flying-llama -> RE: E-SKY LAMA 2 THREAD (11/22/2006 7:22:58 PM)
quote:
ORIGINAL: sonicpelican ... My understanding is that the gyroscopic effect is 90 degrees from the point of force in the direction of rotation. However the linkages that control the angle of the lower blades are offset from the from the blades by an arc of 90 degrees. This being the case, looking from the rear of the Lama with the swashplate tilted forward and the linkages being offset by 90 degrees, an upward force will be applied to the right side of the helicopter. Then, taking into account the gyroscopic effect the aircraft should move forward. Another way to look at this is if the swashplate is tilted forward the retreating blade will have a higher angle of attack and the advancing blade a lower angle of attack, thus the retreating blade will create more lift than the advancing blade creating additional lift on the right side of the heli. Then apply the gyroscopic effect rules and the aircraft should go forward. ... I have read that while the angle of the effect is 90 degrees in theory, in practice the angle is not 90 degrees, but needs to be determined experimentally. I do know that in both my Lama2 and Hirobo XRB lama, both servos are at about a 45 degree angle from either the helicopter's X or Y axis, and that in both, when I move the cyclic stick forward/back only 1 servo moves, and when I move the cyclic stick left/right only the other servo moves. quote:
ORIGINAL: sonicpelican ... Crikey, now my head hurts, all I really wanted to think about was a tasty curry seafood laksa. ... I agree, trying to think this through tends to result in a headache. quote:
ORIGINAL: sonicpelican ... Anyway, without any intervention, when I power on the Lama the swashplate is angled to the rear of the heli and slightly to the right, where previously it was dead horizontal. The cyclic control stick is centred and all trim tabs are centred as they were before the little possum decided to take long service leave. I might take a look in the transmitter. Nine flights ago I decided to change from Mode 1 to Mode 2. I did some soldering in the transmitter to get it working properly on Mode 2 and maybe a stray piece of solder has shorted something. ... Two other possible ways to try to fix things: 1. Move the left/right cyclic trim tab and forward/backward cyclic trim tab (each should just move 1 servo) to get the swashplate to be level after power-on, or (harder to do): 2. Turn the links between the swashplate and servos to get the swashplate to be level after power-on: Each link should have a metal part (connected to the servo) and a plastic part (connected to a ball joint on the swashplate). Disconnect one end of each link (the swashplate end is probably easier). Then one should be able to turn the metal and plastic part relative to each other to lengthen or shorten the link as needed.
