Is an all white plane a bad thing?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> Is an all white plane a bad thing? Page: [1]
Login
Is an all white plane a bad thing? - 11/5/2005 2:58:21 AM
xray328
Status: offline
All I can find is white coroplast resulting in an all white plane. I'm gonna add a few stickers to it but in general, will the all white cause a problem? I was looking around here and it seems that nothing really sticks to coroplast besides the vinyl stickers.
       Post #: 1
RE: Is an all white plane a bad thing? - 11/5/2005 3:02:31 AM
voyager_663rd
Status: offline
rustoleum or krylon rust paints (spray can) stick fine. they just take a week or so to dry then they're done (fuel proof too).
all white is bad news on cloudy/overcast days. Hard enough sometimes to see coloured ones let alone white. re-consider if you can.
if you do paint, make the markings at least 6 inches wide. Otherwise, they'll just kinda fade away and you won't see the effect you want.
< Message edited by voyager_663rd -- 11/5/2005 4:06:38 AM >
_____________________________
Len-> More questions than answers some answers are here [url]http://www.freewebs.com/rc_tips_and_hints[/url] 18,000+ hi
(in reply to xray328)
       Post #: 2
RE: Is an all white plane a bad thing? - 11/5/2005 3:40:42 AM
ArmedZagi
Status: offline
quote:
ORIGINAL: xray328
...will the all white cause a problem?
At distance, an all white plane can get disorienting... Without a different color on the top and bottom...it can get hard to tell if its right-side-up or not...
But it shouldnt be a big problem to paint it with some of those new paint designed especialy for plastic...what is it called? Krylon Fusion? Somthing like that anyway...
< Message edited by ArmedZagi -- 11/5/2005 3:42:12 AM >
-I love the smell of glow fuel in the morning
       Post #: 3
RE: Is an all white plane a bad thing? - 11/5/2005 1:32:49 PM
Muldoer
Status: offline
I usually stripe the underside of all my wings. With the stripes I can tell how I am looking at the plane from a distance and never lose orientation. Just make sure the stripes contrast enough with the color you have. I'd use some black on your wing.
(in reply to ArmedZagi)
       Post #: 4
RE: Is an all white plane a bad thing? - 11/5/2005 11:36:46 PM
BillBabe
Status: offline
Try to get some contact paper. I am currently using a checkerboard contact paper on the bottom of my wings. It is very light and cheap. Most importantly, It impresses the non Spaders as you make a fly-by of the field.
       Post #: 5
RE: Is an all white plane a bad thing? - 11/6/2005 1:29:39 AM
moparcolt
Status: offline
I just put some stripes on my wing and tail because it was getting real hard to tell which way was up when flying. especially when it was cloudy!!!
the stripes are a big help!
(in reply to BillBabe)
       Post #: 6
RE: Is an all white plane a bad thing? - 11/7/2005 2:02:03 AM
xray328
Status: offline
I ordered some adhesive sign vinyl from Ebay so I'll try that. Maybe some kind of neat design on top and the stars and stripes (like on WWII fighters) on the bottoms I got from the LHS. I saw a neat design from avoidtheground.com that was a bright green that you could see forever.
(in reply to moparcolt)
       Post #: 7
RE: Is an all white plane a bad thing? - 11/21/2005 4:06:32 AM
Mitty
Status: offline
Vinyl is a way to go.As for me the only problem white was posing for me is dirt and exhaust were visible on it.I had a Spa3DT ,i used some dark blue on it so mulched grass mixed with castor wouldnt be VERY noticable.
http://aviaportal.net is biggest online community of avitors.
       Post #: 8
RE: Is an all white plane a bad thing? - 11/23/2005 2:16:46 PM
martno1fan
Status: offline
hi exray i used some sticky back covering its cheap and looks great ,as others have said vinyl is good go to any sign makers and pick it up in any colour you want!!heres a pick of mine !![image][/image]in fact heres a b4 and two after shots which do you think will be easier to see?.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
im not argumentative im just missunderstood
       Post #: 9
RE: Is an all white plane a bad thing? - 11/23/2005 5:13:15 PM
xray328
Status: offline
Looks good! Which plane is that?
(in reply to martno1fan)
       Post #: 10
RE: Is an all white plane a bad thing? - 11/23/2005 5:30:21 PM
martno1fan
Status: offline
hi mate its the dps i built it as in the plans exept i ended up building the dominator wing as i found it easier using one peice of coro and bending it over !! dont ask why lol .glad you like it.its still unflown as ive been short of time for few months and the weathers been bad lol.shes all ready for some decent weather knowing my luck that will be in the spring lol .its my 1st spad and she looks good and i cant wait to fly her.i used 3 mill coro for the wing instead of 2 mill top 4 mill bottom so the weights the same and shes turned out good i think!!.oh by the way the black trim is just vinyl tape .dont forget to post pics of yours when shes finnished .i decided to get into spads after a rebuild on my trainer balsa is such a pain to repair lol.[image][/image]heres a pic of my trainer after rebuilding and covering using the same covering as on the dps.my 8 yr old son designed the colour scheme and the covering was off ebay by rtf models called quick cover .self adhesive but also you can use heat to shrink it if used on balsa.easy stuff to use and comes in lots of nice colours.good luck with yours mate .
Click for fullsize
       Post #: 11
RE: Is an all white plane a bad thing? - 11/24/2005 3:17:06 AM
Villa
Status: offline
It is not difficult to put some contrasting color on the plane. A roll of vinyl from Harbor Sales is only about $18.00.
Click for fullsize
Click for fullsize
       Post #: 12
RE: Is an all white plane a bad thing? - 11/24/2005 4:21:21 AM
CJ32769
Status: offline
Go to the local sign shops, fast signs or any of them. They will load you up with scrap sign vinyl usually for free. I have been known to check the dumpster out back of the fast sign places too.
(in reply to Villa)
       Post #: 13
RE: Is an all white plane a bad thing? - 11/24/2005 4:25:03 PM
martno1fan
Status: offline
hey villa cool planes what are they?left to right i particularly like the one on the right !!.any build pics or videos of it flying?.
(in reply to Villa)
       Post #: 14
RE: Is an all white plane a bad thing? - 12/2/2005 8:02:05 AM
