thecheatscalc
GA, USA Status: offline
heh, I tried landing on a pan, (and someone's flat head ) and it was amazing how much forward I had to push before I could land properly, when which once I got over the effect I was already overshot.... if you want a landing pad with none of that, buy a grid of thin, yet deep mesh of rectangles, similar to a radiator coils, just a little more space imbetween. Well, I've gotten over the problem of the flybar, for the moment, I used a glob of JB WELD to fix it, and it worked great, it held the fly... ok stabilizer bar under starting and stopping stresses very nicely, but, when I crashed (seeing how fast the bugar could go, not very) it just popped off and revealed that I had forgotten to remove the CA from the joint (I had tried to CA it back, didn't work) so, after a careful sanding job I've reglued it (setting a REGULAR lightbulb, on, next to the joint while it's drying works wonders, dries in about 2/5 the time. The secret to the stuff is it's a form of epoxy mixed with very fine metal shavings which are basicly absorbed by the epoxy. I have a few super magnets laying around, so, I had some fun watching the "blob" move around. anyways, it seems to have done a good job, I'm waiting for the skid glue to dry to see if it works there, but so far I'd recommend it, but, nothing makes it worth using than the advertisement on the back from somone "I've decided this is even better than bailing wire"
_____________________________
www.ushobbysupply.com - your #4 HQ! All stock located in the U-S of A!
