S/S electronic ignition (Pics Added)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
90 Dgree Muffler Adapters
Seller:  RC Specialties
Details:   $19.95   |  4/12/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> S/S electronic ignition (Pics Added)
Page: [1]
Login
S/S electronic ignition (Pics Added) - 11/8/2005 10:58 PM
blueberry
Score: 100
Last Login: 5/17/2010
Status: offline
I recently purchased an electronic ignition second hand it says S/S ignition on it.
Does anybody know anything about this brand or know how to contact them?
The guy I purchased it from said he bought it at the Weak Signals RC Show in Toledo Ohio.
Pete
< Message edited by blueberry -- 11/13/2005 4:23 AM >
Hide Signatures
       Post #: 1
RE: S/S electronic ignition - 11/12/2005 6:53 AM
blueberry
Score: 100
Status: offline
Anybody?
Hide Signatures
(in reply to blueberry)
       Post #: 2
RE: S/S electronic ignition - 11/12/2005 9:19 AM
davewallace
Score: 100
Last Login: 7/7/2012
Status: offline
Hi Berry,
Post a picture of the unit and the circuit board and see if anyone recognizes it.
Dave
_____________________________
Every day above ground is a good day.
Hide Signatures
       Post #: 3
RE: S/S electronic ignition - 11/13/2005 4:21 AM
blueberry
Score: 100
Status: offline
Ok Dave here are some pics.
The first problem I was having was that when the plug fired it would also jump a spark from the plug cap to the outside of the plug. I beleive I solved that by grounding the sheilded wire.
Second is the yellow wire coming out of the box, I have no idea what that is for?
Third I don't know if I can run 6 volts or if I should just stick with 4.8 volts. The spark does look pretty good with 4.8volts.
Sorry for all the questions this is my first electronic ignition.
Pete
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to davewallace)
       Post #: 4
RE: S/S electronic ignition - 11/13/2005 4:50 AM
Antique
Score: 557
Last Login: 3/21/2012
Status: offline
Could be a secondary ground wire...Check for contunuity between the shielding and the wire...An ignition needs to be grounded..The shield is normally connected to the ground somewhere...
RC Ignition
Hide Signatures
       Post #: 5
RE: S/S electronic ignition - 11/13/2005 5:54 AM
blueberry
Score: 100
Status: offline
quote:
ORIGINAL: RCIGN1
It does have continuity and I just tried grounding the yellow wire and that seems to work.
I have to get a new battery pack though. The one that I got with it must be junk because I charged it and I can only get a few sparks and then the voltage drops too low and I don't get any spark.
Pete
Hide Signatures
(in reply to Antique)
       Post #: 6
RE: S/S electronic ignition - 11/13/2005 6:22 AM
tkg
Score: 657
Last Login: 5/21/2013
Status: offline
Not much help, but he was upstairs in the swapmeet section. Didn't get a card so no joy.
TKG
Too much power is just about right.
Hide Signatures
       Post #: 7
RE: S/S electronic ignition - 11/13/2005 6:27 AM
blueberry
Score: 100
Status: offline
Thanks That might help.
Did you happen to look at his ignitions or ask any questions?
Pete
Hide Signatures
(in reply to tkg)
       Post #: 8
RE: S/S electronic ignition - 11/14/2005 5:05 AM
Eagle Flyer
Score: 100
Last Login: 2/19/2013
Status: offline
The yellow wire is a ground.
Hide Signatures
       Post #: 9
RE: S/S electronic ignition (Pics Added) - 11/19/2005 5:09 AM
Prop Nut
Score: 100
Last Login: 5/12/2012
Status: offline
S/S Machine and Engineering, LLC
Specializing in Prototypes, AlloyMachining adn Anodizing
Roy Sholl-President
16940 Co. Rd. T Fayette, Oh, 43521
419 452-7490
www.cncengines.com
Hmmm, sorry that I dont have very much information on S/S to give you. Hope this helps
I talked to the guy at Toledo last spring, he seemed very knowledgable and friendly. He had several demo motors set up. His web site has good information to help set up that system.
