which simulator cord for Tracker III?
Tower Hobbies
Logged in as Guest
  Printable Version
208oz Servo
Seller:  monstertruck2000
Details:   $48.95   |  10/8/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Polks Hobby >> which simulator cord for Tracker III?
Page: [1]
Login
which simulator cord for Tracker III? - 11/5/2005 3:47:16 AM
fireflynj
Status: offline
anyone try using the Tracker III on FMS sim?
which simulator cords works?
< Message edited by fireflynj -- 11/6/2005 5:47:18 AM >
       Post #: 1
RE: which simulator cord for Tracker III? - 11/6/2005 7:56:54 PM
fireflynj
Status: offline
ok, so far I figured out that I need to get the Futaba 6pin cable.
anyone tried it with Tracker III?
so another question.... is the USB that much better then serial?, I am leaning to the USB only because its easier to plug to front of computer and also because not all computers (notebooks) has serial connectors anymore.
(in reply to fireflynj)
       Post #: 2
RE: which simulator cord for Tracker III? - 11/6/2005 11:25:19 PM
skypilit
Status: offline
It works just fine on my G3 as long as it is in trainer mode.
< Message edited by skypilit -- 11/6/2005 11:30:52 PM >
       Post #: 3
RE: which simulator cord for Tracker III? - 11/8/2005 6:40:45 PM
lewispolk
Status: offline
Dear All Tracker III Owners,
Please note that we offer a great trainer cord for $8.00 and recommend it to be compatible with the Futaba cords. It's designed to be used with our radio and many simulators.
It's available through our web store.
Yours truly,
Lewis Polk
(in reply to skypilit)
       Post #: 4
RE: which simulator cord for Tracker III? - 11/8/2005 11:32:47 PM
skypilit
Status: offline
Lewis, are those in stock? I know I would like to get one.
Dave
my hanger:skypilit.rcuniverse.com
(in reply to lewispolk)
       Post #: 5
RE: which simulator cord for Tracker III? - 11/9/2005 12:02:27 AM
lewispolk
Status: offline
Dear Dave,
Yes they are in stock and can be ordered at www.polkshobby.com.
I don't want to give out stock numbers here as this is a non-advertising opportunity, but they can be easily located at our webstore.
Yours truly,
Lewis Polk
       Post #: 6
RE: which simulator cord for Tracker III? - 11/9/2005 4:10:30 PM
fireflynj
Status: offline
can't connect trainer cord to pc, unless I am missing something.... how you connect a 6 pin connector to a PC?
there should be two cords, radio to buddy box (trainer cord) and radio to PC (simulator cord)
BTW, I got the trainer cord added to my radio order, Thank you
so now I am after the simulator cord
       Post #: 7
RE: which simulator cord for Tracker III? - 11/10/2005 12:50:40 AM
skypilit
Status: offline
A sim cord would be nice, but I will have to get the trainer cord in the meantime. It does still work with my G3 with the cords that come with it but it seemed hard to set up.
Dave
My hanger:skypilit.rcuniverse.com
       Post #: 8
RE: which simulator cord for Tracker III? - 11/11/2005 3:23:14 AM
genebond
Status: offline
www.tti-us.com/sim works for me. I use it for FMS and AFP. Use Student mode: hold down the 'Mode Down' button during power up.
       Post #: 9
RE: which simulator cord for Tracker III? - 11/16/2005 12:49:05 AM
fireflynj
Status: offline
Update . . .
I got my simulator cord from
http://www.rc-circuits.com/USB%20Joystick%20Interface.htm
working good!
Tracker III
FMS
Windows XP
< Message edited by fireflynj -- 11/16/2005 1:26:40 AM >
(in reply to genebond)
       Post #: 10
RE: which simulator cord for Tracker III? - 12/15/2005 4:36:40 AM
lbarnes
Status: offline
I didn't see this info on the post.
If you are using windows 95, 82, 2000 you can use the serial/parallel cables for yous FMS simulator.
Now if you have Windows XP, these cables will not work and you need a USB serial cable to get the program to work. It is not he probem with FMS or the cable, it is a problem with windows XP. XP does not reconize the parallel/serial port with FMS.
Just my $.02 worth.
Larry
       Post #: 11
RE: which simulator cord for Tracker III? - 12/15/2005 4:38:26 AM
lbarnes
Status: offline
Just my $.02 worth.
Larry
       Post #: 12
RE: which simulator cord for Tracker III? - 12/17/2005 4:04:11 PM
fireflynj
Status: offline
its possible it will work, for XP you need software called Pic Joy
http://www.tti-us.com/sim/picjoy.html
(in reply to lbarnes)
       Post #: 13
RE: which simulator cord for Tracker III? - 12/17/2005 8:09:59 PM
lbarnes
Status: offline
Wish I would have known that before I spent $40.00 for a USB interface
Larry
       Post #: 14
RE: which simulator cord for Tracker III? - 12/18/2005 6:46:37 AM
fireflynj
Status: offline
cost me $50 after shipping,
if anyone one has serial, please test and reply with results, so others will know! thanks!
I still wanted USB, I hate digging around the back of computer, some computers has USB port in front.
