rainman777
Joined: 2/22/2004 From: Wagga Wagga NSW, AUSTRALIA Status: offline
My Marder's ZG22 engine starts fine after a few tugs on the starter. The bulb fills nicely and all is well. However, after 5 or so minutes of hard charging, she starts to die when I open the throttle wide, which eventually gets worse until the merest whiff of throttle threatens a stall. Then she dies. When I look at the bulb on the carb it's empty. Furious pressing gets fuel in but it immediately drains out and there is no chance of getting the motor started. I can see no fuel leaking but when I press the bulb there seems little movement of fuel from the tank, but bubbles do move on the return line. If I leave the car for a short while, maybe 5 minutes, she'll go again, even responding to full throttle, then it all starts again. Now I'm guessing this is a blocked fuel filter. DOes this sound like a reasonable assumption? If so, has anybody got tips on cleaning the filters? I have one in the tank and one in the line just after the line exits the tank on its way to the carb (which some have suggested is in back to front - could this be the problem?) If it sounds like something else, could anybody advise how I could track down the problem? It's frustrating, as all seems fine then she dies.
