Ek 4
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Ek 4
Page: [1]
Login
Ek 4 - 11/6/2002 5:54:59 PM
jsasser7
Status: offline
I was wondering if anyone has ever had problems with getting their EK 4 to crank. My engine will not even fire until I manually place fuel into the carb or cylinder head. Could it be that the carb is not seated correctly to the engine?? I need help fast!! Thanks
       Post #: 1
Ek 4 - 11/6/2002 9:14:28 PM
Bonefrost
Status: offline
Does it run once it's started?
BNZ'
(in reply to jsasser7)
       Post #: 2
EK 4 - 11/6/2002 9:27:31 PM
jsasser7
Status: offline
No! It only runs the fuel that I manually placed in it out then dies. I've also noticed that when the engine is completely cycled, it has a small air leakage coming from the back - somewhere around the starter system attachment. But it was doing this when I first got it. The first day I ran the truck, it ran ok being that it was a new engine or not broken in. That night, I sprayed WD-40 into the cylinder (with the cylinder head off) and let it sit overnight. Eversince, the truck will not pull fuel and therefore, will not stay running. What do you think?? Thanks for all the help you can give me!!
       Post #: 3
Ek 4 - 11/7/2002 11:18:21 AM
3maxxman
Status: offline
Have you done the changes to the tank and muffler? Tank: raise it up about 3/4" so the fuel flows down to the carb, muffler: move the pressure fitting down the pipe to the 1st chamber instead of the 2nd chamber where the factory put it. Seal your air leaks! Does the engine have compression? Check that the piston ring is not caught in the piston they had a batch of them with problems.
If you want EK4 information here is the site [URL=http://www.midmad.com/]Midnight Madness RCMT[/URL] They also have a very good forum.
       Post #: 4
Thanks!! - 11/7/2002 5:16:33 PM
jsasser7
Status: offline
Thanks for all of your help - I will try to move the tank and put the pressure fitting on down the pipe. When you say that - you mean closer to the exhaust outlet?? Thanks again!!
       Post #: 5
Ek 4 - 11/7/2002 7:04:35 PM
3maxxman
Status: offline
Toward the header, from the hanger screw at the end of the pipe 5" toward the header.
       Post #: 6
Pipe - 11/7/2002 7:43:41 PM
jsasser7
Status: offline
But it came from the factory with the pressure fitting there. I guess I'll just try to move the fuel tank higher. If I put a piece of fuel tubing onto the pressure fitting on the tank and blow air into it (with the tank empty), it is very hard to get air to come out of the fuel outlet. It would seem to me if it is hard to blow air out of the tank then it would be even harder to blow fuel out of it!! Any suggestions?? Thanks again for your help!!
Jeremy
       Post #: 7
Ek 4 - 11/9/2002 4:45:44 AM
Bonefrost
Status: offline
Sounds like a clog somewhere.Try a new fuel tank.Check your fuel lines and make sure there is no obstuctions.
BNZ'
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU1
