RE: Nother 27% CA 300L Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Nother 27% CA 300L Build
Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: Nother 27% CA 300L Build - 12/28/2005 10:06:19 PM
Steve
Status: offline
I've always liked the looks of that H9. I know Lanier has a big one that will work for you. You can do a lot to lighten up their kits. I am still flying the 31% Staudacher. And the cost is reasonable, just a little extra work to lighten them up. They go on sale for cheeeeep some times too.
_____________________________
AKA,, "The Spleen"
If you want to see my Super Power,,, pull my finger.
(in reply to v-snap)
       Post #: 126
RE: Nother 27% CA 300L Build - 12/28/2005 11:58:17 PM
USAce777
Status: offline
how do you know when the wings are parralell to the fuse??? so i can glue the main rib and dowels???
trying to put them up.
Here is my progress so far.
I cut all surfaces off. On the elevator i made an offset... read somewhere it releases loading from servos...
.........Cant Load Pictures........Later!!!
< Message edited by USAce777 -- 12/29/2005 3:05:08 AM >
Gleb D.
(in reply to Steve)
       Post #: 127
RE: Nother 27% CA 300L Build - 12/29/2005 2:37:06 AM
rcblimppro
Status: offline
All 3 of the 38% CA Extras I have built had the same thing going on with the turtle deck. The fix is easy. Just glue the thing on and secure with masking tape pulled VERY tightly. The friction that the tape provides will allow you to pull both sides of the turtle deck flush with the fuse sides. For hatch attachment I use a single 1/4" nylon screw at the back of the hatch, access to the screw via a hole cut in the canopy along with the dowels up front.
SHawn Berkheimer
R/C Blimp Productions.com
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to USAce777)
       Post #: 128
RE: Nother 27% CA 300L Build - 12/29/2005 3:45:55 AM
Steve
Status: offline
Shawn, now that I think about it, that is what I did also.
Gleb, you need to trial fit the wings on the fuse and measure where you have a gap. You can then use a piece of balsa the same thickness as the gap to mark the root end of the wing for sanding. Just place the piece of balsa against the fuse and with the wing in place, mark the top of the wing. You need to do the top and bottom before you start sanding.
AKA,, "The Spleen"
(in reply to rcblimppro)
       Post #: 129
RE: Nother 27% CA 300L Build - 12/29/2005 5:24:40 AM
rcblimppro
Status: offline
Let me add something here, What I discovered is that the wings are actually cut pretty darn close to fit against the fuse. If you trial fit both wings on the fuse and say on the right wing there is a gap at the leading edge most likley there will be a gap on the left wing trailing edge. Measure wing tip trailing edge to back of the fin on both sides. What this should tell you is that you need to adjust the position of the phenolic sleeve in the fuse. I always leave the phenolic in the fuse loose so everything can be adjusted. I will jig everything up and fit the wings, stabs and fin to the fise in one shot to make sure I get everything square. This usually takes me half the day but is worth the effort.
Shawn Berkheimer
(in reply to Steve)
       Post #: 130
RE: Nother 27% CA 300L Build - 12/29/2005 6:36:35 AM
v-snap
Status: offline
To level wings to fuse. First level the fuse at the hatch. Slide wings onto tube flush against the fuse and check that the wings are perpindicular to the fuse. This should be square as you checked this with the wing tube prior to gluing the fuse together once assembled. Once wing is slid onto the tube use a incidence meter on the wings to level them (keeping fuse level). If the root rib lines up then pull wing add glue to rib and slide back on (wax paper between root rib and fuse) check fuse level, check wing incidence meter, check wing square and secure. Let dry.
Steve I have the big Lanier in boxes just looking for a better one. If none then I will build it.
www.dawghouserc.com
"sooner or later you'll be here"
       Post #: 131
RE: Nother 27% CA 300L Build - 12/29/2005 11:52:24 PM
Steve
Status: offline
Ohhhh, You gotta build it
AKA,, "The Spleen"
       Post #: 132
RE: Nother 27% CA 300L Build - 12/30/2005 12:12:40 AM
USAce777
Status: offline
Is the stock balsa going to hold hinges in place or i need betetr one... and what size???
Gleb D.
(in reply to Steve)
       Post #: 133
RE: Nother 27% CA 300L Build - 12/30/2005 2:20:00 AM
Steve
Status: offline
If you top hinge, the stock balsa is fine.
AKA,, "The Spleen"
       Post #: 134
RE: Nother 27% CA 300L Build - 1/1/2006 10:27:09 PM
USAce777
Status: offline
Hey
Today got some 1/4" balsa.
Finally could load pictures...
Here they are...
Click for fullsize
Click for fullsize
Gleb D.
(in reply to Steve)
       Post #: 135
RE: Nother 27% CA 300L Build - 1/2/2006 3:00:30 PM
Steve
Status: offline
Looks like you did a nice job on the cuts. I'm at the point that I need to take pictures outside with mine. If it ever quits snowing!!
AKA,, "The Spleen"
       Post #: 136
RE: Nother 27% CA 300L Build - 1/2/2006 3:22:51 PM
v-snap
Status: offline
Hey that looks like it going together great. I will start the 34% next weekend, and hope to have it ready to cover by weeks end...Will post pics. (actually I could probably cut and paste yours and nobody would know).
www.dawghouserc.com
(in reply to Steve)
       Post #: 137
RE: Nother 27% CA 300L Build - 1/4/2006 11:02:59 PM
Steve
Status: offline
Almost done. Here are a few pics.
Click for fullsize
Click for fullsize
AKA,, "The Spleen"
       Post #: 138
RE: Nother 27% CA 300L Build - 1/4/2006 11:20:34 PM
v-snap
Status: offline
I like it, it should show well in the air..Now get that cowl painted!!!
www.dawghouserc.com
(in reply to Steve)
       Post #: 139
RE: Nother 27% CA 300L Build - 1/4/2006 11:43:10 PM
Slyder
Status: offline
Plane looks great. Snow looks like chit.
Eric H
       Post #: 140
RE: Nother 27% CA 300L Build - 1/4/2006 11:48:43 PM
