RE: Here's a Simple & FREE First Foam Build Plan! Cool Looking Plane Too...
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Foamies! - RC Electric Foam Aircraft >> RE: Here's a Simple & FREE First Foam Build Plan! Cool Looking Plane Too...
Page: <<   < prev  55 56 57 58 59 60 61 62 63 [64]
Login
RE: Here's a Simple & FREE First Foam Build Plan! Cool ... - 3/13/2008 10:57 PM
Swift427
Score: 100
Last Login: 7/10/2009
Status: offline
deleted
< Message edited by Swift427 -- 3/15/2008 2:08 AM >
_____________________________
Never Give Up, Never Slow Down, Never Grow Old, and Never Ever Die Young
Hide Signatures
(in reply to Swift427)
       Post #: 1576
RE: Here's a Simple & FREE First Foam Build Plan! Cool ... - 3/15/2008 2:06 AM
Swift427
Score: 100
Status: offline
deleted
Hide Signatures
       Post #: 1577
RE: Here's a Simple & FREE First Foam Build Plan! Cool ... - 12/5/2008 10:29 PM
fritzjd
Score: 100
Last Login: 12/6/2008
Status: offline
Hello Gentlemen,
I was thinking of building a copy of the Great Planes Extra 300s Flatout. Can you recommend where to get the correct foam brand
to build it. A little confused on what to use.
Thanks for the help.
Hide Signatures
(in reply to critterhunter)
       Post #: 1578
RE: Here's a Simple & FREE First Foam Build Plan! Cool ... - 12/8/2008 3:42 AM
Fisher
Score: 100
Last Login: 11/14/2009
Status: offline
fritzjd,
Great Planes uses a proprietory foam that is sandwiched between a thin skin. I do not believe that you can purchase the exact same foam. Most folks work with DOW bluecore fanfold faom that is ~1/4 inch thick and purchased from local builder supply like Lowes or Allied Builders supply. 6mm depron foam board is pretty much the gold standard though. You can purchase that at www.RCFoam.com . Do you already have planes or are you truely scratch building? Either way you will need foam.
This link will take you right to the depron section. Look around the site is has lots to offer.
http://www.rcfoam.com/cart.php?target=category&category_id=60
< Message edited by Fisher -- 12/8/2008 3:44 AM >
I never crash while flying, it''s the landings that get me.
Hide Signatures
(in reply to fritzjd)
       Post #: 1579
RE: Here's a Simple & FREE First Foam Build Plan! Cool ... - 12/15/2008 8:02 AM
calvino
Score: 106
Last Login: 11/21/2009
Status: offline
the closest match to that has to be dollar tree "sturdy board" its 2 sheets of thin (newspaper style) paper sandwiched between the foam, prety light, easy to strip of paper, and $1/sheet, thats the closest i can think of, OK so i got some 3/4" foam (yes the plans call for 1 1/2 but hauling it was a pain enough), SO i got the 3/4, and used a piece i had to cut to fit in the car to make the plane, so far im really liking it, made the nose out of 3 sheets (overkill but i plan on hauling up a cam..... want protection), so other than that, im almost done installing electronics/need to install tail stuff but other than that, its almost ready to tear up the sikes, anything to 'look out for" like bad tendencies... (easy to sall) anything "nasty" to look out for, my motor system is way overkill for it (good thing), i am omitting rudders and atempting to use 1 aeleron (will have the second wired up....) anyone know how to do 2 aelerons (reversed movement) with a 4-channel reciever/non computer radio? i was thinking of using the aelerons to also act like "elevons" to control the plane (old prototype did that with good results)
RC18T Brushless, 1980 Goldpan , ST-1, Slow Stick, Kyosho QRC, Thunder Tiger Phoenix GT † TTR Makes it, LRP Shakes it.
Hide Signatures
(in reply to Fisher)
       Post #: 1580
RE: Here's a Simple & FREE First Foam Build Plan! Cool ... - 12/18/2008 4:34 AM
saucerguy
Score: 100
Status: offline
I found the Elmers brand foam board to be stiffer then the dollar store brand, it's worth the extra couple of bucks in this area.
Hide Signatures
(in reply to calvino)
       Post #: 1581
RE: Here's a Simple & FREE First Foam Build Plan! Cool ... - 3/27/2009 5:27 AM
ZRAT
Score: 100
Last Login: 11/15/2009
Status: offline
Calvino, I put reverse throw ailerons on my Slow Stick w/ 4ch, just pointed the arms toward the wing tips and the gear side of the cases to the back of the wing. Doesn't matter as long as either the bottoms or the tops of the servos are facing each other and the output gears face the same direction. Verbage may not be condusive so here's a pic...Zrat
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1582
RE: Here's a Simple & FREE First Foam Build Plan! Cool... - 3/30/2009 4:15 AM
son of alpea42
Score: 100
Last Login: 7/2/2009
Status: offline
Here is a little plane I built that is about 1/3 of a full sheet of Green Gaurd.
Click for fullsize
Click for fullsize
< Message edited by son of alpea42 -- 3/30/2009 4:19 AM >
Hide Signatures
       Post #: 1583
RE: Here's a Simple & FREE First Foam Build Plan! Cool ... - 3/30/2009 6:04 AM
calvino
Score: 106
Status: offline
^ Cool looking plane, you need to bend up the wing tips or it will turn VERY BAD (seriously) without Dihedral or Aelerons. Does look good, I have found even 30* at the wing tips (not much) can make loads of difference
Hide Signatures
(in reply to son of alpea42)
       Post #: 1584
RE: Here's a Simple & FREE First Foam Build Plan! Cool ... - 11/11/2009 5:03 AM
matt123456
Score: 100
Last Login: 11/17/2009
Status: offline
Are there any videos of these planes in action?
Hide Signatures
       Post #: 1585
RE: Here's a Simple & FREE First Foam Build Plan! Cool ... - 11/14/2009 8:46 PM
Fisher
Score: 100
Status: offline
I have an aerial video I took from the plane. I can tell you this plane is very capable. As Foam Flyer says on his site. These planes can do way more than you would expect from a single aileron, elevator setup. They are simple, cheap and fly great! You can hug the ground at 4' and pull a full loop ending right back on the deck and keep on going. Rolls are a bit slow but that does not affect the fun factor!
Build your first one just as the plans and instructions indicate and you will be smiling all day long.
If you want to see the aerial video let me know and I will attempt to post it to YouTube.
Hide Signatures
(in reply to matt123456)
       Post #: 1586
RE: Here's a Simple & FREE First Foam Build Plan! Cool ... - 11/14/2009 8:50 PM
Fisher
Score: 100
Status: offline
son of alpea42,
Hey. Just mout your motor a bit higher and add sponsons to the bottom and you will have a hydro flyer!
Hide Signatures
       Post #: 1587
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.984RCU1
