RE: AXI 5330/F3A Flight Report
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: AXI 5330/F3A Flight Report
Page: <<   < prev  1 2 3 [4]
Login
RE: AXI 5330/F3A Flight Report - 10/1/2006 5:09:33 PM
Aladdin
Status: offline
ExFokkerFlyer .....I'm using an 21x13 on my 5330/FAI and sometimes I have the vibration you mentioned......how did you solve the problem??
Marco
(in reply to ExFokkerFlyer)
       Post #: 76
RE: AXI 5330/F3A Flight Report - 10/2/2006 7:01:27 PM
Aladdin
Status: offline
Thanks for PM.
Marco
(in reply to Aladdin)
       Post #: 77
RE: AXI 5330/F3A Flight Report - 1/10/2007 5:46:07 PM
leoni
Status: offline
ExFokkerFlyer...I'm using an 21x14 on my 5330/F3A and sometimes I have the vibration you mentioned......how did you solve the problem??
Thank¨s Andres.
       Post #: 78
RE: AXI 5330/F3A Flight Report - 1/10/2007 7:36:48 PM
Aladdin
Status: offline
Try to contact Mr. Jan
vaclavik@modelmotors.cz
he solved me the problem
Great service!!!
Marco
(in reply to leoni)
       Post #: 79
RE: AXI 5330/F3A Flight Report - 1/10/2007 9:02:37 PM
kmp647
Status: offline
Guys i HAVE A 5330/F3A JETI 90 IN A 12LB pattern plane lots of flights
I use hyperion lvx3700 cells(2 5s packs) great power with 20x11e prop
anyways last time I flew I had buzzing noises from the motor for no apparent reason
sometimes at full throttle sometimes part throttle
Motor inspection revealed nothing
anybody have any ideas?
       Post #: 80
RE: AXI 5330/F3A Flight Report - 1/11/2007 1:33:02 AM
patternflyer1
Status: offline
Look for a loose magnet.
Pretty sure it's your noise.
Chris
_____________________________
Team Airtronics
(in reply to kmp647)
       Post #: 81
RE: AXI 5330/F3A Flight Report - 1/11/2007 1:39:30 AM
patternflyer1
Status: offline
We found props to vary in quality. Generally we would switch props and the vibration would go away. Not saying this is your problem, but try a few different props.
Also, check your mounting screws. Possible cracks in the mounting block. (I had these due to using countersink type screws once). Check your fuse if nose mounted. Something in your fuse could have come loose..
Just ideas.
I know Tom (exfokker) got a nice new job and not sure how often he gets on here right now.
Let us all know what you find.
Chris
Team Airtronics
(in reply to leoni)
       Post #: 82
RE: AXI 5330/F3A Flight Report - 1/11/2007 8:20:08 AM
leoni
Status: offline
Hello, my axi f3a is ok whit 22/12 apc, but, when I put 21/14, start a strange and strong sound, like magnets, but I chek it and is all rhigt. I will talk whit modelmotors . Thanks.
(in reply to patternflyer1)
       Post #: 83
RE: AXI 5330/F3A Flight Report - 1/11/2007 11:08:19 AM
kmp647
Status: offline
I will double ck everything, but I cant imagine a magnet is loose
I think I will end up switching props
I am only running 20x11 and have very good cooling, 82 amps static 3,046 watts
many here run their f3a motos much harder than me(22x12 props) 90 plus amps?
maybe a prop or balance issue, but its much to low rpms for prop vibration
(in reply to leoni)
       Post #: 84
RE: AXI 5330/F3A Flight Report - 1/11/2007 2:26:09 PM
patternflyer1
Status: offline
I had a mag come loose after a crash, and one come loose on a new motor. Bad glue was the culprit.
I was suprised also..
Chris
Team Airtronics
       Post #: 85
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.422RCU1
