RE: Nother 27% CA 300L Build
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Carden Aircraft Edge 540 - 40%
Seller:  5811
Details:   $2,900.00   |  10/27/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Nother 27% CA 300L Build
Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: Nother 27% CA 300L Build - 2/4/2006 3:32 PM
AndresAM
Score: 100
Last Login: 11/6/2009
Status: offline
Guys, Here are some pictures of my progress. This is my first gasser and I have been building it for more than a year now (Not much time, and sent the DA back for updates ). With the quality of the ARF´s now I think this will be my last kit. Too much work and in the end, it ended up costing a little more than a similar ARF. However this plane will be light. I think it will weight a little bit under 14 pounds
Before anybody asks why is not the engine inverted. I will post a picture later with the cowl on. It looks better this way with only the top cylinder fins sticking out the cowl than almost half of the cylinder head sticking out the bottom of the cowl. I cut the cowl very carefully and It looks nice.
Hide Signatures
(in reply to v-snap)
       Post #: 176
RE: Nother 27% CA 300L Build - 2/4/2006 3:40 PM
AndresAM
Score: 100
Status: offline
OK. Here It goes again.[image][/image]
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to AndresAM)
       Post #: 177
RE: Nother 27% CA 300L Build - 2/4/2006 3:43 PM
AndresAM
Score: 100
Status: offline
More Pictures.[image][/image]
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 178
RE: Nother 27% CA 300L Build - 2/4/2006 5:57 PM
Steve
Score: 100
Last Login: 11/7/2009
Status: offline
Andres
The plane looks good. The main reason for mounting the engine inverted is latteral ballance. You just may need to add some extra weight to the left wing tip. When is the test fly date?
_____________________________
AKA,, "The Spleen"
If you want to see my Super Power,,, pull my finger.
Hide Signatures
       Post #: 179
RE: Nother 27% CA 300L Build - 2/5/2006 2:43 AM
v-snap
Score: 100
Last Login: 6/11/2009
Status: offline
Yea a few onces will be needed in the left wing tip..
www.dawghouserc.com
"sooner or later you'll be here"
Hide Signatures
(in reply to Steve)
       Post #: 180
RE: Nother 27% CA 300L Build - 2/6/2006 9:04 PM
AndresAM
Score: 100
Status: offline
quote:
Andres
Steve,
I hope to test the plane in a couple of weeks. Regarding lateral balance, I will try to balance it with the ignition and radio batteries and hope I do not have to add much weight to the left wing tip.
Andres
Hide Signatures
       Post #: 181
RE: Nother 27% CA 300L Build - 2/7/2006 12:23 AM
Steve
Score: 100
Status: offline
keep us posted
AKA,, "The Spleen"
Hide Signatures
       Post #: 182
RE: Nother 27% CA 300L Build - 2/7/2006 7:15 PM
Steve
Score: 100
Status: offline
Scott,
Finally got the 34%er in the mail today.
AKA,, "The Spleen"
Hide Signatures
(in reply to Steve)
       Post #: 183
RE: Nother 27% CA 300L Build - 2/8/2006 12:44 AM
xoon
Score: 100
Last Login: 5/14/2009
Status: offline
Hi, i have a CA extra 27% and plannin to finish it this summer. but my biggest problem is to hold the wing to the plane. what was your method? any pix would be greatly appreciated.. thx
Don't think... just fly!!!
Hide Signatures
(in reply to Steve)
       Post #: 184
RE: Nother 27% CA 300L Build - 2/8/2006 12:58 AM
EL TEMUCANO
Score: 100
Status: offline
I PUT NYLON WING BOLTS WITH BLIND NUTS..
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by EL TEMUCANO -- 2/8/2006 1:08 AM >
I said to my fingers, ! YOU CRASH MY MODEL !
Hide Signatures
(in reply to xoon)
       Post #: 185
RE: Nother 27% CA 300L Build - 2/8/2006 1:47 AM
Steve
Score: 100
Status: offline
I used the bolt through the wing tube. You can see it on post #72.
AKA,, "The Spleen"
Hide Signatures
(in reply to EL TEMUCANO)
       Post #: 186
RE: Nother 27% CA 300L Build - 2/8/2006 2:18 AM
xoon
Score: 100
Status: offline
quote:
ORIGINAL: Steve
The holes for the wing tube are already in the foam cores. You just have to slide the phenolic tube in and glue it. The holes for the servo extentions are also in the wing core already and the wings are pre-sheeted also.
I installed the hard points for the wing screws to hold the wings on. I used 6/32 X 2" screws.
so would this screw goes through the metal tube that is HAND tapped?? or what is there to hold the screw in thread?
also the nylon bolt through the fuse then the wing. how would that hole in the wing be tapped? how big is the screw?
thanks a lot
Hide Signatures
(in reply to Steve)
       Post #: 187
RE: Nother 27% CA 300L Build - 2/8/2006 2:28 AM
EL TEMUCANO
Score: 100
Status: offline
XOON IF YOU CAN READ SPANISH OK MY ENGLISH IS VERY BAD
LA BLINT NUT VA PUESTA SOBRE UN BLOQUE DE MADERA Y ESTE VA PEGADO EN LA COSTILLA DE TERMINACIÓN DEL ALA.
LA FUERZA QUE HACE EL ALA HACIA AFUERA NO ES MUCHA, ESTE SISTEMA LO HE VISTO EN MUCHOS AVIONES Y ES PREFERIDO POR LA SENCILLES EN EL ARMADO. TAMBIEN HE ESCUCHADO QUE LOS TORNILLOS EN EL ALUMINIO DEL ALA, DESPUES DE UN TIEMPO TIENDEN A SOLTARSE....
