RE: What charger would you recommend?
Tower Hobbies
Logged in as Guest
  Printable Version
FISHER FUEL PRODUCTS 5 GALLON & 2.5 GAS FUELERS
Seller:  hunternfla
Details:   $220.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> RE: What charger would you recommend?
Page: <<   < prev  1 [2]
Login
RE: What charger would you recommend? - 11/7/2005 7:42:33 PM
kx250ryder
Status: offline
Sure. I was going to charge my nimh glow ignitor battery here at work. But I found out that a formation charge requires 16 hours (and I only work an 8 hour shift). So when I take it home to start it, I will check the current on that too.
So what you are saying I should see is that (for example) a .5 amp setting would be a pulse of 1 amp, followed by an equal length pulse of zero amps yielding an average of .5 amps insetead of a constant .5 amps? Theory being that they use pulses beyond what you selected as a charge value?
I will investigate further.
While I am at it, check my math on this: If I am charging a 3300 nimh cell at .33 amps, that is 3300/1000 = 3.3. 3.3 /10 = .330 is a c/10 charge rate. Shouldn't this then take 10 hours to put the capacity back into it? The battery says 16 hours at that rate. I am confused there. If I am charging at 1/10th capacity, shouldn't it take 10 units of time (in my case hours) to reach capacity? Where did they get 16? Also, my charger doesn't do .33, I can either do .30 or .40, what would I expect for a time on either of those?
Ha, after reading the above, it looks like an evil math test word problem. But its open book/calculator, I don't want you getting it wrong. That battery cost me $7.00, I don't want to blow it up.
_____________________________
". . . the same thing we do every night Pinky, try and take over the world." -- Brain
(in reply to JNorton)
       Post #: 26
RE: What charger would you recommend? - 11/7/2005 9:17:53 PM
JNorton
Status: offline
kx250ryder
Your math is right. 3300/300 = 11 hours
A trickle or forming charge is usually figured as battery capacity divided by 10 plus 25%. It's not that critical. 14 to 16 hours is the general agreed time frame.
John
Have desk ... Will Fly....
Saito Member #467
(in reply to kx250ryder)
       Post #: 27
RE: What charger would you recommend? - 11/10/2005 7:55:57 PM
MadVenomm
Status: offline
What calculations do you use to set the charging rates? I have the 969 and directions don't seem to charge the batteries all that well.
       Post #: 28
RE: What charger would you recommend? - 11/14/2005 10:45:31 PM
gopeder111
Status: offline
I recieved the accucycle elite from towerhobbies a few days ago
I haven't tried it yet but im gunna try it next time I use my plane
wing dragon, typhoon 3d, firebird freedom, blade cp
(in reply to MadVenomm)
       Post #: 29
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU1
