Great Planes new DC charger/cycler
Tower Hobbies
Logged in as Guest
  Printable Version
Cell Indicator/Checker
Seller:  mds007
Details:   $11.00   |  7/11/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Great Planes new DC charger/cycler
Page: <<   < prev  1 [2] 3 4 5   next >   >>
Login
Great Planes new DC charger/cycler - 11/20/2002 3:06:18 AM
Scorch
Status: offline
WooHoo! Thanks! Yes, please keep us novices in mind when approaching this product. The flowcharts are pretty easy to follow and I think you have given me the missing piece of the puzzle. I'm off tonight to try out some different types of batteries on the Triton!
Thanks again.
_____________________________
Dustin Wright
Columbia, MO
(in reply to Scorch)
       Post #: 26
Great Planes new DC charger/cycler - 11/20/2002 6:01:21 AM
rajul
Status: online
[QUOTE]Originally posted by redscho
For right now I would recommend that you stick with 1/3C for charge rate with a cut off at 4.1 volts. [/QUOTE]
Hi red, how do you determine the proper cut off voltage for any given cell ? Does it depend on the charge rate and number of cells ? Thanks...........
       Post #: 27
Great Planes new DC charger/cycler - 11/20/2002 6:21:21 AM
Red Scholefield
Status: offline
When we are talking DISCHARGE cut off:
The cut off voltage is set by the type of cell, not the size or capacity. Of course if you are discharging at a very high rate the cut off can be lower. But in our use, normally to determine the battery capacity in the C/5 discharge region (than this is good for discharges up to C rate) the recommended cut offs are:
Ni-Cd/Ni-MH V cut off = (N-1) X 0.9volts, where N= the number of cells. Or if you don't want to mess with the math just use 0.9 volts/cell - this is good for as many cells as we find in the hobby application.
For Lithium systems the cut off is 2.5 volts, for saftey use 3.0 volts because there is very little left between 2.5 and 3.0 anyway. CHECK THE MANUFACTURER'S SPECS - AS THIS NUMBER IS SOMEWHAT FLUID AT PRESENT, DEPENDING ON THE ACTUAL CELL DESIGN.
The CHARGE cut off for constant potential systems (Lithium) is set by the manufacturer. It is usually 4.1 volts per cell, which would give you 12.3 volts for a 3 cells (in series) Lithium system.
Red S.
AMA 951 Leader Member
       Post #: 28
Great Planes new DC charger/cycler - 11/20/2002 7:34:08 AM
rajul
Status: online
[/QUOTE]
Thanks Red ! What is the recommended charge cut off voltage for NiCd and NiMH ? ................
       Post #: 29
Great Planes new DC charger/cycler - 11/20/2002 9:12:15 AM
CO-Zman
Status: offline
I think he said .9v/cell
Looking forward to the full fleged review, and more users' commentary. I'm planning on the Dym. ST but now this Triton threw a wrench in the situation.
Rob
>>Ya think???<< Yea, but the more I do, the more trouble I get into.
       Post #: 30
Great Planes new DC charger/cycler - 11/20/2002 10:41:13 AM
Scorch
Status: offline
I got to play with the Triton a bit this evening. I'm beginning to get the feel of it. As I have said before, I am pretty much the forever novice, so the former is high praise for the Triton; I think I understand it
Of course, we as modelers cannot leave well enough alone. I replaced the alligator clips with a male cigarette lighter plug and tried it out on my aircraft carrier/Chevy truck. I have a 12v outlet at the tailgate end of the bed, so this works out well.
Click to see fullsize image.
Click for fullsize
< Message edited by Scorch -- Nov 20 2002 5:46AM >
Dustin Wright
Columbia, MO
       Post #: 31
Great Planes new DC charger/cycler - 11/20/2002 11:49:47 PM
herman2002
Status: offline
Is the Triton a "smart" charger like the Shulze Chameleon chargers? e.g. does it dynamically adjust input current automatically? I'm debating whether to get the Triton or a Shulze 6-330.
       Post #: 32
Great Planes new DC charger/cycler - 11/21/2002 12:48:04 AM
Scorch
Status: offline
Yes, it is.
Dustin Wright
Columbia, MO
       Post #: 33
Great Planes new DC charger/cycler - 11/21/2002 5:46:59 AM
Scorch
Status: offline
I need help with a Triton related project. I am planning to build a power supply from a PC power supply to use with the Triton in the shop. The article I’m going by is from the May 2002 issue of QST Magazine. The article calls out components that I am unable to find. Please help me find a source for these guys.
Thanks.
20 Watt, 3-Ohm resistor. (Metal cased with mounting tabs)
1.5 inch diameter ferrite FT140-43 toroid core
In the photo, the author says he's using 2 10-ohm resistors in parallel. This is used to put a load on the 5v side to engage the regulator.
Please help me locate these items.
Click for fullsize
< Message edited by Scorch -- Nov 21 2002 12:57AM >
Dustin Wright
Columbia, MO
       Post #: 34
Great Planes new DC charger/cycler - 11/21/2002 7:02:05 AM
dick Hanson
Status: offline
In anticipation of using this new charger - I have a Genuine WalMart lawn tractor battery ready to go -
I keep this thing on low trickle - so I can use it on the flight line (it has a nice plastic carry handle) or use it in the shop.
It cost me 16 bucks - on speshul .
(that's what they call it at Wal Mart--)
       Post #: 35
Great Planes new DC charger/cycler - 11/21/2002 10:12:26 AM
Airborn
Status: offline
I Just got my triton tonight. I didn't realize my lack of knowledge about batteries. I have been using a accu cycle plus for a year or so......just push a button and walk away. This new charger is going to take some getting used to .
       Post #: 36
Great Planes new DC charger/cycler - 11/21/2002 10:14:20 AM
Scorch
Status: offline
We are working on that. I am hoping we can learn together and share the knoledge. I I am also going to build a power supply to use the Triton in the shop as well as at the field. I'll gladly share that information as well.
Dustin Wright
Columbia, MO
       Post #: 37
Great Planes new DC charger/cycler - 11/21/2002 12:08:32 PM
CO-Zman
Status: offline
Scorch,
Here's a start for your power supply:
http://www.rcuniverse.com/forum/tm.asp?m=188188+power+supply
Just did a search here on RCU for "computer power supply". Appears to be a "Been there, done that" for many folks.
Robb
       Post #: 38
Great Planes new DC charger/cycler - 11/21/2002 7:02:59 PM
Scorch
Status: offline
Thanks, that gave me some of the information I needed. Now I need a source for a 1.5 inch diameter ferrite FT140-43 torite core. And I need a 20 watt 3 ohm resistor, metal cased with mounting tabs.
If you can point me to a source for these parts, I'd be really grateful.
Thanks.
Dustin Wright
Columbia, MO
       Post #: 39
Great Planes new DC charger/cycler - 11/21/2002 8:38:18 PM
Ross Kean
Status: offline
2 x 10 ohm resistors in parallel is equivalent to 5 ohms of resistance. 5 volts through a 5 ohm resistance draws one ampere. 5 volts at one ampere is 5 watts. This would be the absolute minimum for wattage for the application - I would go higher. A 6V automotive lamp would probably work just as well as a resistor!
What is the purpose of the other component?? Don't see why it would be necessary.
Ross
