flying-llama
MA, USA Status: offline
quote:
ORIGINAL: thecheatscalc ... I had a question, I'm still using the stock charger and I've had a heck of a time with batteries swelling! I've so far lost three. would this be because of excessive discharging or is the charger at fault? So far, I have lost two batteries (one battery swelled after ~20 flights, another battery is weak after 1 flight, but no swelling). I have timed my charging, and it seems about right (1-3 hours, more as the voltage before charging is lower). I have also occasionally measured the voltage after charging and it seems fine (8.2-8.3 volts). During charging, the battery is not hot. So my guess is that my discharging is doing the damage. Unfortunately, I cannot yet monitor the condition of my battery while flying. One session, I measured the voltage while running my lama (pinned to the ground), and it was sometimes a lot lower than the voltage after stopping the lama (dropped to 6 volts while running, recovered to 7+ volts after stopping). I need to build/get some kind of airborne low voltage indicator and/or try some alternative power sources (wire for low level hovering, NiMH batteries?).
