Espresso-Outfitters
Score: 100 Joined: 12/24/2005 Last Login: 5/19/2006 From: Tacoma, WA, USA Status: offline
Thanks for the input fisher, I wonder of those are UL listed, I get in trouble with equipment that's not since I have a regular shop, biz license and all and do get inspected from time to time, they look down their noses at non UL stuff due to the liability. When I buy equipment, I always start out cheap, and only when I can justify it's ability to save enough time and improve accuracy and it actually gives me a return, this is why I'm going with just foam cutters, setting up some jigs and of course, doing things in volume, I'll get the same results as any automated process, and in fact, much of the time improve accuracy since all equipment is in the process of degrading, so you gotta go old school style in order to achieve perfect results. My biz url is http://espresso-outfitters.com everything there from the site design and it's marketing "stays on the front page of msn and yahoo nicely" to building and designing the carts from their plumbing and electrical systems to creating them from raw materials are my creations, I let my work speak for itself in this area, and when I build for others I take a much larger consideration any and all details, these guys are paying big bucks for this stuff and have their own inspectors so they have to look and perform flawlessly. The difference between the carts and airplanes, the carts don't have to fly, yet need to carry a ton of weight, yet the planes are a different animal all together since their parts are so small, I can't use the same procedures "will be doing so shortly" to cut out the components. All I'm doing is going from 8' X 4' plywood stock to foam and balsa stock, this latest build is my largest yet at 36", It just passed the threshold of being able to start using some of my jigs and routers, but regardless, I still have to shape the surface of these, which is what makes foam a different animal and is why I'm looking for foam cutters and preferably ones that can handle a production setting, I replace many power tools annually since they just can't keep up with the volume of use I put them through, the same thing eventually will be with the foam cutters, so as I use them, I can justify upgrading. Along the foam cutters themselves construction wise, you are right critterhunter, the blocks or "jigs" are what the 2 ends of the foam cutter ends rest upon, I use a similar method with my router, and to be frank, the contraptions I've seen in the home made end don't look like they can handle any serious volume, I'd beef up the controls so gravity isn't the only thing keeping it in place, this is also the same type of method used in duplication machines.
< Message edited by Espresso-Outfitters -- 2/3/2006 5:35 PM >
Hide Signatures
