johnc1go
IN, USA Status: offline
I had a control issue similiar to the one andrew speaks of with his shrike. Upon pulling out of a full power dive, the airplane would pitch up violently, dropping the right wing 90 degrees. I found that diving more shallow and reducing speed solved the problem, but I still needed to address it. I'm thinking a high speed tip stall on the right wing. I carefully inspected both wings for warps, no warping to be found. I still felt I had to do something, so I ironed in a sligh amount of washout into the right wing tip. The next, back at the flying field, same thing problem. Well, I just gave up and learned how to deal with it. Recently, I upgraded from 72 mhz to spread spectrum. Any of us who build shrikes understand the problem routing the reciever antenna. When I was on 72, I ran my wire out the needle valve side of the fusealage, above the wing and through a little hole I drilled in the bottom of the left tail fin. This would allow for about 1 foot of wire to trail out behind the plane. Upon switching to spread spectrum, the antenna issue was eliminated as I could keep the much shorter antannae inside the airplane. Walla.....my "tip stall" problem was suddenly solved. I was mistaking a radio glitch for a tip stall. Perhaps the glitch was brought on by the exposed antenna wire oscillating in a certain way during high g manuevers, I don't know, I do know that I no longer have the problem and that high altitude split S's are much more fun.
< Message edited by johnc1go -- 10/7/2007 3:08:28 PM >
