RE: Genesis Arf Build (Electric)
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: Genesis Arf Build (Electric)
Page: <<   < prev  1 2 3 4 5 6 [7]
Login
RE: Genesis Arf Build (Electric) - 12/11/2005 12:26:33 AM
RC_Pattern_Flyer
Status: offline
Yes, sorry, i meant Temple (squared) since both the Waco and temple old contests will be held at the same field i understand.
I hope so Mike.
More pics tonight on the insight.
later all.
Chuck
_____________________________
Mark Hunt Designs
(in reply to MikeEast)
       Post #: 151
RE: Genesis Arf Build (Electric) - 12/12/2005 5:28:20 AM
Bill_Higgins
Status: offline
well,
I've got 8 flights on the bird, and for the most part it's going well. Im have some problems with upline point rolls getting off track in a hurry that I just can seem to figure out, but will mess with tomorrow. I've also got a little bit of Roll coupleing and a downline mix yet to add. I hope to have 90 % of the trimming done by tommorrow. I pushed todays flights to 7 and 7.5 minutes and could really notice the drop in performance by the 7 minute mark. Kinda makes me wonder how bad things are going to be at the 10 minute mark !!
Bill
Bill Higgins
(in reply to RC_Pattern_Flyer)
       Post #: 152
RE: Genesis Arf Build (Electric) - 12/12/2005 5:38:02 AM
patternrules
Status: offline
Bill check some of the graphs on RCGroup http://www.rcgroups.com/forums/showthread.php?t=342568 your still forming the batteries, they seem to get better after a few flights and it's good your keeping the flights short for now.
If you what a real challenge come up here and try it in the snow that we have had for 4 days and more coming LOL.
Steve Maxwelll
Steve Maxwell
(in reply to Bill_Higgins)
       Post #: 153
RE: Genesis Arf Build (Electric) - 12/12/2005 6:01:16 AM
Bill_Higgins
Status: offline
quote:
ORIGINAL: patternrules
Steve Maxwelll
Thanks Steve....Im sure they'll get better as I get through the first 10 cycles or so.
Snow ????? I barley even know how to spell it !!! :-) Last time we had snow here was 1986 !!!
Forecast for tommorrow is sunny and 71 !!
-Bill
Bill Higgins
(in reply to patternrules)
       Post #: 154
RE: Genesis Arf Build (Electric) - 12/12/2005 11:44:07 AM
rm
Status: offline
What voltage are you ending up at the end of the 7 minutes?
       Post #: 155
RE: Genesis Arf Build (Electric) - 12/12/2005 1:06:28 PM
swk550
Status: offline
Bill,
For your upline rolls getting off track, you may want to check your aileron differential. I was able to get another four flights on my electric Genesis yesterday. Ron Barr also flew the plane. This plane rolls great. I can say this is probably the best rolling plane I have owned. Attached are my control throws. On aileron, I am only using 25% expo. From the photo, my differential is very slight. The aileron servo horn is almost at neutral.
By the way, I am using the TP6000 cells. With throttle management, I can fly the Masters pattern plus a few extra maneuvers in 8 minutes and only use 3200 to 3400 ma. We never went to full throttle until vertical up maneuvers.
Hope this info helps. In the spring, let's all get together for a Genesis practice session.
Good luck,
Steve K
Click to see fullsize image.
Click for fullsize
(in reply to rm)
       Post #: 156
RE: Genesis Arf Build (Electric) - 12/12/2005 4:40:22 PM
Bill_Higgins
Status: offline
quote:
ORIGINAL: rm
On average about 19.10
I've got a copy of Chads excel sheet that I have been keeping track of things on, and I'll try to upload it here later tonight.
Bill
Bill Higgins
(in reply to rm)
       Post #: 157
RE: Genesis Arf Build (Electric) - 10/21/2006 6:17:04 PM
woodie
Status: online
quote:
ORIGINAL: Bill_Higgins
Well....just like Mike, over in the Genesis build thread in the pattern forum....I had my first boo boo tonight as well. In looking at gear plate inside the fuse, I noticed that the 3 holes for the gear were already marked with indentions....this must be pre-aligned right ?????........NOPE !!!. I think my gear plate was actually installed upside down, because the gear ended up mounting too far back, and once I had the gear on the belly pan wouldn't even come close to going on correctly. So now I did what I should have done in the first place which was to mount the belly pan, and then slide a gear half in and mark it !! You'll see in the pics below that the marks (with the holes) are to far back, and the one side that has the forward marks are actually the correct location for the gear !! This pics from inside the fuse show the blind nuts in place, which makes it kind of obvious that the gear plate was just mounted upside down !! :-( No biggie...just a waste of about an hour, and some minor frustrations.......no build ever goes perfect the first time !!!! :-)
-Bill
Bill, quick question. Did your right a left carbon gear for the Genesis match. Mine have different angles (outward) from the fuselage and the face where the axles mount are at different angles. See attached pic. I emailed CA about this but no response yet. I am curious if I am the 'lucky' one or this is a common problem.
Don Atwood
Click for fullsize
       Post #: 158
RE: Genesis Arf Build (Electric) - 10/21/2006 9:13:47 PM
MTK
Status: offline
Don, it looks like you have two different legs. The angle can be fixed by heating the area you want to bend and then bending and holding in position til cool, but the thickness is much harder to change. Flex would be significantly different and your model would tend to list especially after a few landings.
MattK
quote:
ORIGINAL: woodie
Don Atwood
(in reply to woodie)
       Post #: 159
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.922RCU3