Hide Signatures
(in reply to xoon)
       Post #: 188
RE: Nother 27% CA 300L Build - 2/8/2006 4:18 AM
Steve
Score: 100
Status: offline
Here are a few photos of my wing. I use the same dowl stock that is used for the hard points in the rudder, elevators, and alerons. I cut a short piece to glue to the topside, and a short piece to glue to the bottom side. The bottom hardpoint is tapped for the screw I use so no additional hardware is required and the tension of the screw will kind of clamp the tube in. I should have gone a little more to the wingtip and the end of the wing tube with the hole though. With the size of the wing tube I don't think I'll ever have a problem with a failure where I drilled the hole through the aluminum tube. This is the same system most kit manufacturers use.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
AKA,, "The Spleen"
Hide Signatures
       Post #: 189
RE: Nother 27% CA 300L Build - 2/8/2006 4:44 AM
xoon
Score: 100
Status: offline
lol i translated the spanish to english using an online translator... and i think you are sayin that the nuts will go through the root of the wing into a block of wood inside. and there are not much force pulling the wing out so not much is needed to keep the wing on while flying. and the nuts throught the tube method will over time tend to be free.
thanks a lot for the replies, i am still not sure of which method to go with. but i will certainly let you guys know of how it goes.
by the way, what would be the good servos for this plane?
im looking at....
HS-5745mg .speed .18, 208oz in at 4.8 v 69$
HS-5645mg speed .18, 164oz in at 6v 54$
HS-5945mg speed .13, 180oz in of torque at 6v 89$
these are the servos that im looking at.. trying to keep the cost down but also looking for the best that i can afford. any ideas? thanks again
Hide Signatures
(in reply to Steve)
       Post #: 190
RE: Nother 27% CA 300L Build - 2/8/2006 12:17 PM
Steve
Score: 100
Status: offline
I'm using all 5645's. The 5925's would be great also.
AKA,, "The Spleen"
Hide Signatures
(in reply to xoon)
       Post #: 191
RE: Nother 27% CA 300L Build - 2/9/2006 4:55 PM
AndresAM
Score: 100
Status: offline
I am using one 5945 for the rudder and 5625´s everywhere else.
Hide Signatures
(in reply to Steve)
       Post #: 192
RE: Nother 27% CA 300L Build - 2/9/2006 8:29 PM
EL TEMUCANO
Score: 100
Status: offline
STEVE,
HOW MANY MOVE DO YOU HAVE ON AILERON RUDER AND ELEVATORS??
ON MY:
AILERONS LOW 1"
HY 1 7/16"
ELEVATR LOW 1 1/2"
HY 3"
< Message edited by EL TEMUCANO -- 2/9/2006 8:38 PM >
Hide Signatures
       Post #: 193
RE: Nother 27% CA 300L Build - 2/10/2006 12:52 AM
Steve
Score: 100
Status: offline
EL TEMUCANO,
I don't use inches, I use degrees. I have mine set up for, alerons= 48* high rate and 25* low. The elevator is the same. The rudder is 38* high and 25* low rate. Hope this helps. I also use 30% expo on everything.
Steve
< Message edited by Steve -- 2/10/2006 12:53 AM >
AKA,, "The Spleen"
Hide Signatures
       Post #: 194
RE: Nother 27% CA 300L Build - 2/10/2006 11:58 PM
xoon
Score: 100
Status: offline
and how about your engine? what would be the thrust angle needed??.... i know that engine box is built w/ the thrust angle. any pix of the engine box and how it is reenforced?? thanks a lot. this will keep me up to date when i start finishing my CA 27%.
Hide Signatures
(in reply to Steve)
       Post #: 195
RE: Nother 27% CA 300L Build - 2/11/2006 2:03 AM
Steve
Score: 100
Status: offline
I kept the thrust angle that was already built into the plane. I will change it as I fly and see what needs to be done for inverted flight and uplines. The only re-inforcement I used was tri-stock on the inside of the engine box and I pinned the firewall in with 1/8 inch dowls.
AKA,, "The Spleen"
Hide Signatures
(in reply to xoon)
       Post #: 196
RE: Nother 27% CA 300L Build - 2/11/2006 2:05 PM
USAce777
Score: 100
Last Login: 2/15/2008
Status: offline
hey guys !!!
Nice jobs building!!!
question...
what are some good companes for control horns???
Which ones????
Thanks!
Gleb D.
Hide Signatures
(in reply to Steve)
       Post #: 197
RE: Nother 27% CA 300L Build - 2/12/2006 3:03 AM
Steve
Score: 100
Status: offline
For the Colombo I use the Hanger 9 harware. Horns, ball links, and titainium rods.
AKA,, "The Spleen"
Hide Signatures
(in reply to USAce777)
       Post #: 198
RE: Nother 27% CA 300L Build - 2/12/2006 3:12 AM
EL TEMUCANO
Score: 100
Status: offline
A GREAT WEEKEND ON VALDIVIA CHILE 7 FLYGHTS VERY VERY NICE
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Steve)
       Post #: 199
RE: Nother 27% CA 300L Build - 2/12/2006 3:15 AM
EL TEMUCANO
Score: 100
Status: offline
OTHERS FLYIGHTS TODAY............
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by EL TEMUCANO -- 2/12/2006 3:18 AM >
Hide Signatures
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.438RCU1
