Post #: 7
Great Planes new DC charger/cycler - 11/11/2002 6:00:12 AM
Red Scholefield
Status: offline
You will have to get a DC power supply to use it at home, just like most of the chargers that are offered to the hobby market. The DC supplies are quite reasonable at about the $30 range.
Red S.
       Post #: 8
Great Planes new DC charger/cycler - 11/11/2002 6:08:09 AM
coomarlin
Status: offline
Is that some kind of adapter that plugs into your wall outlet while at the same time accepting a DC device? Is that something I can buy from Tower?
       Post #: 9
Great Planes new DC charger/cycler - 11/11/2002 6:12:33 AM
Red Scholefield
Status: offline
No, it is a simple oldfashioned DC power supply that every models shop should have.
Check theck these sites;http://www.efunctional.com/new-pyramid-power-supplies.html
http://www.millionbuy.com/caudio-kit-sup.html
http://www.valcoelectronics.com/
Red S.
       Post #: 10
AC Power Supply - 11/11/2002 8:09:32 PM
Ross Kean
Status: offline
Is there any problem with using an old PC power supply (AT type) for these chargers? I have a 250w power supply that is rated for 12 VDC at 9.5 amps. In order to "switch" it on and to get regulated power from the 12 V, you need to put a load on the 5V output - it seems to work Ok with a 5 ohm 25 watt resistor across the 5V supply (1 ampere draw). Higher resistance, lower wattage might work as well, but I have this one available. I have ordered the Triton and was planning to use this supply unless someone can tell me why it might not be a good idea.
Ross
       Post #: 11
Great Planes new DC charger/cycler - 11/11/2002 8:21:03 PM
Scorch
Status: offline
Actually, that is a great idea! There was an article in QST (ham radio) magazine about using just such a power supply to build one for use with 12v DC mobile ham rigs. I plan to do the same thing. If you like, I can dig up the magazine and give you specific information if you would like to read that article.
Dustin Wright
Columbia, MO
       Post #: 12
Great Planes new DC charger/cycler - 11/11/2002 8:58:54 PM
Ross Kean
Status: offline
Setting it up shouldn't be a problem. I would simply "tidy" it up a bit by removing wires that aren't needed. It is my understanding that all of the lines of the same voltage are in parallel. I might keep two "yellows" (+12V, 9.5A) tied together because of the potential high current draw if charging big packs at high rate.
I don't know if there is any reason to not use the PC supply. These are quite stable in voltage and (according to specs) should put out enough current to run the Triton. Can't wait until I get it - early December!
Ross
       Post #: 13
Great Planes new DC charger/cycler - 11/11/2002 9:12:41 PM
Scorch
Status: offline
I am excited too. I have acquired many models over the years and have fallen short on support equipment. I have high hopes the Triton will serve all my charging/cycling needs. I am also excited about building the power supply for the shop. The article I read seemed simple enough. I am somewhat of a novice at most of this stuff, so I will lean heavily on my fellow modelers at the field and on RCU
I hope it becomes available soon. I have oredered one, so we'll see.
Dustin Wright
Columbia, MO
       Post #: 14
Great Planes new DC charger/cycler - 11/15/2002 8:04:29 PM
Scorch
