Great Planes new DC charger/cycler
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Great Planes new DC charger/cycler Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
Great Planes new DC charger/cycler - 12/3/2002 5:59:43 AM
Scorch
Status: offline
This is the inside. Notice my resistors in front of the fan. The switch I used fit perfectly in the hole left by the bundle of wires originally pouring out of the PS. This was pretty easy and fun. I have been wanting a bench top PS for a long time. I had no idea how easy it would be to build one.
Click to see fullsize image.
Click for fullsize
_____________________________
Dustin Wright
Columbia, MO
(in reply to Scorch)
       Post #: 76
Re: Scorch - 12/3/2002 6:02:52 AM
Scorch
Status: offline
[QUOTE]Originally posted by Cougar
Thanks very much for the up-dates sir..
Jeff
[/QUOTE]
You are very welcome, it's fun
Dustin Wright
Columbia, MO
       Post #: 77
Re: Scorch - 12/3/2002 6:05:49 AM
Scorch
Status: offline
What watts power supply did you use to start with?
and did you do the TWO resisters? I am wondering
if I need to add one more and a pic on how to.
Jeff
[/QUOTE]
Mine is a 400 watt unit from [url]www.dealsonic.com[/url] I used two resistors because the author of the article I read told me to. I honestly don't know ohms law well enough to prove why or why not.
In order to put the two resistors in paralell, simply lay them side by side, twist the endd together, and tin. Attach the five volt wires to each end of the two and you are in business. Look at my picture of the inside, if you cannot see what you need to, shoot me a PM and I will get a photo to you late tonight. I have to go to school now.
Dustin Wright
Columbia, MO
       Post #: 78
Re: Scorch - 12/3/2002 6:09:04 AM
Scorch
Status: offline
And another Q's why the triton and not the sirus?
just wondering before I buy a charger.. Seems that
the Triton does the discharge as well? and the other
doesnt?
thanks agian
Jeff
[/QUOTE]
I did not shop this around very well. I don't know that brand/product. I saw the Triton, and a local flyer I respect bought one, so I did too. Shamless, but not stupid. I use what the smart people use as much as I can. I hope that comes out right. I am talking about MYSELF not anyone else.
I will share any knoledge I can. Thanks to all the great guys who have posted and helped people like me.
Time for school.
Dustin Wright
Columbia, MO
       Post #: 79
Re: Re: Scorch - 12/3/2002 6:19:10 AM
Cougar-RCU
Status: offline
[QUOTE]Originally posted by Scorch
[/QUOTE]
So use two RED wires on the end of EACH Resistor and tie
the other ends togeher? NO GROUND? like I have now..
This is right?
Jeff
And yes I would like to see a pic . I will pm you now..
       Post #: 80
Re: Re: Re: Scorch - 12/3/2002 6:21:31 AM
Cougar-RCU
Status: offline
the other ends togeher? NO GROUND? ..
This is right? I now just have ONE resistor with one red wire (+5)
on one end and the black (ground) on the other side
http://www.snowcrest.net/cougar/atx/MVC-895F.JPG
Jeff
[/QUOTE]
       Post #: 81
Great Planes new DC charger/cycler - 12/3/2002 6:30:18 AM
flatfour
Status: offline
Twist the ends of the resistors together.
Connect a red wire to one side and a black to the other.
Careful, they will get WARM
The pic is just an example with some resistors from my junkbox.
Note, these are not the proper value or wattage
Click for fullsize
Jim in Chicagoland
       Post #: 82
flatfour - 12/3/2002 6:38:25 AM
Cougar-RCU
Status: offline
GATCHA! THANKS SO MUCH!
So will 2 be better then ONE? (resistor)
Also I noticed in some supplys that there running
ALL the Yellow together and the Blacks Ect.. so I now
need to beef up my wiring? I just removed them all
and left what I needed. I could add more tho.. you tell me!
THANKS!
Jeff
       Post #: 83
Great Planes new DC charger/cycler - 12/3/2002 6:57:21 AM
flatfour
Status: offline
The number of resistors depends on how many ohms you are shooting for. I showed 2 because the previous post asked about 2.
I think you will want around 5 ohms of total resistance. A 5 ohm load on the 5 volt line should give a current of 1 amp. This will also generate 5 watts of heat in the resistor. When using resistors of equal value in parallel, the effective resistance is half.
So, to get a 5 ohm total, you would use 2 10's in parallel.
I just went back and looked at your pics. Your single resistor will be just fine. The current will be about 715ma and will dissapate 3.6 watts. Since you have 12.6 volts you will be OK
For the wires to carry the 12V current, there is no need to use more than 2 yellows and 2 blacks
< Message edited by flatfour -- Dec 3 2002 2:04AM >
Jim in Chicagoland
       Post #: 84
flatfour - 12/3/2002 7:02:37 AM
Cougar-RCU
Status: offline
Sooo? I have now ONE 10W 7 ohm
Leave it that ways? (what would be better?)
Your use two? sorry to be bothering ya. :
but I am soaking up this learning stuff!
PS and this is enough amps to run these chargers>?
       Post #: 85
Great Planes new DC charger/cycler - 12/3/2002 7:07:41 AM
flatfour
Status: offline
Go back to my previous post. I did some editing.
I don't use resistors at all. I use a halogen bulb from a fog light.
Yours is fine........
Jim in Chicagoland
       Post #: 86
flatfour You Da Man! - 12/3/2002 7:21:02 AM
Cougar-RCU
Status: offline
THANKS !
That's what I needed to know!
Jeff
       Post #: 87
Great Planes new DC charger/cycler - 12/3/2002 3:07:22 PM
f2racer
Status: offline
I think this thread got a little off the subject... Anybody have any reports on how this charger performs? I'm interested in it since it seems to support all the current battery technologies and is relatively cheap.
       Post #: 88
Great Planes new DC charger/cycler - 12/3/2002 4:09:37 PM
coomarlin
Status: offline
I'm thinking about selling my Einstein and getting a Triton. I just wish great Planes would've just made an AC port on the charger in addition to the DC capabilities
       Post #: 89
Great Planes new DC charger/cycler - 12/3/2002 7:31:15 PM
Scorch
Status: offline
[QUOTE]Originally posted by f2racer
I think this thread got a little off the subject... Anybody have any reports on how this charger performs? I'm interested in it since it seems to support all the current battery technologies and is relatively cheap. [/QUOTE]
Check post #70. I'm sure others will follow.
Dustin Wright
Columbia, MO
       Post #: 90