Scope? Listerine? Or Prop Wash?
Hide Signatures
(in reply to Eagle Flyer)
       Post #: 10
RE: S/S electronic ignition (Pics Added) - 11/19/2005 5:23 AM
blueberry
Score: 100
Status: offline
Thanks Prop Nut!
That is what I was trying to find. When I get a hub made I will post here how it works.
All that I have done so far is bench test it and it does seem to have a nice spark.
Pete
Hide Signatures
(in reply to Prop Nut)
       Post #: 11
RE: S/S electronic ignition (Pics Added) - 2/13/2006 7:16 AM
Scott Ellingson
Score: 100
Last Login: 8/21/2008
Status: offline
I have been dealing with Roy Sholl for a while now. He is a great guy. Any questions you have he will be happy to answer. You are correct on the shielded wire. It needs to touch the metal part of the plug. The silicon on the cap is to hold the braided wire aginst the plug. The ignition was designed to run at 4.8v. DO NOT run a 6volt battery to it. The max input voltage is 5.4 volts. The unit you have he does not make anymore. It is a fixed timing unit and all he currently makes is an auto advance unit. I have one of his old fixed timing units as well as a bunch of the variable timing units. My fixed timing does not have the extra ground. That must be somthing he changed since yours was made.
There is no replacement for displacement....you can allways throttle back!
Hide Signatures
       Post #: 12
RE: S/S electronic ignition (Pics Added) - 2/13/2006 8:18 PM
blueberry
Score: 100
Status: offline
poco242,
Yeah Roy seems like a good guy to deal with. He e-mailed me and sent me an update kit for my ignition no charge! I bought this ignition second hand from a guy not from Roy directly, anybody that would do that is ok in my book! I will definetly buy my next ignition from him!
Pete
Hide Signatures
(in reply to Scott Ellingson)
       Post #: 13
RE: S/S electronic ignition (Pics Added) - 8/12/2006 8:30 AM
TIGITRIGHT
Score: 100
Last Login: 6/11/2010
Status: offline
Roy is a very nice guy and friendly to deal with.You got a good ignition there.
Click for fullsize
If Only a Frog Had Wings He Would'nt Bump His Aft,,..
Hide Signatures
       Post #: 14
RE: S/S electronic ignition (Pics Added) - 8/16/2006 7:37 AM
billzair
Score: 100
Last Login: 5/19/2013
Status: offline
I bought an ss ignition about 6 months ago.....finally about to set it up on a 55cc craftsman Anyway, I never got the little magnet that you epoxy into the prop hub to fire the plug......is that something that I should have bought seprate, or ??? Can I get one at radio shack or something..
thanks for the help guys!
Jon
If it came from a chainsaw or weedwacker, its GOTTA be good.
Hide Signatures
(in reply to TIGITRIGHT)
       Post #: 15
RE: S/S electronic ignition (Pics Added) - 8/16/2006 9:27 AM
blueberry
Score: 100
Status: offline
quote:
ORIGINAL: billzair
Jon
billzair,
Check post #10 it has Roy's number give him a call and I bet he can set you up.
Pete
Hide Signatures
(in reply to billzair)
       Post #: 16
RE: S/S electronic ignition (Pics Added) - 8/16/2006 4:35 PM
Eagle Flyer
Score: 100
Status: offline
Let us know how the 55 does......
Hide Signatures
       Post #: 17
RE: S/S electronic ignition (Pics Added) - 8/17/2006 3:58 PM
coralcape
Score: 100
Status: offline
Yep. You can get those little magnets at Radio Shack. They come two to a blister pack. I use the 1/4" size. Make sure you test on ignition before epoxing to pickup ring. They have to be oriented correctly. Good luck, red
Hide Signatures
       Post #: 18
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Engine Conversions >> S/S electronic ignition (Pics Added)
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.891RCU1
