buzzard bait
Joined: 1/1/2003 From: Ithaca, NY, USA Status: offline
Shane, yes, it is the 60. I think most of them end up around 8 lbs or over--you did well for a first build. I'm a light builder by habit, from my free flight days. But with the Saito 100 you will have plenty of power, and the Four Star has so much wing it will be a nice flyer. One guy's came out to 9 lbs and he's crazy about it. Not everybody likes light planes--there are lots of threads. But I do. Building light is really about a lot of little things that add up. Pretty much the reverse of how planes come out heavy! I weigh the wood before I start. Any that is really heavy I replace the part with lighter wood from my stock (except toward the front where I usually don't worry about it). When I buy balsa I weigh each piece and label it on masking tape. I use a table to convert weight/size to density (lbs/cubic foot). I have an old double beam gram scale, but you can get a good electronic balance now very cheaply--try Radical RC. I use Weldbond glue, which is a white carpenter's glue--it's water based and the water evaporates, unlike epoxy. I don't try to fill gaps with glue--I try to get good fitting joints, and if I have to fill a gap I'll do it with wood slivers. I don't try to make glue filets--they don't help anyway. I'm especially careful about weight in the tail. I don't use epoxy back there, I make sure tail surfaces are light, and I don't use after market tail gear--just a music wire skid or a light tail wheel made for electrics. Really, on grass a skid works as well as a wheel and can be fully steerable. I can't detect any difference in ground handling. I use the heavier wing pieces on the port side to balance out the engine which sticks out on the starboard side. Actually my 4*60 kit had very good wood--I just replaced some of the sheeting for the fin and stab. I really take pleasure in building light and strong. We're building flying machines, not something that will sit on a shelf. That's part of the kick for me. W8ye--thanks for the info about your gear mods. I was thinking about that, but ended up with the stock location. Jim
