ST 2300 Carb & Muffler
Tower Hobbies
Logged in as Guest
  Printable Version
K&B .40 R/C Ball Bearing
Seller:  area51jmitch
Details:   $75.00   |  8/28/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> ST 2300 Carb & Muffler
Page: [1]
Login
ST 2300 Carb & Muffler - 11/15/2005 2:52:22 PM
buzzingb
Status: offline
I was looking at the carb and muffler on the Jett engineering web page for the 2300 and I am interested in one. If anyone has tried one of these products please post your results. Did you get metter midrange and transition? Did you get more rpms? Is this engine worth spending the extra money on to get it to run properly?
_____________________________
Buzz
       Post #: 1
RE: ST 2300 Carb & Muffler - 11/15/2005 3:51:58 PM
bob27s
Status: offline
Buzz,
There are a handful of folks out there flying the "red" carb on their ST2300 and ST3000 engines. You may want to post this in the glow forum.
There is not a huge rpm boost from the muffler. The engine is not agressively timed. However there is a noted boost in torque - usually you can go up one pitch size and keep the same rpm, and with the right prop the engine will unload nicely in the air. Does make it run great though Super smooth.
Worth considering the cost as you noted. The ST2300 is about $120. Carb and muffler are going to run $160 or so for the pair.
The newer ST2300 carbs have been pretty good.
Bob
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to buzzingb)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.282RCU1
