Steve
ID, USA Status: offline
1st, You can try soaking the aileron in hot water for a hour, then weighing it down on a flat surface with a 1/6" or 1/8" piece of balsa under each tip to counter the bow. Most of it should come out. 2nd, Forgo the Stinger. I have a lot of time on a Stinger 120, Ultra Stick, and Ultra Hots. They all have similar flying qualities. If you want to practice some 3D, try a Funtana 90. I still use one to hone in my slow and low practice. They are very good performers and you can use a wide range of motors. I've used a Saito 150, and currently a YS 140. My buddy uses a Saito 180. Another one in the club uses a YS 120AC. Just make sure every thing is right and use good hardware before you fly. The plane is very easy to fly and you may just want to stay on low rates for about 20 flights. This plane has no bad habbits.
_____________________________
AKA,, "The Spleen" If you want to see my Super Power,,, pull my finger.
